CINT1175A1506K01
CINT1175A1506K01
    SLPOWER
    AC/DC CONVERTER 15V 120W
CINT1175A1506K01 数据手册
175W Single Output Industrial Grade CINT1175 Family FEATURES AND BENEFITS Industrial 175W W/Air, 120W Convection Cooled Approved to EN/CSA/IEC/UL62368-1 2” x 4” x 1.3” Package 12V Fan Output Ideal for 1U Applications 90% Efficiency Typical at Full Load Universal Input 90VAC–264VAC 3 Year Warranty Meets Level V Efficiency Requirements RoHS Compliant MODEL SELECTION Output Current Model Number Volts* CINT1175A1206K01 Fan Output Ripple & Noise** Total Regulation OVP*** Threshold*** w/200LFM air Convection 12V 14.6A 10.0A 12VDC/04.A 0.5%RMS, 1.2% pk-pk ±3% 14.0V ± 1.1V CINT1175A1506K01 15V 11.7A 8.0A 12VDC/04.A 0.5%RMS, 1.0% pk-pk ±3% 18.5V ± 1.5V CINT1175A2406K01 24V 7.3A 5.0A 12VDC/04.A 0.5%RMS, 1.2% pk-pk ±3% 28.0V ± 2.5V CINT1175A4806K01 48V 3.6A 2.5A 12VDC/04.A 0.5%RMS, 1.0% pk-pk ±3% 55.0V ± 4.0V CINT1175A5606K01 56V 3.1A 2.1A 12VDC/04.A 0.5%RMS, 1.0% pk-pk ±3% 59.0V ± 1.0V Notes: 1. 2. 3. * Total convection power is 120 watts. ** Measured with noise probe directly across output terminals, and load terminated with 0.1μF ceramic and 10μF low ESR capacitors. *** Output adjustment on 56 volts model will not exceed 56.2 volts. CINT1175 Datasheet v1020 Copyright © 2020 SL Power Electronics Corp. All rights reserved. Page 1 175W Single Output Industrial Grade CINT1175 Family INPUT OUTPUT Input Voltage and Frequency 100VAC–240VAC, ±10%, 47Hz–63Hz, 1Ø 120VDC–370VDC Output Voltage See chart Input Current 115VAC: 2A, 230VAC: 1A Output Power Inrush Current 264VAC, cold start: will not exceed 50A 175W continuous, with 200 lfm airflow, 120W convection cooled – See chart for specific voltage model ratings Input Fuse 4A, 250VAC fuse provided on all models Turn On Time Earth Leakage Current
CINT1175A1506K01 价格&库存
很抱歉,暂时无法提供与“CINT1175A1506K01”相匹配的价格&库存,您可以联系我们找货
