QS3.241
QS3.241
    PULS
    AC/DCCONVERTER24V80W
QS3.241 数据手册
QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series POWER SUPPLY           AC 100-240V Wide-range Input Width only 32mm Efficiency up to 90% 150% (120W) Peak Load Capability Easy Fuse Tripping due to High Overload Current Negligible low Inrush Current Surge Short-term Operation down to 60Vac and up to 300Vac Full Power Between -25°C and +60°C Quick-connect Spring-clamp Terminals 3 Year Warranty GENERAL DESCRIPTION SHORT-FORM DATA The most outstanding features of this Dimension QSeries DIN-rail power supply are the high efficiency and the small size, which are achieved by a synchronous rectification and further novel design details. The QSeries is part of the Dimension family, existing alongside the lower featured C-Series. Output voltage Adjustment range Output current With short-term peak power capability of 150% and built-in large sized output capacitors, these features help start motors, charge capacitors and absorb reverse energy and often allow a unit of a lower wattage class to be used. High immunity to transients and power surges as well as low electromagnetic emission makes usage in nearly every environment possible. The integrated output power manager, a wide range input voltage design and virtually no input inrush current make installation and usage simple. Diagnostics are easy due to a green DC-ok LED and red overload LED. DC 24V 24 - 28V 3.4 – 3.0A 5 – 4.5A Output power 80W 120W Output ripple < 50mVpp Input voltage AC 100-240V Mains frequency 50-60Hz AC Input current 1.42 / 0.82A Power factor 0.53 / 0.47 AC Inrush current typ. 5 / 10A peak Efficiency 88.7 / 90.0% Losses 10.4 / 9.1W Temperature range -25°C to +70°C Derating 2W/°C Hold-up time typ. 41 / 174ms Dimensions 32x124x102mm continuous for typ. 4s continuous for typ. 4s 20Hz to 20MHz ±15% ±6% at 120 / 230Vac at 120 / 230Vac at 120 / 230Vac at 120 / 230Vac at 120 / 230Vac operational +60 to +70°C at 120 / 230Vac WxHxD Unique quick-connect spring-clamp terminals allow a safe and fast installation and a large international approval package for a variety of applications makes this unit suitable for nearly every situation. ORDER NUMBERS Power Supply MARKINGS QS3.241 Mechanical Accessory ZM1.WALL ZM11.SIDE UL508 UL 60950-1 Class I Div 2 Wall mount bracket Side mount bracket Marine Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 1/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series INDEX Page 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. Intended Use .......................................................3 Installation Requirements ...................................3 AC-Input...............................................................4 DC-Input...............................................................5 Input Inrush Current ...........................................5 Output .................................................................6 Hold-up Time .......................................................8 Efficiency and Power Losses................................9 Reliability ...........................................................10 Functional Diagram...........................................11 Terminals and Wiring ........................................11 Front Side and User Elements ...........................12 EMC ....................................................................13 Environment ......................................................14 Protection Features ...........................................15 Safety Features ..................................................15 Dielectric Strength ............................................15 Approvals and Fulfilled Standard .....................16 Regulatory Compliance .....................................17 Physical Dimensions and Weight ......................18 Page 21. Accessories ........................................................ 19 21.1. ZM1.WALL Wall Mounting Bracket ....... 19 21.2. ZM11.SIDE Side Mounting Bracket ........ 19 21.3. UF20.241 Buffer Module .......................... 20 21.4. YRM2.DIODE Redundancy Module.......... 20 22. Application Notes ............................................. 21 22.1. Repetitive Pulse Loading .......................... 21 22.2. Peak Current Capability ........................... 22 22.3. Back-feeding Loads .................................. 22 22.4. External Input Protection ......................... 22 22.5. Charging of Batteries ............................... 23 22.6. Parallel Use to Increase Output Power .... 23 22.7. Parallel Use for Redundancy .................... 23 22.8. Daisy Chaining of Outputs ....................... 24 22.9. Series Operation ....................................... 