ML15.051
ML15.051
    PULS
    AC/DCCONVERTER5V15W
ML15.051 数据手册
ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 POWER SUPPLY         100-240V Wide Range Input NEC Class 2 Compliant Adjustable Output Voltage Efficiency up to 77.2% Compact Design, Width only 22.5mm Full Output Power Between -10°C and +60°C Large International Approval Package 3 Year Warranty GENERAL DESCRIPTION SHORT-FORM DATA A compact size, light weight, simple mounting onto the DIN-rail and the utilization of only quality components are what makes the MiniLine power supplies so easy to use and install within seconds. Output voltage Adjustment range Output current Output power Output ripple Input voltage Mains frequency AC Input current Power factor AC Inrush current DC 5V 5 – 5.5V 3A at 5V 15W < 50mVpp AC 100-240V 50-60Hz 0.28 / 0.17A 0.51 / 0.44 typ. 16 /31A DC Input Efficiency Losses Temperature range Derating Hold-up time Dimensions Weight 88-375Vdc 76.8 / 77.2% 4.6 / 4.5W -10°C to +70°C 0.4W/°C typ. 45 / 186ms 22.5x75x91mm 130g / 0.29lb A rugged electrical and mechanical design as well as a high immunity against electrical disturbances on the mains provides reliable output power. This offers superior protection for equipment which is connected to the public mains network or is exposed to a critical industrial environment. The MiniLine series offers output voltages from 5 to 56Vdc and a power rating from 15W to 120W. ORDER NUMBERS Power Supply ML15.051 20Hz to 20MHz -15% / +10% ±6% at 120 / 230Vac at 120 / 230Vac peak value at 120/230Vac, 40°C and cold start at 120 / 230Vac at 120 / 230Vac operational +60 to +70°C at 120 / 230Vac WxHxD MARKINGS 5V Standard unit UL 508 UL 60950-1 Class I Div 2 IEC 60950-1 Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 1/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 INDEX Page 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. Intended Use .......................................................3 Installation Requirements ...................................3 AC-Input...............................................................5 DC-Input...............................................................6 Input Inrush Current ...........................................6 Output .................................................................7 Hold-up Time .......................................................8 Efficiency and Power Losses................................9 Functional Diagram...........................................10 Front Side and User Elements ...........................10 Terminals and Wiring ........................................11 Lifetime Expectancy and MTBF.........................11 EMC ....................................................................12 Environment ......................................................13 Protection Features ...........................................14 Safety Features ..................................................14 Dielectric Strength ............................................15 Page 18. Approvals and Fulfilled Standard .................... 16 19. Regulatory Compliance .................................... 18 20. Physical Dimensions and Weight ..................... 19 21. Application Notes ............................................. 20 21.1. Peak Current Capability ........................... 20 21.2. Back-feeding Loads .................................. 20 21.3. External Input Protection ......................... 21 21.4. Parallel Use to Increase Output Power .... 21 21.5. Parallel Use for Redundancy .................... 22 21.6. Series Operation ....................................... 22 21.7. Inductive and Capacitive Loads................ 22 21.8. Operation on Two Phases ........................ 23 21.9. Use Without PE on the Input ................... 23 21.10. Use in a Tightly Sealed Enclosure ............ 24 21.11. Mounting Orientations ............................ 25 The information presented in this document is believed to be accurate and reliable and may change without notice. The housing is patent by PULS (US patent No US D442,923S) No part of this document may be reproduced or utilized in any form without permission in writing from the publisher. TERMINOLOGY AND ABREVIATIONS PE and symbol PE is the abbreviation for Protective Earth and has the same meaning as the symbol . Earth, Ground This document uses the term “earth” which is the same as the U.S. term “ground”. T.b.d. To be defined, value or description will follow later. AC 230V A figure displayed with the AC or DC before the value represents a nominal voltage with standard tolerances (usually ±15%) included. E.g.: DC 12V describes a 12V battery disregarding whether it is full (13.7V) or flat (10V) 230Vac A figure with the unit (Vac) at the end is a momentary figure without any additional tolerances included. 