MTB080012A
MTB080012A
    INVENTUSPOWER
    MTB080系列是65-100W的医疗级开放式电源模块,具有高效率、高功率密度和多种保护功能。输入电压范围为85-264VAC,输出电压有9.0V、12.0V、15.0V和24.0V四种选项。
MTB080012A 数据手册
MTB080 Series 65 ­ 100 W Medical Open Frame Power Supply High Efficiency: Level V High Power Density 12.5W/in3 Output Floating Lifetime Expectation >5 years Hold­up Time 28ms at full load Medical Approval ­ EN60601­1 Class I Elpac Part Number Output Voltage Output Peak Total Typical Current1 Current2 Regulation3 Efficiency4 MTB080009A 9.0V 7.2A 10.0A ±5% 88% MTB080012A 12.0V 6.7A 8.3A ±5% 90% MTB080015A 15.0V 5.4A 6.7A ±5% 90% MTB080024A 24.0V 3.4A 4.2A ±5% 91% Notes 1 Maximum load current with natural convection cooling 2 Maximum peak load lasting up to 4 seconds with natural convection cooling, or maximum continuous output current with minimum 5 CFM airflow. 3 Includes initial setting, line regulation, load, regulation, and thermal drift. 4 Typical at 115VAC and full load (65W) Input Input Voltage 85 ­ 264VAC 100 ­ 240VAC Nominal Input Frequency 47 ­ 63Hz Input Current
MTB080012A 价格&库存
很抱歉,暂时无法提供与“MTB080012A”相匹配的价格&库存,您可以联系我们找货