24 22.10. Inductive and Capacitive Loads................ 24 22.11. Operation on Two Phases ........................ 25 22.12. Use in a Tightly Sealed Enclosure ............ 25 22.13. Mounting Orientations ............................ 26 The information given in this document is correct to the best of our knowledge and experience at the time of publication. If not expressly agreed otherwise, this information does not represent a warranty in the legal sense of the word. As the state of our knowledge and experience is constantly changing, the information in this data sheet is subject to revision. We therefore kindly ask you to always use the latest issue of this document (available under www.pulspower.com). No part of this document may be reproduced or utilized in any form without our prior permission in writing. TERMINOLOGY AND ABREVIATIONS PE and symbol Earth, Ground PE is the abbreviation for Protective Earth and has the same meaning as the symbol . This document uses the term “earth” which is the same as the U.S. term “ground”. T.b.d. To be defined, value or description will follow later. AC 230V A figure displayed with the AC or DC before the value represents a nominal voltage with standard tolerances (usually ±15%) included. E.g.: DC 12V describes a 12V battery disregarding whether it is full (13.7V) or flat (10V) 230Vac A figure with the unit (Vac) at the end is a momentary figure without any additional tolerances included. 50Hz vs. 60Hz As long as not otherwise stated, AC 230V parameters are valid at 50Hz mains frequency. may A key word indicating flexibility of choice with no implied preference. shall A key word indicating a mandatory requirement. should A key word indicating flexibility of choice with a strongly preferred implementation. Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 2/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 1. INTENDED USE This device is designed for installation in an enclosure and is intended for commercial use, such as in industrial control, process control, monitoring and measurement equipment or the like. Do not use this device in equipment, where malfunctioning may cause severe personal injury or threaten human life without additional appropriate safety devices, that are suited for the end-application. If this device is used in a manner outside of its specification, the protection provided by the device may be impaired. 2. INSTALLATION REQUIREMENTS Install device in an enclosure providing protection against electrical, mechanical and fire hazards. Install the device onto a DIN-rail according to EN 60715 with the input terminals on the bottom of the device. Other mounting orientations require a reduction in output current. Make sure that the wiring is correct by following all local and national codes. Use appropriate copper cables that are designed for a minimum operating temperature of 60°C for ambient temperatures up to +45°C, 75°C for ambient temperatures up to +60°C and 90°C for ambient temperatures up to +70°C. Ensure that all strands of a stranded wire enter the terminal connection. Use ferrules for wires on the input terminals. The device is designed for pollution degree 2 areas in controlled environments. No condensation or frost is allowed. The enclosure of the device provides a degree of protection of IP20. The housing does not provide protection against spilled liquids. The device is designed for overvoltage category II zones. Below 2000m altitude the device is tested for impulse withstand voltages up to 4kV, which corresponds to OVC III according to IEC 60664-1. The device is designed as “Class of Protection I” equipment according to IEC 61140. Do not use without a proper PE (Protective Earth) connection. The device is suitable to be supplied from TN, TT or IT mains networks. The continuous voltage between the input terminal and the PE potential must not exceed 276Vac. The input can also be powered from batteries or similar DC sources. The continuous voltage between the supply voltage and the PE/ground potential must not exceed 375Vdc. A disconnecting means shall be provided for the input of the device. The device is designed for convection cooling and does not require an external fan. Do not obstruct airflow and do not cover ventilation grid! The device is designed for altitudes up to 5000m (16400ft). Above 2000m (6560ft) a reduction in output current is required. Keep the following minimum installation clearances: 40mm on top, 20mm on the bottom, 5mm left and right side. Increase the 5mm to 15mm in case the adjacent device is a heat source. When the device is permanently loaded with less than 50%, the 5mm can be reduced to zero. The device is designed, tested and