50Hz vs. 60Hz As long as not otherwise stated, AC 100V and AC 230V parameters are valid at 50Hz and AC 120V parameters are valid at 60Hz mains frequency. Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 2/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 1. INTENDED USE This device is designed for installation in an enclosure and is intended for commercial use, such as in industrial control, process control, monitoring and measurement equipment or the like. Do not use this device in equipment, where malfunctioning may cause severe personal injury or threaten human life without additional appropriate safety devices, that are suited for the endapplication. If this device is used in a manner outside of its specification, the protection provided by the device may be impaired. 2. INSTALLATION REQUIREMENTS Install device in an enclosure providing protection against electrical, mechanical and fire hazards. Install the device onto a DIN-rail according to EN 60715 with the input terminals on the bottom of the device. Other mounting orientations require a reduction in output current. Make sure that the wiring is correct by following all local and national codes. Use appropriate copper cables that are designed for a minimum operating temperature of 60°C for ambient temperatures up to +45°C, 75°C for ambient temperatures up to +60°C and 90°C for ambient temperatures up to +70°C. Ensure that all strands of a stranded wire enter the terminal connection. Unused screw terminals should be securely tightened. The device is designed for pollution degree 2 areas in controlled environments. No condensation or frost is allowed. The housing of the device provides a degree of protection of IP20. The housing does not provide protection against spilled liquids. The isolation of the device is designed to withstand impulse voltages of overvoltage category III according to IEC 60664-1. The device is designed as “Class of Protection” I equipment according to IEC 61140. Do not use without a proper PE (Protective Earth) connection. The device is suitable to be supplied from TN, TT or IT mains networks. The continuous voltage between the input terminal and the PE potential must not exceed 300Vac. The input can also be powered from batteries or similar DC sources. The continuous voltage between the supply voltage and the PE/ground potential must not exceed 375Vdc. Connect the +pole to L and the -pole to the N terminal. A disconnecting means shall be provided for the input of the device. The device is designed for convection cooling and does not require an external fan. Do not obstruct airflow and do not cover ventilation grid! The device is designed for altitudes up to 5000m (16400ft). Above 2000m (6560ft) a reduction in output current and over voltage category is required. Keep the following minimum installation clearances: 40mm on top, 20mm on the bottom, 0mm left and right side. Increase the 0mm to 15mm in case the adjacent device is a heat source. The device is designed, tested and approved for branch circuits up to 20A without additional protection device. If an external fuse is utilized, do not use circuit breakers smaller than 6A B- or 3A C-Characteristic to avoid a nuisance tripping of the circuit breaker. The maximum surrounding air temperature is +70°C (+158°F). The operational temperature is the same as the ambient or surrounding air temperature and is defined 2cm below the device. The device is designed to operate in areas between 5% and 95% relative humidity. WARNING Risk of electrical shock, fire, personal injury or death. - Do not use the power supply without proper grounding (Protective Earth). Use the terminal on the input block for earth connection and not one of the screws on the housing. - Turn power off before working on the device. Protect against inadvertent re-powering. - Make sure that the wiring is correct by following all local and national codes. - Do not modify or repair the unit. - Do not open the unit as high voltages are present inside. - Use caution to prevent any foreign objects from entering into the housing. - Do not use in wet locations or in areas where moisture or condensation can be expected. - Do not touch during power-on, and immediately after power-off. Hot surface may cause burns. Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 3/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 Notes for use in hazardous location areas: The power supply is suitable for use in Class I Division 2 Groups A, B, C, D locations. WARNING EXPLOSION HAZARDS! Substitution of components may impair suitability for this environment. Do not disconnect the unit or operate the voltage adjustment unless power has been switched off or the area is known to be non-hazardous. Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 4/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 3. AC-INPUT AC input AC input range nom. Allowed voltage L or N to earth Input frequency Turn-on voltage Shut-down voltage max. nom. typ. typ. AC 100-240V 85-264Vac 264–300Vac 300Vac 50–60Hz 59Vac 54Vac Input current (rms) Power factor *) Crest factor **) Start-up delay Rise time Turn-on overshoot typ. typ. typ. typ. typ. max. AC 100V 0.34A 0.52 3.45 630ms 10ms 100mV -15% / +10%, TN/TT/IT-mains continuous operation < 0.5s ±6% steady-state value, see Fig. 3-1 steady-state value, see Fig. 3-1 AC 120V 0.28A 0.51 3.53 630ms 10ms 100mV AC 230V 0.17A 0.44 3.94 630ms 10ms 100mV at 5V, 3A see Fig. 3-3 at 5V, 3A see Fig. 3-4 at 5V, 3A see Fig. 5 2 at 5V, 3A, see Fig. 3-2 see Fig. 3-2 *) The power factor is the ratio of the true (or real) power to the apparent power in an AC circuit. **) The crest factor is the mathematical ratio of the peak value to RMS value of the input current waveform. Rated input range max. 500ms Turn-on Shut-down POUT Fig. 3-2 Turn-on behavior, definitions Intput Voltage VIN 54V 59V 85V Start-up delay Rise Time 264V 300Vac Fig. 3-3 Input current vs. output load Fig. 3-4 Power factor vs. output load Input Current, typ. 0.4A 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 - 5% Output Voltage Overshoot Fig. 3-1 Input voltage range Power Factor, typ. a) 100Vac b) 120Vac c) 230Vac a 0.55 b 0.50 a) 100Vac b) 120Vac c) 230Vac a b 0.45 c c 0.40 0.35 Output Current 0 0.5 1.0 1.5 2.0 2.5 3.0A 0.30 0.5 Output Current 1.0 1.5 2.0 2.5 3.0A Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 5/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 4. DC-INPUT DC input DC input range DC input current Turn-on voltage Shut-down voltage nom. typ. typ. typ. DC 110-300V 88-375Vdc 0.16A / 0.057A 80Vdc 60Vdc Instructions for DC use: a) Use a battery or similar DC source. For other sources contact PULS b) Connect +pole to L and –pole to N. c) Connect the PE terminal to an earth wire or to the machine ground. Fig. 4-1 Wiring for DC Input Battery Power Supply + AC L internal fused + N - PE - -20%/+25% continuous operation 110Vdc / 300Vdc, at 5V, 3A steady state value steady state value Load DC 5. INPUT INRUSH CURRENT A NTC limits the input inrush current after turn-on of the input voltage. The inrush current is input voltage and ambient temperature dependent. The charging current into EMI suppression capacitors is disregarded in the first microseconds after switch-on. Inrush current Inrush energy max. typ. max. AC 100V 13Apeak 11Apeak 0.1A2s AC 120V 16Apeak 13Apeak 0.1A2s AC 230V 31Apeak 26Apeak 0.4A2s 40°C ambient, cold start 40°C ambient, cold start 40°C ambient, cold start Fig. 5-1 Input inrush current, typical behavior Fig. 5-2 Input inrush current, zoom into first peak Input: Output: Ambient: Upper curve: Lower curve: Time basis: Input: 230Vac Output: 5V, 3A Ambient: 25°C Input current curve: 5A/DIV, 500µs / DIV Ipeak 23A 230Vac 5V, 3A 25°C Input current 5A/DIV Input voltage 500V/DIV 10ms / DIV Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 6/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 6. OUTPUT Output voltage Adjustment range nom. max. Factory setting Line regulation Load regulation Ripple and noise voltage Output capacitance Output current max. max. max. typ. nom. nom. nom. min. max. Output power Short-circuit current *) 5V 5-5.5V 6V *) 5.1V 10mV 100mV 50mVpp 4 800µF 3A 2.72A 15W hiccup mode 3A rms-current guaranteed at clockwise end position of potentiometer ±0.2%, at full load, cold unit 85-264Vac static value, 0A  3A 20Hz to 20MHz, 50Ohm at 5V, see Fig. 6-1 at 5.5V, see Fig. 6-1 see Fig. 6-2 short circuit impedance 2V D Output voltage potentiometer Turn to set the output voltage. Factory set: 5.1V Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 10/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 11. TERMINALS AND WIRING All terminals are easy to access when mounted on the panel. Input and output terminals are separated from each other (input