CINT1275A4814K01
CINT1275A4814K01
    SLPOWER
    AC/DC CONVERTER 48V 180W
CINT1275A4814K01 数据手册
275W Single Output Industrial Grade CINT1275 Family FEATURES AND BENEFITS Industrial 3” x 5” x 1.40” Package Inhibit, Power Fail, Output OK Signals Up to 275W of AC-DC Power Approved to EN/CSA/IEC/UL62368-1 For 1U Applications Efficiency 92% Typical Universal Input 90-264VAC Input Range 3 Years Warranty Standby and Fan Output Voltages RoHS Compliant Forced Current Share MODEL SELECTION Output Current Fan Output Ripple & Noise** Total Regulation 15.0A 12V DC/1A 120mV pk-pk ±3% 14.0 ± 1.1V 18.3A 12.0A 12V DC/1A 150mV pk-pk ±3% 19.5 ± 1.5V 24V 10.9A 7.50A 12V DC/1A 240mV pk-pk ±3% 28.0 ± 2.5V CINT1275A4814K01 48V 5.46A 3.75A 12V DC/1A 480mV pk-pk ±3% 55.0 ± 4.0V CINT1275A5614K01 56V 4.68A 3.21A 12V DC/1A 560mV pk-pk ±3% 59.0 ± 1.0V Model Number Volts CINT1275A1214K01 12V 21.8A CINT1275A1514K01 15V CINT1275A2414K01 w/200LFM air Convection* OVP Threshold*** Note: * Total convection power is 180 Watts. ** Measured with noise probe directly across output terminals, and load terminated with 0.1μF ceramic and 10μF low ESR capacitors. *** No output adjustment on 56V. INPUT OUTPUT AC Input 100-240VAC, ±10%, 47-63Hz, 1Ø 120-370V DC Hold-Up Time 16ms at 250W, 120VAC/60Hz Input Current 115VAC: 3A, 230VAC: 1.5A 3.7A max at 90VAC Turn On Time Less than 2 sec @115VAC (inversely proportional to input voltage and thermistor temperature) Inrush Current 264VAC, cold start: will not exceed 50A Input Fuses F1, F2: 5A, 275VAC fuses provided on all models Switching Frequency PFC: Variable, 30kHz - 400kHz Main converter: Variable 30-250kHz, 65-70kHz at full load Earth Leakage Current
CINT1275A4814K01 价格&库存
很抱歉,暂时无法提供与“CINT1275A4814K01”相匹配的价格&库存,您可以联系我们找货