approved for branch circuits up to 20A without additional protection device. If an external fuse is utilized, do not use circuit breakers smaller than 6A B- or 4A C-Characteristic to avoid a nuisance tripping of the circuit breaker. The maximum surrounding air temperature is +70°C (+158°F). The operational temperature is the same as the ambient or surrounding air temperature and is defined 2cm below the device. The device is designed to operate in areas between 5% and 95% relative humidity. WARNING Risk of electrical shock, fire, personal injury or death. - Do not use the power supply without proper grounding (Protective Earth). Use the terminal on the input block for earth connection and not one of the screws on the housing. - Turn power off before working on the device. Protect against inadvertent re-powering. - Make sure that the wiring is correct by following all local and national codes. - Do not modify or repair the unit. - Do not open the unit as high voltages are present inside. - Use caution to prevent any foreign objects from entering the housing. - Do not use in wet locations or in areas where moisture or condensation can be expected. - Do not touch during power-on, and immediately after power-off. Hot surfaces may cause burns. Notes for use in hazardous location areas: The device is suitable for use in Class I Division 2 Groups A, B, C, D locations. WARNING EXPLOSION HAZARDS! Substitution of components may impair suitability for this environment. Do not disconnect the device or operate the voltage adjustment unless power has been switched off or the area is known to be non-hazardous. Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 3/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 3. AC-INPUT AC input nom. Allowed voltage L or N to earth Input frequency Turn-on voltage Shut-down voltage max. nom. typ. typ. AC 100-240V 85-276Vac 60-85Vac 276-300Vac 276Vac 50–60Hz 61Vac 58Vac Input current Power factor *) Crest factor **) Start-up delay Rise time typ. typ. typ. typ. typ. typ. max. AC 100V 1.67A 0.55 3.33 360ms 6ms 20ms 100mV Turn-on overshoot suitable for TN-, TT- and IT mains networks continuous operation full power for 200ms, no damage between 0 and 85Vac < 500ms continuous, IEC 62103 ±6% steady-state value, see Fig. 3-1 steady-state value, see Fig. 3-1 AC 120V 1.42A 0.53 3.9 350ms 5ms 20ms 100mV AC 230V 0.82A 0.47 3.88 330ms 7ms 22ms 100mV at 24V, 3.4A, see Fig. 3-3 at 24V, 3.4A, see Fig. 3-4 at 24V, 3.4A see Fig. 3-2 0mF, 24V, 3.4A, see Fig. 3-2 3.4mF, 24V, 3.4A, see Fig. 3-2 see Fig. 3-2 *) The power factor is the ratio of the true (or real) power to the apparent power in an AC circuit. **) The crest factor is the mathematical ratio of the peak value to RMS value of the input current waveform. Rated input range Shut-down full power for 200ms max. 500ms Turn-on POUT Fig. 3-2 Turn-on behavior, definitions 60V - 5% Output Voltage VIN Start-up delay Rise Time 276V 300Vac 85V Fig. 3-3 Input current vs. output load at 24V 1.8A Input Voltage Overshoot Fig. 3-1 Input voltage range Input Current, typ. c Va 0 10 Vac 120 1.5 1.2 c 0Va 0.9 23 0.6 Fig. 3-4 Power factor vs. output load Power Factor, typ. 0.6 Vac 0.55 100 ac 0.5 120V 0.45 230Vac 0.4 0.3 Output Current 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5A Output Current 0.35 0.5 1.0 1.5 2.0 2.5 3.0 3.5A Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 4/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 4. DC-INPUT DC input DC input range DC input current Allowed Voltage L/N to Earth Turn-on voltage Shut-down voltage nom. typ. max. typ. typ. DC 110-300V 88-375Vdc 0.8A / 0.29A 375Vdc 61Vdc 47Vdc Instructions for DC use: a) Use a battery or similar DC source. For other sources contact PULS b) Connect +pole to L and –pole to N. c) Connect the PE terminal to a earth wire or to the machine ground. Fig. 4-1 Wiring for DC Input Battery + Power Supply AC L N PE - + - -20%/+25% continuous operation 110Vdc / 300Vdc, at 24V, 3.4A IEC 62103 steady state value steady state value Load DC 5. INPUT INRUSH CURRENT An active inrush limitation circuit limits the input inrush current after turn-on of the input voltage and after short input voltage interruptions. The charging current into EMI suppression capacitors is disregarded in the first microseconds after switch-on. Inrush current Inrush energy max. typ. max. AC 100V 6Apeak 4.5Apeak 2A2s AC 120V 7Apeak 5Apeak 2A2s AC 230V 13Apeak 10Apeak 2A2s over entire temperature range over entire temperature range over entire temperature range Fig. 5-1 Input inrush current, typical behavior Input: Output: Ambient: Upper curve: Middle curve: Lower curve: Time basis: 230Vac 24V, 3.4A 25°C Input current 5A / DIV Input voltage 500V / DIV Output voltage 