below, output above) to help in error-free wiring. Type Solid wire Stranded wire American Wire Gauge Wire stripping length Screwdriver Recommended tightening torque Input screw terminals 0.5-6mm2 0.5-4mm2 20-10 AWG 7mm / 0.275inch 3.5mm slotted or Pozidrive No 2 1Nm, 9lb.in Output screw terminals 0.5-6mm2 0.5-4mm2 20-10 AWG 7mm / 0.275inch 3.5mm slotted or Pozidrive No 2 1Nm, 9lb.in Instructions: a) Use appropriate copper cables that are designed for minimum operating temperatures of: 60°C for ambient up to 45°C and 75°C for ambient up to 60°C minimum. b) Follow national installation codes and installation regulations! c) Ensure that all strands of a stranded wire enter the terminal connection! d) Up to two stranded wires with the same cross section are permitted in one connection point (except PE wire). e) Do not use the unit without PE connection. f) Screws of unused terminal compartments should be securely tightened. g) Ferrules are allowed. 12. LIFETIME EXPECTANCY AND MTBF These units are extremely reliable and use only the highest quality materials. The number of critical components such as electrolytic capacitors has been reduced. Lifetime expectancy *) MTBF **) SN 29500, IEC 61709 MTBF **) MIL HDBK 217F AC 100V 66 000h > 15 years > 15 years 2 479 000h 4 066 000h 1 175 000h 1 575 000h AC 120V 70 000h > 15 years > 15 years 2 838 000h 4 654 000h 1 251 000h 1 676 000h AC 230V 93 000h > 15 years > 15 years 2 686 000h 4 405 000h 1 145 000h 1 534 000h at 5V, 3A and 40°C at 5V, 1.5A and 40°C at 5V, 3A and 25°C at 5V, 3A and 40°C at 5V, 3A and 25°C at 5V, 3A and 40°C; Ground Benign GB40 at 5V, 3A and 25°C; Ground Benign GB25 The Lifetime expectancy shown in the table indicates the minimum operating hours (service life) and is determined by the lifetime expectancy of the built-in electrolytic capacitors. Lifetime expectancy is specified in operational hours and is calculated according to the capacitor’s manufacturer specification. The prediction model allows only a calculation of up to 15 years from date of shipment. **) MTBF stands for Mean Time Between Failure, which is calculated according to statistical device failures, and indicates reliability of a device. It is the statistical representation of the likelihood of a unit to fail and does not necessarily represent the life of a product. The MTBF figure is a statistical representation of the likelihood of a device to fail. A MTBF figure of e.g. 1 000 000h means that statistically one unit will fail every 100 hours if 10 000 units are installed in the field. However, it can not be determined if the failed unit has been running for 50 000h or only for 100h. *) Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 11/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 13. EMC The power supply is suitable for applications in industrial environment as well as in residential, commercial and light industry environment without any restrictions. A detailed EMC report is available on request. EMC Immunity Electrostatic discharge Electromagnetic RF field Fast transients (Burst) Surge voltage on input Generic standards: EN 61000-6-1 and EN 61000-6-2 Contact discharge EN 61000-4-2 Air discharge EN 61000-4-3 80MHz-2.7GHz Input lines EN 61000-4-4 Output lines EN 61000-4-5 LN N  PE, L  PE ++  PE, -  PE 0.15-80MHz 0% of 100Vac 40% of 100Vac 70% of 100Vac 0% of 200Vac 40% of 200Vac 70% of 200Vac Surge voltage on output EN 61000-4-5 Conducted disturbance Mains voltage dips EN 61000-4-6 EN 61000-4-11 Voltage interruptions Input voltage swells Powerful transients EN 61000-4-11 PULS internal standard VDE 0160 over entire load range 8kV 8kV 10V/m 4kV 2kV 2kV 4kV Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A Criterion A 500V 2kV 10V 0Vac, 20ms 40Vac, 200ms 70Vac, 500ms 0Vac, 20ms 80Vac, 200ms 140Vac, 500ms 0Vac, 5000ms 300Vac, 500ms 750V, 1.3ms Criterion A Criterion A Criterion A Criterion A Criterion C Criterion A Criterion A Criterion A Criterion A Criterion C Criterion A Criterion A Criterions: A: Power supply shows normal operation behavior within the defined limits. C: Temporary loss of function is possible. Power supply may shut-down and restarts by itself. No damage or hazards for the power supply will occur. EMC Emission Conducted emission Radiated emission Harmonic input current Generic standards: EN 61000-6-3 and EN 61000-6-4 EN 55011, EN 55032, FCC Part 15, CISPR 11, CISPR 32 EN 55011, EN 55032 EN 61000-3-2 Class B, input lines Class B Not applicable below 75W input power fulfilled Voltage fluctuations, flicker EN 61000-3-3 This device