175W Single Output
Industrial Grade
CINT1175 Family
FEATURES AND BENEFITS
Industrial
175W W/Air, 120W Convection Cooled
Approved to EN/CSA/IEC/UL62368-1
2” x 4” x 1.3” Package
12V Fan Output
Ideal for 1U Applications
90% Efficiency Typical at Full Load
Universal Input 90VAC–264VAC
3 Year Warranty
Meets Level V Efficiency Requirements
RoHS Compliant
MODEL SELECTION
Output Current
Model Number
Volts*
CINT1175A1206K01
Fan Output
Ripple &
Noise**
Total Regulation
OVP***
Threshold***
w/200LFM air
Convection
12V
14.6A
10.0A
12VDC/04.A
0.5%RMS,
1.2% pk-pk
±3%
14.0V ± 1.1V
CINT1175A1506K01
15V
11.7A
8.0A
12VDC/04.A
0.5%RMS,
1.0% pk-pk
±3%
18.5V ± 1.5V
CINT1175A2406K01
24V
7.3A
5.0A
12VDC/04.A
0.5%RMS,
1.2% pk-pk
±3%
28.0V ± 2.5V
CINT1175A4806K01
48V
3.6A
2.5A
12VDC/04.A
0.5%RMS,
1.0% pk-pk
±3%
55.0V ± 4.0V
CINT1175A5606K01
56V
3.1A
2.1A
12VDC/04.A
0.5%RMS,
1.0% pk-pk
±3%
59.0V ± 1.0V
Notes:
1.
2.
3.
* Total convection power is 120 watts.
** Measured with noise probe directly across output terminals, and load terminated with 0.1μF ceramic and 10μF low ESR capacitors.
*** Output adjustment on 56 volts model will not exceed 56.2 volts.
CINT1175 Datasheet v1020
Copyright © 2020 SL Power Electronics Corp. All rights reserved.
Page 1
175W Single Output
Industrial Grade
CINT1175 Family
INPUT
OUTPUT
Input Voltage and
Frequency
100VAC–240VAC, ±10%, 47Hz–63Hz, 1Ø
120VDC–370VDC
Output Voltage
See chart
Input Current
115VAC: 2A, 230VAC: 1A
Output Power
Inrush Current
264VAC, cold start: will not exceed 50A
175W continuous, with 200 lfm airflow, 120W
convection cooled – See chart for specific
voltage model ratings
Input Fuse
4A, 250VAC fuse provided on all models
Turn On Time
Earth Leakage Current
很抱歉,暂时无法提供与“CINT1175A4806K01”相匹配的价格&库存,您可以联系我们找货