20V / DIV 100ms / DIV Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 5/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 6. OUTPUT Output voltage Adjustment range Factory setting Line regulation Load regulation Ripple and noise voltage Output current Output power BonusPower® time BonusPower® recovery time Overload behaviour Short-circuit current Output capacitance *) **) ***) nom. max. typ. max. max. max. nom. nom. nom. 24V 24-28V 30V ***) 24.1V 10mV 100mV 50mVpp 3.4A 3A 5A *) nom. 4.5A *) nom. nom. typ. min. max. typ. 80W / 84W 120W / 126W *) 4s 3s 5s 7s cont. current 3.5A **) 4.2A **) 5.2A **) 6.0A **) 6.0A **) 1 500µF min. max. min. max. max. typ. guaranteed at clockwise end position of potentiometer ±0.2%, at full load, cold unit 60-300Vac static value, 0A  3.4A 20Hz to 20MHz, 50Ohm continuously available at 24V, see Fig. 6-1 continuously available at 28V, see Fig. 6-1 short term available BonusPower® *), at 24V, for typical 4s, see Fig. 6-1 short term available BonusPower® *), at 28V, for typical 4s, see Fig. 6-1 continuously available at 24V / 28V short term available BonusPower® *) at 24V / 28V duration until the output voltage dips, see Fig. 6-2 overload free time to reset power manager, see Fig. 6-3 continuous, load impedance 25mOhm, see Fig. 6-1 continuous, load impedance 25mOhm, see Fig. 6-1 during BonusPower® *), load impedance 25mOhm during BonusPower® *), load impedance 25mOhm continuous, load impedance 90% of the adjusted output voltage E Overload LED (red) On, when the voltage on the output terminals is 2000m (6500ft), see Fig. 14-2 IEC 62103, EN 50178, altitudes up to 2000m altitudes from 2000m to 6000m IEC 62103, EN 50178, not conductive 5W/1000m or 5°C/1000m III II 2 Degree of pollution *) Operational temperature is the same as the ambient temperature and is defined as the air temperature 2cm below the unit. **) Do not energize while condensation is present Fig. 14-1 Output current vs. ambient temp. Fig. 14-2 Output current vs. altitude Allowed Output Wattage at 24V Allowed Output Wattage at 24V 120W 120W for typ. 4s 100 80 80 continuous 60 60 40 40 20 20 Ambient Temperature 0 -25 0 20 40 for typ. 4s 100 continuous A... Tamb < 60°C B... Tamb < 50°C C... Tamb < 40°C 0 60 70°C A 0 2000 B C Altitude 4000 6000m Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 14/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 15. PROTECTION FEATURES Output protection Output over-voltage protection Electronically protected against overload, no-load and short-circuits *) typ. 34Vdc In case of an internal power supply defect, a redundant max. 36Vdc circuit limits the maximum output voltage. The output shuts down and automatically attempts to restart. IP 20 EN/IEC 60529 > 3.5mm e.g. screws, small parts yes Output shut-down with automatic restart MOV (Metal Oxide Varistor) T4A H.B.C. not user replaceable Degree of protection Penetration protection Over-temperature protection Input transient protection Internal input fuse *) In case of a protection event, audible noise may occur. 16. SAFETY FEATURES Input / output separation *) Class of protection Isolation resistance PE resistance Touch current (leakage current) *) SELV PELV I > 5MOhm < 0.1Ohm typ. 0.11mA / 0.26mA typ. 0.15mA / 0.38mA typ. 0.25mA / 0.63mA < 0.14mA / 0.31mA < 0.20mA / 0.46mA < 0.35mA / 0.8mA IEC/EN 60950-1 IEC/EN 60204-1, EN 50178, IEC 62103, IEC 60364-4-41 PE (Protective Earth) connection required input to output, 500Vdc 100Vac, 50Hz, TN-,TT-mains / IT-mains 120Vac, 60Hz, TN-,TT-mains / IT-mains 230Vac, 50Hz, TN-,TT-mains / IT-mains 110Vac, 50Hz, TN-,TT-mains / IT-mains 132Vac, 60Hz, TN-,TT-mains / IT-mains 264Vac, 50Hz, TN-,TT-mains / IT-mains double or reinforced insulation 17. DIELECTRIC STRENGTH The output voltage is floating and has no ohmic connection to the ground. Type and factory tests are conducted by the manufacturer. Field tests may be conducted in the field using the appropriate test equipment which applies the voltage with a slow ramp (2s up and 2s down). Connect all input-terminals together as well as all output poles before conducting the test. When testing, set the cut-off current settings to the value in the table below. Type test 60s A 2500Vac B 3000Vac C 500Vac Factory test 5s 2500Vac 2500Vac 500Vac Field test 5s 2000Vac 2000Vac 500Vac > 4mA > 4mA > 4mA Fig. 17-1 Dielectric strength Input L N B Output A Earth, PE + C - Cut-off current setting To fulfil the PELV requirements according to EN60204-1 § 6.4.1, we recommend that either the + pole, the – pole or any other part of the output circuit shall be connected to the protective earth system. This helps to avoid situations in which a load starts unexpectedly or can not be switched off when unnoticed earth faults occur. Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 15/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 18. APPROVALS AND FULFILLED STANDARD UL Certificate Listed equipment for category NMTR - Industrial Control Equipment Applicable for US and Canada E-File: E198865 CB Scheme Certificate General safety requirements for Information Technology Equipment (ITE) UL 508 IEC 60950-1 UL 60950-1 ANSI / ISA 12.12.012007 (Class I Div 2) Marine Marine SEMI F47 Corrosion IEC 60068-2-60 Method 4 Corrosion G3-ISA-71.04 VDMA 24364 LABS VDMA 24364-C1-L/W UL Certificate Recognized component for category QQGQ - Information Technology Equipment (ITE) Applicable for US and Canada E-File: E137006 CSA Certificate Power Supplies for Hazardous Location Applicable for Canada and US CSA Class: 5318-01 (Canada), 5318-81 (USA) Temperature Code: T4 Groups: A, B, C and D DNV-GL Certificate DNV-GL Type approved product Certificate: TAA00002JT Temperature: Class D Humidity: Class B Vibration: Class C EMC: Class A Enclosure: Class A ABS Design Assessment Certificate ABS (American Bureau of Shipment) assessed product Certificate: 17-HG1599236-PDA Test Report Voltage Sag Immunity for Semiconductor Processing Equipment Tested for AC 120V and 208V L-L or L-N mains voltages, nominal output voltage and nominal output load Manufacturer's Declaration (Online Document) IEC 60068-2-60 - Environmental Tests, Flowing Mixed Gas Corrosion Test Test Ke - Method 4 H2S: 10ppb NO2: 200ppb Cl2: 10ppb SO2: 200ppb Test Duration: 3 weeks, which simulates a service life of at least 10 years Manufacturer's Declaration (Online Document) Airborne Contaminants Corrosion Test Severity Level: G3 Harsh H2S: 100ppb NOx: 1250ppb Cl2: 20ppb SO2: 300ppb Test Duration: 3 weeks, which simulates a service life of at least 10 years. Paint Wetting Impairment Substances Test (or LABS-Test) Tested for Zone 2 and test class C1 according to VDMA 24364-C1-L/W for solvents and water-based paints Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 16/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 19. REGULATORY COMPLIANCE EU Declaration of Conformity The CE mark indicates conformance with the - EMC directive - Low-voltage directive (LVD) - RoHS directive Manufacturer's Statement EU-Directive regarding the Registration, Evaluation, Authorisation and Restriction of Chemicals Registration for the Eurasian Customs Union market (Russia, Kazakhstan, Belarus) REACH Directive EAC TR Registration IEC 61558-2-16 (Annex B) Safety Isolation Transformer Test Certificate IEC 61558-2-16 - Safety of transformers, reactors, power supply units and similar products for supply voltages up to 1100 V Particular requirements and tests for switch mode power supply units and transformers for switch mode power supply units Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 17/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 20. PHYSICAL DIMENSIONS AND WEIGHT Weight DIN-Rail Installation Clearances 440g / 0.97lb Use 35mm DIN-rails according to EN 60715 or EN 50022 with a height of 7.5 or 15mm. The DIN-rail height must be added to the unit depth (102mm) to calculate the total required installation depth. See chapter 2 Fig. 21-1 Front view Fig. 21-2 Side view Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 18/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 21. ACCESSORIES 21.1. ZM1.WALL WALL MOUNTING BRACKET This bracket is used to mount the power supply onto a flat surface without utilizing a DIN-Rail. 21.2. ZM11.SIDE SIDE MOUNTING BRACKET This bracket is used to mount Dimension units sideways with or without utilizing a DIN-Rail. The two aluminum brackets and the black plastic slider of the unit have to be detached, so that the steel brackets can be mounted. For sideway DIN-rail mounting, the removed aluminum brackets and the black plastic slider need to be mounted on the steel bracket. Side mounting with DIN-rail brackets Side mounting without DIN-rail brackets Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 19/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 21.3. UF20.241 BUFFER MODULE This buffer unit is a supplementary device for DC 24V power supplies. It delivers power to bridge typical mains failures or extends the hold-up time after turn-off Buffer Power of the AC power. In times when the power Load AC Unit(s) Supply supply provides sufficient voltages, the buffer unit stores energy in integrated + DC electrolytic capacitors. In case of mains voltage fault, this energy is released again in a regulated process. One buffer module can deliver 20A additional current. The buffer unit does not require any control wiring. It can be added in parallel to the load circuit at any given point. Buffer units