complies with FCC Part 15 rules. Operation is subjected to following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. Switching frequency Constant, typ. 65kHz Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 12/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 14. ENVIRONMENT Operational temperature *) Storage temperature Output de-rating Humidity **) Vibration sinusoidal Shock Altitude Altitude de-rating Over-voltage category -10°C to +70°C (14°F to 158°F) -40 to +85°C (-40°F to 185°F) 0.4W/°C 5 to 95% r.H. 2-17.8Hz: ±1.6mm; 17.8-500Hz: 2g 2 hours / axis 30g 6ms, 20g 11ms 3 bumps / direction, 18 bumps in total 0 to 6000m (0 to 20 000ft) Reduce output power according Fig. 14-1 For storage and transportation 60-70°C (140°F to 158°F) IEC 60068-2-30 IEC 60068-2-6 IEC 60068-2-27 Reduce output power or ambient temperature above 2000m sea level. above 2000m (6500ft), see Fig. 14-2 IEC 62103, EN 50178, altitudes up to 2000m Altitudes from 2000m to 6000m IEC 62103, EN 50178, not conductive 1W/1000m or 5°C/1000m III II 2 Degree of pollution *) Operational temperature is the same as the ambient temperature and is defined as the air temperature 2cm below the unit. **) Do not energize while condensation is present Fig. 14-1 Output power vs. ambient temp. Fig. 14-2 Output power vs. altitude Allowable Output Power Allowable Output Power 15W 15W 12.5 12.5 10.0 10.0 7.5 7.5 5.0 5.0 2.5 -10 0 20 40 A... Tamb < 60°C B... Tamb < 50°C C... Tamb < 40°C 2.5 Ambient Temperature 0 A 0 2000 C Altitude 0 60 70°C B 4000 6000m Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 13/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 15. PROTECTION FEATURES Output protection Output over-voltage protection Output over-current protection Degree of protection Penetration protection Over-temperature protection Input transient protection Internal input fuse *) Electronically protected against overload, no-load and short-circuits *) typ. 8.7Vdc In case of an internal power supply fault, a redundant max. 9.6Vdc circuit limits the maximum output voltage. In such a case, the output shuts down and stays down until the input voltage is turned off and on again. electronically limited see Fig. 6-2 IP 20 EN/IEC 60529 > 2.5mm in diameter e.g. screws, small parts Not included MOV Metal Oxide Varistor T3.15A H.B.C. not user replaceable In case of a protection event, audible noise may occur. 16. SAFETY FEATURES Input / output separation *) Class of protection Isolation resistance Touch current (leakage current) *) SELV PELV I II (with restrictions) > 5MOhm typ. 0.17mA / 0.38mA typ. 0.24mA / 0.55mA typ. 0.40mA / 0.86mA < 0.21mA / 0.44mA < 0.30mA / 0.66mA < 0.54mA / 1.08mA IEC/EN 60950-1 IEC/EN 60204-1, EN 50178, IEC 62103, IEC 60364-4-41 PE (Protective Earth) connection required for use without PE connection contact PULS Input to output, 500Vdc 100Vac, 50Hz, TN-,TT-mains / IT-mains 120Vac, 60Hz, TN-,TT-mains / IT-mains 230Vac, 50Hz, TN-,TT-mains / IT-mains 110Vac, 50Hz, TN-,TT-mains / IT-mains 132Vac, 60Hz, TN-,TT-mains / IT-mains 264Vac, 50Hz, TN-,TT-mains / IT-mains Double or reinforced insulation Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 14/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 17. DIELECTRIC STRENGTH The output voltage is floating and has no ohmic connection to the ground. Type and factory tests are conducted by the manufacturer. Field tests may be conducted in the field using the appropriate test equipment which applies the voltage with a slow ramp (2s up and 2s down). Connect all phase-terminals together as well as all output poles before conducting the test. When testing, set the cut-off current settings to the value in the table below. Type test 60s A 2500Vac B 3000Vac C 500Vac Factory test 5s 2500Vac 2500Vac 500Vac Field test 5s 2000Vac 2000Vac 500Vac > 6mA > 6mA > 1mA Fig. 17-1 Dielectric strength Input L N B Output A Earth, PE + C - Cut-off current setting To fulfill the PELV requirements according to EN60204-1 § 6.4.1, we recommend that either the + pole, the – pole or any other part of the output circuit shall be connected to the protective earth system. This helps to avoid situations in which a load starts unexpectedly or can not be switched off when unnoticed earth faults occur. Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 15/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 18. APPROVALS AND FULFILLED STANDARD UL 508 IEC 60950-1 UL 60950-1 Class I Div 2 UL Certificate Listed equipment for category NMTR - Industrial Control Equipment and Fulfilled Standard Applicable for US and Canada E-File: E198865 CB Scheme Certificate General safety requirements for Information Technology Equipment (ITE) UL Certificate Recognized component for category QQGQ - Information Technology Equipment (ITE) Applicable for US and Canada E-File: E137006 CSA Certificate Power Supplies for Hazardous Location Applicable for Canada and US CSA Class: 5318-01 (Canada), 5318-81 (USA) Temperature Code: T4 Groups: A, B, C and D NEC Class 2 Manufacturer's Declaration NEC CLASS 2 – Limited Power Source Listed device according to NEC Handbook chapter 725-121 Marine (DNV GL) DNV-GL Certificate DNV-GL Type approved product Certificate: TAA00001ST Temperature: Class B Humidity: Class B Vibration: Class C EMC: Class A Enclosure: Class A ABS Design Assessment Certificate ABS (American Bureau of Shipment) assessed product Certificate: 17-HG1599236-PDA Marine (ABS) IEC 60068-2-60 Manufacturer's Declaration (Online Document) Environmental Tests, Flowing Mixed Gas Corrosion Test Test Ke - Method 4 H2S: 10ppb NO2: 200ppb Cl2: 10ppb SO2: 200ppb Test Duration: 3 weeks, which simulates a service life of at least 10 years. ISA-71.04-1985 Manufacturer's Declaration (Online Document) Airborne Contaminants Corrosion Test Severity Level: G3 Harsh H2S: 100ppb NOx: 1250ppb Cl2: 20ppb SO2: 300ppb Test Duration: 3 weeks, which simulates a service life of at least 10 years. Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 16/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 VDMA 24364 Paint Wetting Impairment Substances Test (or LABS-Test) Tested for Zone 2 and test class C1 according to VDMA 24364-C1-L/W for solvents and water-based paints Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 17/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 19. REGULATORY COMPLIANCE EU Declaration of Conformity REACH Directive EAC TR Registration The CE mark indicates conformance with the - EMC directive - Low-voltage directive (LVD) - RoHS directive Manufacturer's Statement EU-Directive regarding the Registration, Evaluation, Authorisation and Restriction of Chemicals EAC Certificate EAC EurAsian Conformity - Registration Russia, Kazakhstan and Belarus 8504408200, 8504409000 Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 18/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 20. PHYSICAL DIMENSIONS AND WEIGHT Weight DIN-Rail Installation Clearances 130g / 0.29lb Use 35mm DIN-rails according to EN 60715 or EN 50022 with a height of 7.5 or 15mm. The DIN-rail height must be added to the unit depth (91mm) to calculate the total required installation depth. See chapter 2 Fig. 20-1 Front view Fig. 20-2 Side view Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 19/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 21. APPLICATION NOTES 21.1. PEAK CURRENT CAPABILITY Solenoids, contactors and pneumatic modules often have a steady state coil and a pick-up coil. The inrush current demand of the pick-up coil is several times higher than the steady-state current and usually exceeds the nominal output current (including the PowerBoost) The same situation applies, when starting a capacitive load. Branch circuits are often protected with circuit breakers or fuses. In case of a short or an overload in the branch circuit, the fuse needs a certain amount of over-current to trip or to blow. The peak current capability ensures the safe operation of subsequent circuit breakers. Assuming the input voltage is turned on before such an event, the built-in large sized output capacitors inside the power supply can deliver extra current. Discharging this capacitor causes a voltage dip on the output. The following two examples show typical voltage dips: Fig. 21-1 Peak loading with 2x the nominal current for 50ms, typ. Fig. 21-2 Peak loading with 5x the nominal current for 5ms, typ. Peak load 6A (resistive load) for 50ms Output voltage dips from 5.1V to 2.4V. Peak load 15A (resistive load) for 5ms Output voltage dips from 5.1V to 0.8V. 21.2. BACK-FEEDING LOADS Loads such as decelerating motors and inductors can feed voltage back to the power supply. This feature is also called return voltage immunity or resistance against Back- E.M.F. (Electro Magnetic Force). The maximum allowed feed back voltage is 6.3Vdc. The absorbing energy can be calculated according to the built-in large sized output capacitor which is specified in chapter 6. This power supply is resistant and does not show malfunctioning when a load feeds back voltage to the power supply. It does not matter, whether the power supply is on or off. However, please note that the output voltage can dip to zero for approximately 200ms if the back-feed voltage is removed. Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 20/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 21.3. EXTERNAL INPUT PROTECTION The unit is tested and approved for branch circuits up to 20A. An external protection is only required, if the supplying branch has an ampacity greater than this. Check also local codes and local requirements. In some countries local regulations might apply. If an external fuse is necessary or utilized, minimum requirements need to be considered to avoid nuisance tripping of the circuit breaker. A minimum value of 6A B- or 3A C-Characteristic breaker should be used. Unit A 21.4. PARALLEL USE TO INCREASE OUTPUT POWER AC + ML15.051 power supplies can be paralleled to increase the output power. This power supply has no feature included which balances the load current DC + between the power supplies. Usually the power supply with the higher Unit B adjusted output voltage draws current until it goes into current limitation. This Load AC means no harm to this power supply as long as the ambient temperature stays + below 45°C. The ML15.051 can also be paralleled with power supplies from MiniLine series with 5V output voltage. The output voltages of all power DC supplies shall be adjusted to the same value (±100mV). A fuse or diode on the output of each unit is only required if more than three units are connected in parallel. If a fuse (or circuit breaker) is used, choose one with approximately 150% of the rated output current of one power supply. Keep an installation clearance of 15mm (left / right) between two power supplies and avoid installing the power supplies on top of each other. Do not use power supplies in parallel in mounting orientations other than the standard mounting orientation (input terminals on the bottom and output terminals on top of the unit). Pay attention that leakage current, EMI, inrush current, harmonics will increase when using multiple power supplies. Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 21/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 21.5. PARALLEL USE FOR REDUNDANCY Power supplies can be paralleled for redundancy to gain higher system availability. Redundant systems require a certain amount of extra power to support the load in case one power supply unit fails. The simplest way is to put two power supplies in parallel. This is called a 1+1 redundancy. In case one power supply unit fails, the other one is automatically able to support the load current without any interruption. Redundant systems for a higher power demand are usually built in a N+1 method. E.g. five power supplies, each rated for 3A are paralleled to build a 12A redundant system. Please note: This simple way to build a redundant system does not cover failures such as an internal short circuit in the secondary side of the power supply. In such a case, the defect unit becomes a load for the other power supplies and the output voltage can not be maintained any more. This can only be avoided by utilizing decoupling diodes which are included in the decoupling module MLY02.100. Recommendations for building redundant power systems: a) Use separate input fuses for each power supply. b) Monitor the individual power supply units. c) 1+1 Redundancy is allowed up to an ambient temperature of 60°C N+1 Redundancy is allowed up to an ambient temperature of 45°C d) It is desirable to set the output voltages of all units to the same value (± 100mV) or leave it at the factory setting. 21.6. SERIES OPERATION Unit A Power supplies of the exact same type can be connected in series for higher AC + output voltages. It is possible to connect as many units in series as needed, providing the sum of the output voltage does not exceed 150Vdc. Voltages DC with a potential above 60Vdc are not SELV any more and can be dangerous. + Such voltages must be installed with a protection against touching. Earthing of Unit B Load the output is required when the sum of the output voltage is above 60Vdc. AC Avoid return voltage (e.g. from a decelerating motor or battery) which is + applied to the output terminals. Keep an installation clearance of 15mm (left / Earth right) between two power supplies and avoid installing the power supplies on DC top of each other. Do not use power supplies in series in mounting orientations other than the standard mounting orientation (input terminals on the bottom and output terminals on top of the unit). Pay attention that leakage current, EMI, inrush current, harmonics will increase when using multiple power supplies. 