CP10.121
CP10.121
    PULS
    AC/DCCONVERTER12V240W
CP10.121 数据手册
CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series POWER SUPPLY ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ AC 100-240V Wide-range Input Width only 39mm Efficiency up to 94.3% Excellent Partial Load Efficiency 20% Output Power Reserves (PowerBoost) Safe HiccupPLUS Overload Mode Easy Fuse Breaking due to High Overload Peak Current Active Power Factor Correction (PFC) Minimal Inrush Current Surge Full Power Between -25°C and +60°C Remote ON / OFF Function DC-OK Relay Contact 3 Year Warranty PRODUCT DESCRIPTION SHORT-FORM DATA The DIMENSION CP-Series units are high-end power supplies in a medium price range without compromising quality, reliability and performance. The CP-Series is part of the DIMENSION power supply family. The most outstanding features of CP10 are the high efficiency, advanced inrush current limitation, active PFC and the wide operational temperature range. Output voltage Adjustment range Output current The CP-Series includes all the essential basic functions. The devices also offer PowerBoost: Power reserves of 20%, which may even be used continuously at temperatures up to +45°C.. Additionally, the CP10 can deliver three times the nominal output current for at least 12ms which helps to trip fuses on faulty output branches. High immunity to transients and power surges as well as low electromagnetic emission, a shut-down input, a DC-OK relay contact and a large international approval package for a variety of applications makes this unit suitable for nearly every situation. ORDER NUMBERS Power Supply Accessory CP10.121 PowerBoost Input voltage AC Mains frequency Input current AC Power factor Input voltage DC Input current DC Input inrush current Efficiency Losses Hold-up time Temperature range Size (w x h x d) Weight DC 12V Nominal 12 - 15Vdc Factory setting 12.0V 16.0 – 12.8A Up to +60°C ambient 12.0 – 9.6A At +70°C ambient Derate linearly between +60°C and +70°C 19.2A Up to +45°C ambient Linear decrease to nominal power between +45°C and +60°C AC 100-240V -15% / +10% 50-60Hz ±6% 1.74 / 0.92A At 120 / 230Vac 0.99 / 0.96 At 120 / 230Vac DC 110-150V ±20% For CP10.121 DC 110-300V ±20% For CP10.122 1.90A At 110Vdc 1.38A At 150Vdc 0.68A At 300Vdc 6 / 9A pk At 120 / 230Vac, 40°C 92.8 / 94.3% At 120 / 230Vac 14.9 / 11.6W At 120 / 230Vac 50ms -25°C to +70°C 39x124x117mm Without DIN rail 600g MAIN APPROVALS CP10.122 Standard unit (preferred item) With extended DC-input ZM10.WALL ZM12.SIDE Wall/panel mount bracket Side mount bracket For details and a the complete approval list, see chapter 21. UL 61010-2-201 UL 60950-1 ATEX IECEx Class I Div 2 Marine Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 1/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series INDEX Page 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. Intended Use .....................................................................3 Installation Instruction.......................................................3 AC-Input.............................................................................5 DC-Input ............................................................................6 Input Inrush Current ..........................................................7 Output ...............................................................................8 Hold-up Time .....................................................................9 DC-OK Relay Contact .......................................................10 Remote ON / OFF Function ..............................................10 Efficiency and Power Losses ............................................11 Lifetime Expectancy .........................................................12 MTBF ...............................................................................12 Functional Diagram..........................................................13 Terminals and Wiring.......................................................14 Front Side and User Elements..........................................15 EMC .................................................................................16 Environment ....................................................................17 Protection Features .........................................................18 Safety Features ................................................................18 Dielectric Strength ...........................................................19 Approved, Fulfilled or Tested Standards..........................20 Page 22. Regulatory Product Compliance ......................................22 23. Physical Dimensions and Weight .....................................23 24. Accessories ......................................................................24 24.1. ZM10.WALL - Wall/Panel Mount Bracket ............. 24 24.2. ZM12.SIDE - Side Mounting Bracket ..................... 25 24.3. YR40.242 - Redundancy Module .......................... 25 25. Application Notes ............................................................26 25.1. Peak Current Capability ........................................ 