can be added in parallel to increase the output ampacity or the hold-up time. 21.4. YRM2.DIODE REDUNDANCY MODULE The YRM2.DIODE is a dual redundancy module, which has two diodes as decoupling devices included. It can be used for various purposes. The most popular application is to configure highly reliable and true redundant power supply systems. Another interesting application is the separation of sensitive loads from nonsensitive loads. This avoids the distortion of the power quality for the sensitive loads which can cause controller failures. Failure Monitor ++ -- 24V,3.4A QS3.241 Power Supply L N PE + - + IN 1 IN 2 ++ IN 1 IN 2 YRM2.DIODE Redundancy Module Output + - -- 24V,3.4A QS3.241 Power Supply L N PE optional I I 24V,3.4A Load L N PE Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 20/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 22. APPLICATION NOTES 22.1. REPETITIVE PULSE LOADING Typically, a load current is not constant and varies over time. This power supply is designed to support loads with a higher short-term power demand (=BonusPower®). The short-term duration is hardware controlled by an output power manager and is available on a repeated basis. If the BonusPower® load lasts longer than the hardware controller allows it, the output voltage will dip and the next BonusPower® is available after the BonusPower® recovery time (see chapter 6) has elapsed. To avoid this, the following rules must be met: a) The power demand of the pulse must be below 150% of the nominal output power. b) The duration of the pulse power must be shorter than the allowed BonusPower® time. (see output section) c) The average (R.M.S.) output current must be below the specified continuous output current. If the R.M.S. current is higher, the unit will respond with a thermal shut-down after a period of time. Use the maximum duty cycle curve (Fig. 23-2) to check if the average output current is below the nominal current. Fig. 23-1 Repetitive pulse loads, definitions Fig. 23-2 Max. duty cycle curve 1.0 PPEAK TPEAK DutyCycle max. 150% 0.6 100% 0.4 P0 P0 = 100% 0.2 0 100 P0 PPEAK T0 TPEAK Example: P0 = 10% P0 = 50% P0 = 75% 0.8 T0 Base load (W) Pulse load (above 100%) Duration between pulses (s) Pulse duration (s) 110 DutyCycle = T0 = 120 130 PPEAK 140 150% Tpeak Tpeak + T0 Tpeak - (DutyCycle x Tpeak) DutyCycle A load is powered continuously with 40W (= 50% of the rated output load). From time to time a peak power of 120W (= 150% of the rated output load) is needed for 1 second. The question is: How often can this pulse be supplied without overloading the power supply? - Make a vertical line at PPEAK = 150% and a horizontal line where the vertical line crosses the P0 = 50% curve. Read the max. duty cycle from the duty cycle-axis (= 0.37) - Calculate the required pause (base load) length T0: - Result: The required pause length = 1.7s T0= - Max. repetition rate = pulse +pause length = 2.7s Tpeak - (DutyCycle x Tpeak) DutyCycle = 1s - (0.37 x 1s) 0.37 = 1.7s More examples for pulse load compatibility: PPEAK 120W 120W 100W P0 80W 0W 40W TPEAK 1s 1s 1s T0 >25s >1.3s > 0.75s PPEAK 120W 120W 120W P0 40W 40W 40W TPEAK 0.1s 1s 3s T0 >0.16s >1.6s >4.9s Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 21/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 22.2. PEAK CURRENT CAPABILITY Solenoids, contactors and pneumatic modules often have a steady state coil and a pick-up coil. The inrush current demand of the pick-up coil is several times higher than the steady-state current and usually exceeds the nominal output current (including the PowerBoost). The same situation applies when starting a capacitive load. Branch circuits are often protected with circuit breakers or fuses. In case of a short or an overload in the branch circuit, the fuse needs a certain amount of over-current to trip or to blow. The peak current capability ensures the safe operation of subsequent circuit breakers. Assuming the input voltage is turned on before such an event, the built-in large sized output capacitors inside the power supply can deliver extra current. Discharging this capacitor causes a voltage dip on the output. The following two examples show typical voltage dips: Fig. 23-3 Peak load with 2x the nominal current for 50ms, typ. Peak load 6.8A (resistive) for 50ms Output voltage dips from 24V to 18.5V. Fig. 23-4 Peak load with 4x the nominal current for 5ms, typ. Peak load 13.5A (resistive) for 5ms Output voltage dips from 24V to 7.5V. 22.3. BACK-FEEDING LOADS Loads such as decelerating motors and inductors can feed voltage back to the power supply. This feature is also called return voltage immunity or resistance against Back- E.M.F. (Electro Magnetic Force). This power supply is resistant and does not show malfunctioning when a load feeds back voltage to the power supply. It does not matter whether the power supply is on or off. The maximum allowed feed-back-voltage is 35Vdc. The absorbing energy can be calculated according to the built-in large sized output capacitor which is specified in chapter 6. 