21.7. INDUCTIVE AND CAPACITIVE LOADS The unit is designed to supply unlimited inductive loads. The max. capacitive load depend on the steady state output current. At 3A output current, the output capacity should not be larger than 10 000µF and at 0.3A output current not larger than 25 000µF. In case of larger capacitors, the unit can show start-up attempts or start-up problems. Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 22/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 21.8. OPERATION ON TWO PHASES Power Supply L1 AC 240V +10% max. The power supply can also be used on two-phases of a three-phase-system. Such a phase-to-phase connection is allowed as long as the supplying voltage is below 240V+10%. Use a fuse or a circuit breaker to protect the N input. The N input is internally not protected and is in this case connected to a hot wire. Appropriate fuses or circuit breakers are specified in section 21.3 “External Input Protection”. L3 L Fuse internal fuse N PE DC L2 21.9. USE WITHOUT PE ON THE INPUT From a safety standpoint, the unit is internally designed according to the requirements for Protection Class 1 and 2. Please contact PULS if you do not plan to use the PE terminal. A different marking of the front foil is then required. Grounding of the input is beneficial for a high EMI immunity: Symmetrical spikes or fast transients on the input side can be conducted directly to earth by the built-in filter capacitors. The magnitude of such spikes or fast transients on the output side caused by the input is much smaller compared to not connecting this terminal to ground. Fig. 21-3 Earthed input Fig. 21-4 Not earthed input Surge Spike Surge 24V L Power Supply + L - N X N Power Supply + X - Y Ground Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 23/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 21.10. USE IN A TIGHTLY SEALED ENCLOSURE When the power supply is installed in a tightly sealed enclosure, the temperature inside the enclosure will be higher than outside. In such situations, the inside temperature defines the ambient temperature for the power supply. The following measurement results can be used as a reference to estimate the temperature rise inside the enclosure. The power supply is placed in the middle of the box, no other heat producing items are inside the box Enclosure: Input: Rittal Type IP66 Box PK 9510 100, plastic, 130x130x75mm 230Vac Case A: Load: Temperature inside the box: Temperature outside the box: Temperature rise: 5V, 3A; load is placed outside the box 38.2°C (in the middle of the right side of the power supply with a distance of 1cm) 26.0°C 12.2K Case B: Load: Temperature inside the box: Temperature outside the box: Temperature rise: 5V, 2.4A; (=80%) load is placed outside the box 35.3°C (in the middle of the right side of the power supply with a distance of 1cm) 25.6°C 9.7K Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 24/25 ML15.051 5V, 3A, SINGLE PHASE INPUT MiniLine-2 21.11. MOUNTING ORIENTATIONS Mounting orientations other than input terminals on the bottom and output on the top require a reduction in continuous output power or a limitation in the max. allowed ambient temperature. The amount of reduction influences the lifetime expectancy of the power supply. Therefore, two different derating curves for continuous operation can be found below: Curve A1 Curve A2 Recommended output current. Max allowed output current (results in approximately half the lifetime expectancy of A1). Fig. 21-5 Mounting Orientation A (Standard orientation) Output Power OUTPUT 15W 12 9 6 3 0 10 Power Supply INPUT Fig. 21-6 Mounting Orientation B (Upside down) 20 30 40 50 60°C INPUT 15W 12 9 6 3 0 10 A2 A1 Ambient Temperature 20 30 40 50 60°C Power Supply OUTPUT Output Power 15W 12 9 6 3 0 10 A2 A1 Ambient Temperature 20 30 40 50 60°C Output Power OUTPUT Power Supply INPUT 15W 12 9 6 3 0 10 A2 A1 Ambient Temperature 20 30 40 50 60°C INPUT Power Supply Output Power OUTPUT Fig. 21-9 Mounting Orientation E (Horizontal ccw) Ambient Temperature Output Power Fig. 21-7 Mounting Orientation C (Table-top mounting) Fig. 21-8 Mounting Orientation D (Horizontal cw) A1 15W 12 9 6 3 0 10 A2 A1 Ambient Temperature 20 30 40 50 60°C Nov. 2020 / Rev. 2.2 DS-ML15.051-EN All parameters are specified at 5V, 3A, 230Vac input, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 25/25
ML15.051 价格&库存
很抱歉,暂时无法提供与“ML15.051”相匹配的价格&库存,您可以联系我们找货