26 25.2. Back-feeding Loads ............................................... 27 25.3. External Input Protection ..................................... 27 25.4. Output Circuit Breakers ........................................ 27 25.5. Parallel Use to Increase Output Power................. 28 25.6. Parallel Use for Redundancy ................................ 28 25.7. Series Operation ................................................... 29 25.8. Inductive and Capacitive Loads ............................ 29 25.9. Charging of Batteries ............................................ 29 25.10. Operation on Two Phases..................................... 30 25.11. Use in a Tightly Sealed Enclosure ......................... 30 25.12. Mounting Orientations ......................................... 31 The information given in this document is correct to the best of our knowledge and experience at the time of publication. If not expressly agreed otherwise, this information does not represent a warranty in the legal sense of the word. As the state of our knowledge and experience is constantly changing, the information in this data sheet is subject to revision. We therefore kindly ask you to always use the latest issue of this document (available under www.pulspower.com). No part of this document may be reproduced or utilized in any form without our prior permission in writing. TERMINOLOGY AND ABREVIATIONS PE and symbol PE is the abbreviation for Protective Earth and has the same meaning as the symbol . Earth, Ground This document uses the term “earth” which is the same as the U.S. term “ground”. t.b.d. To be defined, value or description will follow later. AC 230V A figure displayed with the AC or DC before the value represents a nominal voltage with standard tolerances (usually ±15%) included. E.g.: DC 12V describes a 12V battery disregarding whether it is full (13.7V) or flat (10V) 230Vac A figure with the unit (Vac) at the end is a momentary figure without any additional tolerances included. 50Hz vs. 60Hz As long as not otherwise stated, AC 100V and AC 230V parameters are valid at 50Hz mains frequency. AC 120V parameters are valid for 60Hz mains frequency. may A key word indicating flexibility of choice with no implied preference. shall A key word indicating a mandatory requirement. should A key word indicating flexibility of choice with a strongly preferred implementation. Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 2/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 1. INTENDED USE This device is designed for installation in an enclosure and is intended for commercial use, such as in industrial control, process control, monitoring and measurement equipment or the like. Do not use this device in equipment, where malfunctioning may cause severe personal injury or threaten human life without additional appropriate safety devices, that are suited for the application. If this device is used in a manner outside of its specification, the protection provided by the device may be impaired. 2. INSTALLATION INSTRUCTION WARNING - Risk of electrical shock, fire, personal injury or death. Turn power off before working on the device and protect against inadvertent re-powering. Do not open, modify or repair the device. Use caution to prevent any foreign objects from entering into the housing. Do not use in wet locations or in areas where moisture or condensation can be expected. Do not touch during power-on, and immediately after power-off. Hot surface may cause burns. Obey the following installation instructions: This device may only be installed and put into operation by qualified personnel. This device does not contain serviceable parts. The tripping of an internal fuse is caused by an internal defect. If damage or malfunction should occur during installation or operation, immediately turn power off and send unit to the factory for inspection. Install device in an enclosure providing protection against electrical, mechanical and fire hazards. Install the device onto a DIN rail according to EN 60715 with the input terminals on the bottom of the device. Other mounting orientations require a reduction in output current. Make sure that the wiring is correct by following all local and national codes. Use appropriate copper cables that are designed for a minimum operating temperature of 60°C for ambient temperatures up to +45°C, 75°C for ambient temperatures up to +60°C and 90°C for ambient temperatures up to +70°C. Ensure that all strands of a stranded wire enter the terminal connection. Use ferrules for wires on the input terminals. Unused screw terminals should be securely tightened. The device is designed for pollution degree 2 areas in controlled environments. No condensation or frost is allowed. The enclosure of the device provides a degree of protection of IP20. The enclosure does not provide protection against spilled liquids. The isolation of the device is designed to withstand impulse voltages of overvoltage category III according to IEC 60664-1. The device is designed as “Class of Protection I” equipment according to IEC 61140. Do not use without a proper PE (Protective