FXA350024A
FXA350024A
    INVENTUSPOWER
    FXA350系列350W交流转直流电源模块,具有高效率、宽输入电压范围、功率因数校正等特点。适用于ITE和医疗级应用。
FXA350024A 数据手册
FXA350 Series 350 Watt ITE Open Frame Power Supply High Efficiency: Level V Wide Range AC Input Power Factor Correction +5V Standby & Fan Power Fully regulated DC output EISA and CEC Compliant Grounded Output ITE and Medical Grade Approval Elpac Part Number Output Voltage Output Current1 Typical Efficiency2 FXA350012A 12.0V 20.0A 88% FXA350015A 15.0V 16.5A 88% FXA350024A 24.0V 10.5A 88% FXA350028A 28.0V 9.0A 89% FXA350048A 48.0V 5.3A 88% Notes 1 With convection cooling. Peak load (350W) lasting up to 500ms with a maximum 10% duty cycle. 2 Typical at 115VAC. Input Input Voltage 85 ­ 264VAC 100 ­ 240VAC Nominal Input Frequency 47 ­ 63Hz Input Current
FXA350024A 价格&库存
很抱歉,暂时无法提供与“FXA350024A”相匹配的价格&库存,您可以联系我们找货