22.4. EXTERNAL INPUT PROTECTION The unit is tested and approved for branch circuits up to 20A. An external protection is only required if the supplying branch has an ampacity greater than this. Check also local codes and local requirements. In some countries local regulations might apply. If an external fuse is necessary or utilized, minimum requirements need to be considered to avoid nuisance tripping of the circuit breaker. A minimum value of 6A B- or 6A C-Characteristic breaker should be used Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 22/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 22.5. CHARGING OF BATTERIES The power supply can be used to charge lead-acid or maintenance free batteries. (Two 12V batteries in series) Instructions for charging batteries: a) Set output voltage (measured at no load and at the battery end of the cable) very precisely to the end-of-charge voltage. End-of-charge voltage 27.8V 27.5V 27.15V 26.8V Battery temperature 10°C 20°C 30°C 40°C b) Use a 15A or 16A circuit breaker (or blocking diode) between the power supply and the battery. c) Ensure that the output current of the power supply is below the allowed charging current of the battery. d) Use only matched batteries when putting 12V types in series. e) The return current to the power supply (battery discharge current) is typ. 6.3mA when the power supply is switched off (except in case a blocking diode is utilized). 22.6. PARALLEL USE TO INCREASE OUTPUT POWER Unit A Power supplies from the same series (Q-Series) can be paralleled to increase the output power. The output voltage shall be adjusted to the same value (±100mV) with the same load conditions on all units, or the units can be left with the factory settings. AC + - DC If more than three units are connected in parallel, a fuse or circuit breaker with a rating of 4A or 6A is required on each output. Alternatively, a diode or redundancy module can also be utilized. + Unit B Load AC + - - Keep an installation clearance of 15mm (left / right) between two power DC supplies and avoid installing the power supplies on top of each other. Do not use power supplies in parallel in mounting orientations other than the standard mounting orientation (input terminals on bottom and output terminals on the top of the unit) or in any other condition where a derating of the output current is required (e.g. altitude, above 60°C, …). Pay attention that leakage current, EMI, inrush current, harmonics will increase when using multiple power supplies. 22.7. PARALLEL USE FOR REDUNDANCY Power supplies can be paralleled for redundancy to gain higher system availability. Redundant systems require a certain amount of extra power to support the load in case one power supply unit fails. The simplest way is to put two power supplies in parallel. This is called a 1+1 redundancy. In case one power supply unit fails, the other one is automatically able to support the load current without any interruption. Redundant systems for a higher power demand are usually built in a N+1 method. E.g. five power supplies, each rated for 3.4A are paralleled to build a 13.6A redundant system. For N+1 redundancy the same restrictions apply as for increasing the output power, see also section 23.6. Please note: This simple way to build a redundant system does not cover failures such as an internal short circuit in the secondary side of the power supply. In such a case, the defective Failure Monitor ++ -- 24V,3.4A QS3.241 Power Supply L N PE + - + IN 1 IN 2 ++ IN 1 IN 2 YRM2.DIODE Redundancy Module Output + - -- 24V,3.4A QS3.241 Power Supply L N PE optional I I 24V,3.4A Load L N PE Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 23/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series unit becomes a load for the other power supplies and the output voltage can not be maintained any more. This can be avoided by utilizing decoupling diodes which are included in the redundancy module YRM2.DIODE. Recommendations for building redundant power systems: a) b) c) Use separate input fuses for each power supply. Monitor the individual power supply units. Therefore, use the Input-OK relay contact of the YRM2.DIODE redundancy module. It is desirable to set the output voltages of all units to the same value (± 100mV) or leave it at the factory setting. 