Earth) connection. The device is suitable to be supplied from TN, TT or IT mains networks. The continuous voltage between the input terminal and the PE potential must not exceed 300Vac. The input can also be powered from batteries or similar DC sources. The continuous voltage between the supply voltage and the PE/ground potential must not exceed 375Vdc. A disconnecting means shall be provided for the input of the device. The device is designed for convection cooling and does not require an external fan. Do not obstruct airflow and do not cover ventilation grid! The device is designed for altitudes up to 5000m. Above 2000m a reduction in output current and over voltage category is required. Keep the following minimum installation clearances: 40mm on top, 20mm on the bottom, 5mm left and right side. Increase the 5mm to 15mm in case the adjacent device is a heat source. When the device is permanently loaded with less than 50%, the 5mm can be reduced to zero. Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 3/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series The device is designed, tested and approved for branch circuits up to 32A (IEC) and 30A (UL) without additional protection device. If an external fuse is utilized, do not use circuit breakers smaller than 6A B- or C-Characteristic to avoid a nuisance tripping of the circuit breaker. The maximum surrounding air temperature is +70°C. The operational temperature is the same as the ambient or surrounding air temperature and is defined 2cm below the device. The device is designed to operate in areas between 5% and 95% relative humidity. Installation Instructions for Hazardous Location Areas The device is suitable for use in Class I Division 2 Groups A, B, C, D locations and for use in Group II Category 3 (Zone 2) environments. Classification: ATEX: EPS 15 ATEX 1 101 X, II 3G EX ec nC IIC T4 Gc / IECEx EPS 15.0079X WARNING EXPLOSION HAZARDS! Use only in standard vertical mounting orientation with the input terminals on bottom of the unit. Substitution of components may impair suitability for this environment. Do not disconnect the device or operate the voltage adjustment unless power has been switched off or the area is known to be nonhazardous. A suitable enclosure must be provided for the end product, which has a minimum protection of IP54 and fulfils the requirements of the EN 60079-0. Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 4/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 3. AC-INPUT AC input AC input range Nom. Suitable for TN-, TT- and IT mains networks Max. AC 100-240V 85-264Vac 264-300Vac 300Vac Allowed voltage L or N to earth Input frequency Turn-on voltage Shut-down voltage Nom. Typ. Typ. Typ. 50–60Hz 80Vac 70Vac 55Vac ±6% Steady-state value, see Fig. 3-1 Steady-state value, see Fig. 3-1 Dynamic value (250ms) External input protection See recommendations in chapter 25.3. Input current Power factor*) Crest factor**) Start-up delay Rise time Typ. Typ. Typ. Typ. Typ. AC 100V 2.11A 0.99 1.5 300ms 18ms AC 120V 1.74A 0.99 1.65 290ms 18ms AC 230V 0.92A 0.96 1.65 240ms 18ms Typ. 35ms 35ms 35ms Max. 200mV 200mV 200mV Turn-on overshoot For maximal 500ms Continuous, according to IEC 62103 At 12V, 16A, see Fig. 3-3 At 12V, 16A, see Fig. 3-4 At 12V, 16A See Fig. 3-2 At 12V, 16A const. current load, 0mF load capacitance, see Fig. 3-2 At 12V, 16A const. current load, 16mF load capacitance, see Fig. 3-2 See Fig. 3-2 *) The power factor is the ratio of the true (or real) power to the apparent power in an AC circuit. **) The crest factor is the mathematical ratio of the peak value to RMS value of the input current waveform. Fig. 3-1 Input voltage range Turn-on Shut -dow n max. 500ms Input Voltage - 5% Output Voltage VIN 85V Start-up delay Overshoot Rated input range POUT Fig. 3-2 Turn-on behavior, definitions Rise Time 264V 300Vac Fig. 3-3 Input current vs. output current at 12V output voltage Input Current, typ. Fig. 3-4 Power factor vs. output current at 12V output voltage Power Factor, typ. 3A 1.0 2.5 a) 100Vac b) 120Vac c) 230Vac 2.0 1.5 1.0 (b) 0.9 (a) 100Vac, (b) 120Vac, (c) 230Vac 0.85 (c) (c) 0.8 0.5 Output Current 0 0 (a) 0.95 (a) (b) 2 4 6 8 10 12 14 16 18 20A Output Current 0.75 2 4 6 8 10 12 14 16 18 20A Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 5/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 4. DC-INPUT Input voltage DC Nom. Nom. DC 110-150V ±20% DC 110-300V ±20% 88-180Vdc 88-360Vdc For CP10.121 For CP10.122 For CP10.121 For CP10.122 Typ. Typ. Typ. Max. Typ. Typ. typ. 1.90A 1.38A 0.68A 375Vdc 80Vdc 70Vdc 55Vac At 110Vdc, 12V, 16A At 150Vdc, 12V, 16A At 300Vdc, 12V, 16A Continuous, according to IEC 62477-1 Steady state value Steady state value Dynamic value (250ms) Input voltage range DC DC input current Allowed voltage L/N to earth Turn-on voltage Shut-down voltage Fig. 4-1 Wiring for DC Input Battery + Power Supply AC L N PE - + Load Instructions for DC use: a) Use a battery or a similar DC source. A supply from the intermediate DC-bus of a frequency converter is not recommended and can cause a malfunction or damage the unit. b) Connect +pole to L and –pole to N. c) Connect the PE terminal to an earth wire or to the machine ground. DC Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 6/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 5. INPUT INRUSH CURRENT An active inrush limitation circuit (NTCs, which are bypassed by a relay contact) limits the input inrush current after turn-on of the input voltage. The charging current into EMI suppression capacitors is disregarded in the first microseconds after switch-on. Inrush current Max. Typ. Typ. Max. Inrush energy Fig. 5-1 Typical turn-on behaviour at nominal load, 120Vac input and 25°C ambient 50ms/DIV Output voltage 10V/DIV AC 120V 7Apeak 6Apeak 6Apeak AC 230V 11Apeak 6Apeak 9Apeak At 40°C, cold start At 25°C, cold start At 40°C, cold start 0.1A²s 0.1A²s 0.4A²s At 40°C, cold start Fig. 5-2 Typical turn-on behaviour at nominal load, 230Vac input and 25°C ambient 50ms/DIV 6A Input current 2A/DIV Input voltage 250V/DIV AC 100V 11Apeak 9Apeak 9Apeak Input current 2A/DIV 6A Input voltage 500V/DIV Output voltage 10V/DIV Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 7/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 6. OUTPUT Output voltage Adjustment range Nom. Guaranteed value This is the maximum output voltage which can occur at the clockwise end position of the potentiometer due to tolerances. It is not a guaranteed value which can be achieved. Typ. 12.0Vdc ±0.2% At full load and cold unit Max. 10mV Between 85 and 300Vac Max. 50mV Between 0 and 19.2A, static value, see Fig. 6-1 Max. 50mVpp Bandwidth 20Hz to 20MHz, 50Ohm Nom. 16A At 12V and up to + 60°C ambient temperature, see Fig. 6-1 Nom. 12A At 12V and +70°C ambient temperature, see Fig. 17-1 Nom. 12.8A At 15V and up to +60°C ambient temperature, see Fig. 6-1 Nom. 9.6A At 15V and +70°C ambient temperature, see Fig. 17-1 Derate linearly between +60°C and +70°C, see chapter 17 Nom. 19.2A At 12V and up to +45°C ambient temperature, see Fig. 17-1 Nom. 15.4A At 15V and up to +45°C ambient temperature, see Fig. 17-1 PowerBoost decreases linearly to nominal power between +45°C between +60°C, see chapter 17 Typ. 48A For minimal 12ms once every five seconds, see Fig. 6-2. The output voltage stays above 10V. See chapter 25.1 for more peak current measurements. For AC 100V mains, the pulse length is shorter than 12ms. Continuous current Output voltage above 6.5Vdc, see Fig. 6-1 HiccupPLUS mode2) Output voltage below 6.5Vdc, see Fig. 6-1 Min. 20.5A3) Load impedance 4mm E.g. screws, small parts Yes Output shut-down with automatic restart. The temperature sensor is installed on critical components inside the unit and turns the unit off in safety critical situations (e.g. derating requirements not observed, high ambient temperature, ventilation obstructed or the mounting orientation derating is not followed). There is no correlation between the operating temperature and turn-off temperature since this is dependent on input voltage, load and installation methods. MOV For protection values see chapter 16 (EMC). (Metal Oxide Varistor) Included Not user replaceable slow-blow high-braking capacity fuse 19. SAFETY FEATURES Input / output separation Class of protection Isolation resistance PE resistance Touch current (leakage current) Double or reinforced galvanic isolation SELV IEC/EN 60950-1 PELV IEC/EN 60204-1, EN 50178, IEC 62103, IEC 60364-4-41 I PE (Protective Earth) connection required > 500MOhm At delivered condition between input and output, measured with 500Vdc > 500MOhm At delivered condition between input and PE, measured with 500Vdc > 500MOhm At delivered condition between output and PE, measured with 500Vdc > 500MOhm At delivered condition between output and DC-OK contacts, measured with 500Vdc < 0.1Ohm Resistance between PE terminal and the housing in the area of the DIN rail mounting bracket. Typ. 0.14mA / 0.36mA At 100Vac, 50Hz, TN-,TT-mains / IT-mains Typ. 0.20mA / 0.50mA At 120Vac, 60Hz, TN-,TT-mains / IT-mains Typ. 0.33mA / 0.86mA At 230Vac, 50Hz, TN-,TT-mains / IT-mains Max. 0.18mA / 0.43mA At 110Vac, 50Hz, TN-,TT-mains / IT-mains Max. 0.26mA / 0.61mA At 132Vac, 60Hz, TN-,TT-mains / IT-mains Max. 0.44mA / 1.05mA At 264Vac, 50Hz, TN-,TT-mains / IT-mains Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 18/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 20. DIELECTRIC STRENGTH The output voltage is floating and has no ohmic connection to the ground. Type and factory tests are conducted by the manufacturer. Field tests may be conducted in the field using the appropriate test equipment which applies the voltage with a slow ramp (2s up and 2s down). Connect all input-terminals together as well as all output poles before conducting the test. When testing, set the cut-off current settings to the value in the table below. Type test 60s A 2500Vac Factory test 5s 2500Vac 2500Vac Field test 5s 2000Vac 2000Vac 500Vac 500Vac Cut-off current setting > 10mA > 10mA > 20mA > 1mA Fig. 20-1 Dielectric strength Input L N 13 B* ) 14 B A DC-ok C C 1000Vac D 500Vac 500Vac 500Vac D Output Earth, PE B 4000Vac +/ - ON/OFF 15,16 To fulfil the PELV requirements according to EN60204-1 § 6.4.1, we recommend that either the + pole, the – pole or any other part of the output circuit shall be connected to the protective earth system. This helps to avoid situations in which a load starts unexpectedly or can not be switched off when unnoticed earth faults occur. B*) When testing input to DC-OK ensure that the max. voltage between DC-OK and the output is not exceeded (column D). We recommend connecting DC-OK pins and the output pins together when performing the test. Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 19/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 21. APPROVED, FULFILLED OR TESTED STANDARDS UL 508 UL 61010-2-201 IEC 61010-2-201 IEC 62368-1 IEC 60950-1 (CP10.121) UL 60950-1 (CP10.121) ATEX (CP10.121) IECEx (CP10.121) Class I Div 2 (CP10.121) UL Certificate Listed equipment for category NMTR - Industrial Control Equipment Applicable for US and Canada E-File: E198865 UL Certificate Listed equipment for category NMTR - Electrical Equipment for Measurement, Control and Laboratory Use - Particular requirements for control equipment Applicable for US and Canada E-File: E198865 Manufacturer's Declaration Electrical Equipment for Measurement, Control and Laboratory Use Particular requirements for control equipment CB Scheme Certificate IEC 62368-1 Audio/video, information and communication technology equipment - Safety requirements Output safety level: ES1 CB Scheme Certificate General safety requirements for Information Technology Equipment (ITE) UL Certificate Recognized component for category QQGQ - Information Technology Equipment (ITE) Applicable for US and Canada E-File: E137006 Agency Certificate (Bureau Veritas) EN 60079-0 Explosive atmospheres - General requirements EN 60079-7, EN 60079-15 Equipment protection by type of protection "e" and "n" Certificate: EPS 15 ATEX 1 101 X Temperature Code: T4 Type of Protection: ec nC IECEx Certificate IEC 60079-0 Explosive atmospheres - General requirements IEC 60079-7, IEC 60079-15 Equipment protection by type of protection "e" and "n" Certificate: IECEx EPS 15.0079X Temperature Code: T4 Type of Protection: ec nC CSA Certificate Power Supplies for Hazardous Location Applicable for Canada and US CSA Class: 5318-01 (Canada), 5318-81 (USA) Temperature Code: T4 Groups: A, B, C and D Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 20/31 CP10.121, CP10.122 CP-Series Marine (DNV) (CP10.121) Marine (ABS) (CP10.121) IEC 60068-2-60 (CP10.121) ISA-71.04 G3 (CP10.121) Labs 12V, 16A, 192W, SINGLE PHASE INPUT DNV Certificate DNV Type approved product Certificate: TAA00002YX Temperature: Class D Humidity: Class B Vibration: Class C EMC: Class A Enclosure: Class A ABS Design Assessment Certificate ABS (American Bureau of Shipment) assessed product Certificate: 17-HG1599236-PDA Manufacturer's Declaration (Online Document) Environmental Tests, Flowing Mixed Gas Corrosion Test IEC 60068-2-60 Method 4 Test Ke - Method 4 H2S: 10ppb NO2: 200ppb Cl2: 10ppb SO2: 200ppb Test Duration: 3 weeks, this simulates a service life of 10 years. Manufacturer's Declaration (Online Document) Airborne Contaminants Corrosion Test ISA-71.04 G3 Severity Level: G3 Harsh H2S: 100ppb NOx: 1250ppb Cl2: 20ppb SO2: 300ppb Test Duration: 3 weeks, this simulates a service life of 10 years. Paint Wetting Impairment Substances Test (or LABS-Test) Tested for Zone 2 and test class C1 according to VDMA 24364-C1-L/W for solvents and water-based paints Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 21/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 22. REGULATORY PRODUCT COMPLIANCE EU Declaration of Conformity WEEE Regulation REACH Regulation (EU) UKCA (CP10.121) The CE mark indicates conformance with the - EMC directive - ATEX directive - RoHS directive Manufacturer's Declaration EU Regulation on Waste Electrical and Electronic Equipment Registered as business to business (B2B) products. EU Regulation 2012/19/EU Manufacturer's Declaration EU regulation regarding the Registration, Evaluation, Authorisation and Restriction of Chemicals (REACH) fulfilled. EU Regulation (EC) 1907/2006. UKCA Declaration of Conformity Trade conformity assessment for England, Scotland and Wales The UKCA mark indicates conformity with the UK Statutory Instruments 2016 No.1101, 2016 No.1091, 2012 No.3032 CCC (CP10.121) KC CCC Certificate China Compulsory Certification (CNCA-C23-01:2019) Certificate for devices made in Suzhou/China (PULS Electronics): 2021122303114443 Certificate for devices made in Chomutov/Czech Republic (PULS investiční): 2021122303114444 CCC-Ex KC Korean Certification Korean - Registration of Broadcasting and Communication Equipment Registered under Clause3, Article 58-2 of Radio Waves Act. Registration No. R-R-PUG-CP10_121 Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 22/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 23. PHYSICAL DIMENSIONS AND WEIGHT Width Height Depth Weight DIN rail Housing material Installation clearances 39mm 124mm 117mm The DIN rail depth must be added to the unit depth to calculate the total required installation depth. 