22.8. DAISY CHAINING OF OUTPUTS Daisy chaining (jumping from one power supply output to the next) is allowed as long as the average output current through one terminal pin does not exceed 13A. If the current is higher, use a separate distribution terminal block as shown in Fig. 23-6. Fig. 23-5 Daisy chaining of outputs Fig. 23-6 Using distribution terminals max 13A! Output + + - - Output + + - - + - Load Output + + - - Output + + - - Power Supply Power Supply Power Supply Power Supply Input Input Input Input 22.9. SERIES OPERATION - + Load Distribution Terminals Unit A AC Power supplies of the same type can be connected in series for higher output voltages. It is possible to connect as many units in series as needed, providing the sum of the output voltage does not exceed 150Vdc. Voltages with a potential above 60Vdc are not SELV any more and can be dangerous. Such voltages must be installed with a protection against touching. DC + + Unit B AC Earthing of the output is required when the sum of the output voltage is above 60Vdc. DC Avoid return voltage (e.g. from a decelerating motor or battery) which is applied to the output terminals. Load + - Earth (see notes) Keep an installation clearance of 15mm (left / right) between two power supplies and avoid installing the power supplies on top of each other. Do not use power supplies in series in mounting orientations other than the standard mounting orientation (input terminals on bottom and output terminals on the top of the unit). Pay attention that leakage current, EMI, inrush current, harmonics will increase when using multiple power supplies. 22.10. INDUCTIVE AND CAPACITIVE LOADS The unit is designed to supply any kind of loads, including unlimited capacitive and inductive loads. Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 24/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 22.11. OPERATION ON TWO PHASES Power Supply L1 240V +15% max. The power supply can also be used on two-phases of a three-phase-system. Such a phase-to-phase connection is allowed as long as the supplying voltage is below 240V+15%. Use a fuse or a circuit breaker to protect the N input. The N input is internally not protected and is in this case connected to a hot wire. Appropriate fuses or circuit breakers are specified in section 23.4 “External Input Protection”. L3 AC L Fuse L2 internal fuse N PE DC 22.12. USE IN A TIGHTLY SEALED ENCLOSURE When the power supply is installed in a tightly sealed enclosure, the temperature inside the enclosure will be higher than outside. In such situations, the inside temperature defines the ambient temperature for the power supply. The following measurement results can be used as a reference to estimate the temperature rise inside the enclosure. The power supply is placed in the middle of the box, no other heat producing items are inside the box Enclosure: Load: Input: Temperature inside enclosure: Temperature outside enclosure: Temperature rise: Rittal Typ IP66 Box PK 9516 100, plastic, 110x180x165mm 24V, 3.4A; (=100%) load is placed outside the box 230Vac 41.3°C (in the middle of the right side of the power supply with a distance of 2cm) 25.1°C 16.2K Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 25/26 QS3.241 24V, 3.4A, SINGLE PHASE INPUT Q-Series 22.13. MOUNTING ORIENTATIONS Mounting orientations other than input terminals on the bottom and output on the top require a reduction in continuous output power or a limitation in the maximum allowed ambient temperature. The amount of reduction influences the lifetime expectancy of the power supply. Therefore, two different derating curves for continuous operation can be found below: Curve A1 Curve A2 Recommended output current. Max allowed output current (results in approximately half the lifetime expectancy of A1). Fig. 23-7 Mounting Orientation A (Standard orientation) Output Current OUTPUT 3.5A 2.8 2.1 1.4 0.7 0 10 Power Supply INPUT Fig. 23-8 Mounting Orientation B (Upside down) 20 30 40 50 60°C INPUT 3.5A 2.8 2.1 1.4 0.7 0 10 A2 A1 Ambient Temperature 20 30 50 40 60°C Power Supply OUTPUT Output Current 3.5A 2.8 2.1 1.4 0.7 0 10 A2 A1 Ambient Temperature 20 30 40 50 60°C Output Current OUTPUT Power Supply INPUT 3.5A 2.8 2.1 1.4 0.7 0 10 A2 A1 Ambient Temperature 20 30 50 40 60°C INPUT Power Supply Output Current OUTPUT Fig. 23-11 Mounting Orientation E (Horizontal ccw) Ambient Temperature Output Current Fig. 23-9 Mounting Orientation C (Table-top mounting) Fig. 23-10 Mounting Orientation D (Horizontal cw) A1 3.5A 2.8 2.1 1.4 0.7 0 10 A2 A1 Ambient Temperature 20 30 40 50 60°C Jul. 2020 / Rev. 2.3 DS-QS3.241-EN All parameters are specified at 24V, 3.4A, 230Vac, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 26/26
QS3.241 价格&库存
很抱歉,暂时无法提供与“QS3.241”相匹配的价格&库存,您可以联系我们找货
QS3.241
    • 1+1876.189121+243.81556