600g Use 35mm DIN rails according to EN 60715 or EN 50022 with a height of 7.5 or 15mm. Body: Aluminium alloy Cover: Zinc-plated steel See chapter 2 Fig. 23-1 Front view Fig. 23-2 Side view All dimensions in mm All dimensions in mm Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 23/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 24. ACCESSORIES 24.1. ZM10.WALL - WALL/PANEL MOUNT BRACKET This bracket is used to mount the devices on a wall/panel without utilizing the DIN rail. The bracket can be mounted without detaching the DIN rail brackets from the power supply. PSU for illustration purpose only. Fig. 24-1 Isometric view Fig. 24-4 Wall/panel mounting, front Fig. 24-2 Isometric view Fig. 24-5 Hole pattern for wall mounting Fig. 24-3 Isometric view Fig. 24-6 Wall/panel mounting, side view view Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 24/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 24.2. ZM12.SIDE - SIDE MOUNTING BRACKET This bracket is used to mount DIMENSION units sideways with or without utilizing a DIN rail. The two aluminum brackets and the black plastic slider of the unit have to be detached, so that the steel brackets can be mounted. For sideway DIN rail mounting, the removed aluminum brackets and the black plastic slider need to be mounted on the steel bracket. Side mounting with DIN rail brackets Side mounting without DIN rail brackets 24.3. YR40.242 - REDUNDANCY MODULE The YR40.242 redundancy module is equipped with two input channels, which are individually decoupled by utilizing MOSFET technology. Using MOSFETs instead of diodes reduces the heat generation and the voltage drop between input and output. The YR40.242 does not require an additional auxiliary voltage and is self-powered even in case of a short circuit across the output. Due to the low power losses, the unit is very slender and only requires 36mm width on the DIN rail. Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 25/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 25. APPLICATION NOTES 25.1. PEAK CURRENT CAPABILITY The unit can deliver peak currents (up to several milliseconds) which are higher than the specified short term currents. This helps to start current demanding loads. Solenoids, contactors and pneumatic modules often have a steady state coil and a pick-up coil. The inrush current demand of the pick-up coil is several times higher than the steady-state current and usually exceeds the nominal output current (including the PowerBoost). The same situation applies when starting a capacitive load. The peak current capability also ensures the safe operation of subsequent circuit breakers of load circuits. The load branches are often individually protected with circuit breakers or fuses. In case of a short or an overload in one branch circuit, the fuse or circuit breaker need a certain amount of over-current to open in a timely manner. This avoids voltage loss in adjacent circuits. The extra current (peak current) is supplied by the power converter and the built-in large sized output capacitors of the power supply. The capacitors get discharged during such an event, which causes a voltage dip on the output. The following examples show typical voltage dips for resistive loads: Fig. 25-1 32A peak current for 50ms , typ. (2x the nominal current) Output Voltage Fig. 25-2 80A peak current for 5ms , typ. (5x the nominal current) 12V Output Voltage 7.1V 12V 8.6V 80A 32A Output Current 0A 10ms/DIV 0A 1ms/DIV Output Current Fig. 25-3 48A peak current for 12ms , typ. (3x the nominal current) 12V 48A 12ms 5.8V Output Voltage Output Current 0A 10ms/DIV Peak current voltage dips Please note: The DC-OK relay triggers when the voltage dips more than 10% for longer than 1ms. Typically from 12V to 8.6V at 32A for 50ms with resistive load Typically from 12V to 7.4V at 80A for 2ms with resistive load Typically from 12V to 7.1V at 80A for 5ms with resistive load Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 26/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 25.2. BACK-FEEDING LOADS Loads such as decelerating motors and inductors can feed voltage back to the power supply. This feature is also called return voltage immunity or resistance against Back- E.M.F. (Electro Magnetic Force). This power supply is resistant and does not show malfunctioning when a load feeds back voltage to the power supply. It does not matter whether the power supply is on or off. The maximum allowed feed-back-voltage is 25Vdc. The maximum allowed feed-back peak current is 64A. Higher currents can temporarily shut-down the output voltage. The absorbing energy can be calculated according to the built-in large sized output capacitor which is specified in chapter 6. 25.3. EXTERNAL INPUT PROTECTION The unit is tested and approved for branch circuits up to 30A (UL) and 32A (IEC). An external protection is only required if the supplying branch has an ampacity greater than this. Check also local codes and local requirements. In some countries local regulations might apply. If an external fuse is necessary or utilized, minimum requirements need to be considered to avoid nuisance tripping of the circuit breaker. A minimum value of 6A B- or C-Characteristic breaker should be used. 25.4. OUTPUT CIRCUIT BREAKERS Standard miniature circuit breakers (MCB’s or UL 1077 circuit breakers) are commonly used for AC-supply systems and may also be used on 12V branches. MCB’s are designed to protect wires and circuits. If the ampere value and the characteristics of the MCB are adapted to the wire size that is used, the wiring is considered as thermally safe regardless of whether the MCB opens or not. To avoid voltage dips and under-voltage situations in adjacent 12V branches which are supplied by the same source, a fast (magnetic) tripping of the MCB is desired. A quick shutdown within 10ms is necessary corresponding roughly to the ride-through time of PLC's. This requires power supplies with high current reserves and large output capacitors. Furthermore, the impedance of the faulty branch must be sufficiently small in order for the current to actually flow. The best current reserve in the power supply does not help if Ohm’s law does not permit current flow. The following table has typical test results showing which B- and C-Characteristic MCBs magnetically trip depending on the wire cross chapter and wire length. Maximal wire length*) for a fast (magnetic) tripping: 0.75mm² 1.0mm² 1.5mm² Fig. 25-4 Test circuit Power Supply AC MCB + + Wire length DC S1... Fault simulation switch *) Load S1 - 2.5mm² C-2A C-3A 11m 9m 15m 13m 22m 18m 35m 23m C-4A C-6A B-6A 5m 6m 8m 1m 11m 12m 2m 15m 17m 3m 23m B-10A B-13A 2m 1m 3m 2m 3m 3m 4m 4m Don’t forget to consider twice the distance to the load (or cable length) when calculating the total wire length (+ and – wire). Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 27/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 25.5. PARALLEL USE TO INCREASE OUTPUT POWER Power supplies can be paralleled to increase the output power. The output voltage of all power supplies shall be adjusted to the same value (±100mV) with the same load conditions on all units, or the units can be left with the factory settings. There is no feature included which balances the load current between the power supplies. Usually the power supply with the higher adjusted output voltage draws current until it goes into current limitation. This means no harm to this power supply as long as the ambient temperature stays below 40°C. If more than three units are connected in parallel, a fuse or circuit breaker with a rating of 25A or 32A is required on each output. Alternatively, a diode or redundancy module can also be utilized. Unit A AC DC + + Unit B AC DC Load + - - Energize all units at the same time to avoid the overload HiccupPLUS mode. It also might be necessary to cycle the input power (turn-off for at least five seconds), if the output was in HiccupPLUS mode due to overload or short circuits and the required output current is higher than the current of one unit. Keep an installation clearance of 15mm (left / right) between two power supplies and avoid installing the power supplies on top of each other. Do not use power supplies in parallel in mounting orientations other than the standard mounting orientation (terminals on bottom of the unit) or in any other condition where a derating of the output current is required (e.g. altitude, …). Pay attention that leakage current, EMI, inrush current, harmonics will increase when using multiple power supplies. 25.6. PARALLEL USE FOR REDUNDANCY Power supplies can be paralleled for redundancy to gain higher system availability. Redundant systems require a certain amount of extra power to support the load in case one power supply unit fails. The simplest way is to put two decoupled power supplies in parallel. This is called a 1+1 redundancy. In case one power supply unit fails, the other one is automatically able to support the load current without any interruption. Redundant systems for a higher power demand are usually built in a N+1 method. E.g. five power supplies, each rated for 16A are paralleled to build a 64A redundant system. For N+1 redundancy the same rules apply as for increasing the output power, see also chapter 25.5. Please note: Always use a redundancy module to decouple power supplies from each other. This prevents that the defective unit becomes a load for the other power supplies and the output voltage cannot be maintained any more. Recommendations for building redundant power systems: a) b) c) Use separate input fuses for each power supply. Monitor the individual power supply units. Therefore, use the DC-OK relay contact of the CP10 power supply. It is desirable to set the output voltages of all units to the same value (± 100mV) or leave it at the factory setting. Fig. 25-5 1+1 redundant configuration with one YR40.242 redundancy module Load Failure Monitor optional ++ --oo Output DC- +Output ++ --oo Output DC- OK Power Supply Input LN I OK YR40.242 Redundancy Module Power Supply Input Input 2 1 +-+- Input LN I L N PE Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 28/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series Unit A 25.7. SERIES OPERATION AC Power supplies of the same type can be connected in series for higher output voltages. It is possible to connect as many units in series as needed, providing the sum of the output voltage does not exceed 150Vdc. Voltages with a potential above 60Vdc are not SELV any more and can be dangerous. Such voltages must be installed with a protection against touching. DC + + Unit B AC Avoid return voltage (e.g. from a decelerating motor or battery) which is applied to the output terminals. DC Load + - Earth (see notes) Keep an installation clearance of 15mm (left / right) between two power supplies and avoid installing the power supplies on top of each other. Do not use power supplies in series in mounting orientations other than the standard mounting orientation (input terminals on bottom of the unit). Pay attention that leakage current, EMI, inrush current, harmonics will increase when using multiple power supplies. 25.8. INDUCTIVE AND CAPACITIVE LOADS The unit is designed to supply any kind of loads, including capacitive and inductive loads. If extreme large capacitors, such as EDLCs (electric double layer capacitors or “UltraCaps”) with a capacitance larger than 5F are connected to the output, the unit might charge the capacitor in the HiccupPLUS mode (see chapter 6). 25.9. CHARGING OF BATTERIES The power supply can be used to charge lead-acid or maintenance free batteries (SLA or VRLA batteries). Instructions for charging batteries: a) Set output voltage (measured at no load and at the battery end of the cable) very precisely to the end-of-charge voltage. End-of-charge voltage 13.9V 13.75V 13.6V 13.4V Battery temperature 10°C 20°C 30°C 40°C b) Use a 25A circuit breaker (or blocking diode) between the power supply and the battery. c) Ensure that the output current of the power supply is below the allowed charging current of the battery. d) Ensure that the ambient temperature of the power supply stays below 40°C. e) The return current to the power supply (battery discharge current) is typ. 2.6mA when the power supply is switched off (except in case a blocking diode is utilized). Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 29/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 25.10. OPERATION ON TWO PHASES Power Supply The power supply can also be used on two-phases of a three-phase-system. Such a phase-to-phase connection is allowed as long as the supplying voltage is below 240V+10%. L3 Center Tap 240V +10% max. L1 AC L N PE DC L2 25.11. USE IN A TIGHTLY SEALED ENCLOSURE When the power supply is installed in a tightly sealed enclosure, the temperature inside the enclosure will be higher than outside. In such situations, the inside temperature defines the ambient temperature for the power supply. The following measurement results can be used as a reference to estimate the temperature rise inside the enclosure. The power supply is placed in the middle of the box, no other heat producing items are inside the box The temperature sensor inside the box is placed in the middle of the right side of the power supply with a distance of 1cm. Input voltage Case A 110x180x165mm Rittal Typ IP66 Box PK 9516 100, plastic 230Vac Case B 110x180x165mm Rittal Typ IP66 Box PK 9516 100, plastic 230Vac Case C 180x180x165mm Rittal Typ IP66 Box PK 9519 100, plastic 230Vac Case D 180x180x165mm Rittal Typ IP66 Box PK 9519 100, plastic 230Vac Load Temperature inside the box Temperature outside the box Temperature rise 12V, 12.8A; (=80%) 47.4°C 24.6°C 22.8K 12V, 16A; (=100%) 56.3°C 25.7°C 30.6K 12V, 12.8A; (=80%) 46.2°C 24.4°C 21.8K 12V, 16A; (=100%) 53.4°C 26.0°C 27.4K Enclosure size Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 30/31 CP10.121, CP10.122 12V, 16A, 192W, SINGLE PHASE INPUT CP-Series 25.12. MOUNTING ORIENTATIONS Mounting orientations other than all terminals on the bottom require a reduction in continuous output power or a limitation in the maximum allowed ambient temperature. The amount of reduction influences the lifetime expectancy of the power supply. Therefore, two different derating curves for continuous operation can be found below: Curve A1 Recommended output current. Curve A2 Max allowed output current (results in approximately half the lifetime expectancy of A1). Fig. 25-6 Mounting Orientation A (Standard orientation) Output Current 20A OUTPUT A1 15A Power Supply 10A 5A Ambient Temperature 0 INPUT 10 Fig. 25-7 Mounting Orientation B (Upside down) 20 30 40 50 60°C Output Current INPUT 20A 15A A1 A2 Pow er Supply 10A 5A Ambient Temperature OUTPUT 0 10 Fig. 25-8 Mounting Orientation C (Table-top mounting) 20 30 40 50 60°C Output Current 20A 15A A1 A2 10A 5A Ambient Temperature 0 10 40 50 60°C 20A OUTPUT Pow er Supply 15A A1 10A A2 5A Ambient Temperature 0 10 20 30 40 50 60°C Output Current 15A INPUT Pow er Supply 20A OUTPUT Fig. 25-10 Mounting Orientation E (Horizontal ccw) 30 Output Current INPUT Fig. 25-9 Mounting Orientation D (Horizontal cw) 20 A1 A2 10A 5A Ambient Temperature 0 10 20 30 40 50 60°C Jul. 2022 / Rev. 1.4 DS-CP10.121-EN All parameters are typical values specified at 230Vac, 50Hz input voltage, 12V 16A output, 25°C ambient temperature and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 31/31
CP10.121 价格&库存
很抱歉,暂时无法提供与“CP10.121”相匹配的价格&库存,您可以联系我们找货
CP10.121
    • 1+3050.820141+393.30957
