SL2.100
SL2.100
    PULS
    AC/DCCONVERTER24V60W
SL2.100 数据手册
Baby SilverLine with 2.5 A SL2.100 Data sheet EMC and Low Volt. Directive • • • • • • Input: AC 230V / 115V Output: 24V / 2.5A High overload current, no switch-off Quasi-Wide-Range Input Robust mechanics and EMC NEC Class 2 Power Supply UL60950 E137006 CUL/CSA-C22.2 No. 60950 UL508 LISTED IND. CONT. EQ. 18 WM, 60°C CB scheme IEC60950 Data sheet Input Input voltage Output AC100-120/220-240 V (switchable), 47-63 Hz (85-132 VAC / 176-264 VAC, 160-375 VDC, see also „Output: Continuous Loading“) Output voltage 24 V DC +5% –1% Output noise suppression Radiated EMI values below EN 61000-6-3, even when using long, unscreened output cables. (12V on request) Quasi-Wide-Range Input: With the switch in the 230V position the powAmbient temperature Operation: -10°C...+70°C (>60°C: Derating) er-supply unit operates at low and moderate loads at any input voltage range Tamb Storage: -25°C...+85°C between 95 and 264 V AC (see ’Output’ at the right side). Continuous loading Switch AC/DCin Iout Note: At DC input, always leave the switch in the 230V position (at Tamb = -10°C...+60°C, 230V 176-264 V ACin 2,5 A Input current < 1.3 A (switch in 115V position) convection cooling), 95-176 V ACin 1,5 A see also Diagram overleaf. < 0.7 A (switch in 230V position) 160-375 V DCin 2,5 A For start at Tamb 115V 85-132 V ACin 2.5 A 95 V DC needed Inrush current typ. 25 A at 264 V AC and cold start Output protected against short circuit, open circuit and overload Unit is internally fused (fuse not accessible). For external fusing of unit Derating typ. 1.5 W/K (at Tamb=+60°C...+70°C) and for input line protection, use circuit breaker with B-characteristic 10A or slower action, or alternatively T10A HBC fuse. Voltage regulation better than 2% Vout overall EN 61000-3-2 (harmonic current emissions) is fulfilled Ripple / Noise < 25 mVPP, (20 MHz bandw., 50 !"measurem.) Transient handling Transient resistance acc. to VDE 0160 / W2 (750 V / 1.3 ms), for all load conditions. Overvolt. protection typ. 32 V Hold up time > 20 ms at 196 VAC, 24 V / 2.5 A (see Diagram overleaf) Parallel operation yes; current sharing available on request Power back immunity 26 V Front panel indicator Green LED, goes out at Vout < 18V Efficiency, Reliability etc.* Efficiency typ. 87.5 % (230 VAC, 24 V / 2.5 A) Losses typ. 8.6 W (230 VAC, 24 V / 2.5 A) MTBF 740,000 h acc. to Siemensnorm SN 29500 (24 V/2.5 A, 230 VAC, Tamb = +40 °C) Life cycle (electrolytics) The unit exclusively uses longlife electrolytics, specified for +105°C (cf. ’The SilverLine’, p.2). Start / Overload Behaviour Startup delay typ. 0.1 s Rise time ca. 5-20 ms, depending on load Overload Behaviour • Special PULS Overload Design (see diagram overleaf) – no disconnection, no hiccup if overloaded – high overload current (up to 1.5 INom), Vout is gradually reduced with increasing current. Advantages: • High short-circuit current, giving large ’start-up window’: unit starts reliably even with awkward loads (DC-DC converters, motors). • No ’sticking’ such as can occur with fold-back characteristics • Secondary fuses operate reliably Order information sl2e100 / 070822 Order number Description SL2.100 SLR2.100 SLZ02 (Basic version*) (N+1 redundancy*) (Screw mounting set, two needed per unit) 1/2 Data sheet Construction / Mechanics* Output Current over Input Voltage (min.) Housing dimensions and Weight 49 mm x 124 mm x 102 mm (+ DIN rail) • WxHxD above/below 25 mm recommended • Free space for right 10 mm recommended (front view) ventilation 460 g • Weight 3 DCin 2 1 Output current Iout [A] Design advantages: • All connection blocks are easy to reach as mounted at the front panel. • Input and output are strictly apart from each other and so cannot be mixed up (Input below, output above). * *For further information see data sheets „The SilverLine“, „SilverLine Family Branches“ and mechanics data sheet >95 VDC for start 80 160 100 200 375 300 400 Input voltage VDCin [V] 3 ACin switch at 115V 2 switch 1 95 85 100 132 176 264 200 300 400 Input voltage VACin [V] For further information, especially about • EMC • Connections • Safety, Approvals • Mechanics und Mounting, see page 2 of the „The SilverLine“ data sheet. Output characteristic (min.) 28 Tamb = 60°C / 45°C / 25°C / 0°C 24 For detailed dimensions see SilverLine mechanics data sheet SL2/ SL5/ SL10 Output voltage Vout [V] 20 16 12 8 4 0 0 1 2 3 4 5 6 Output current Iout [A] Hold-up time (min.) 100 100 90 DCin 80 70 60 Hold-up time [ms] Hold-up time [ms] 80 Iout=1,5 50 40 30 Iout=2,5 20 Iout=1,0 A ACin 90 Iout=1,0 Iout=1,5 A 70 60 Iout=2,5 A 50 40 Switch pos. 115V Iout=1,5 A Iout=2,5 A Switch pos 230V 30 20 10 10 0 0 80 120 160 200 240 Input voltage VDCin [V] 280 320 90 120 150 180 Input voltage VACin [V] 210 240 Unless otherwise stated, specifications are valid for AC 230V input voltage, +25°C ambient temperature, and 5 min. run-in time. They are subject to change without prior notice. Your partner in power supply: European Power Supply Manufacturers Association Bayerns Best 50 Czech 100 Best Europe’s 500 PULS GmbH Arabellastraße 15 D-81925 München Tel.: +49 89 9278-0 Fax: +49 89 9278-199 www.puls-power.com 2/2 sl2e100 / 070822 Mechanics Data sheet SL2.5/ SL5/ SL10 • Innovative DIN-Rail mount, unit holds even at vibration or lateral pressure • Clearly arranged and user oriented • Large, robust screw terminals • Sealed metal housing • Fine ventilating grid Side view SL2.5 Front view SL2.5 Construction / Mechanics Connections Housing dimensions and Weight Free space for ventilation Unit W x H x D [mm] weight left above/below right • SL2.5 49 x 124 x 102 460 g 0 mm 25 mm each 10 mm • SL5.10x 64 x 124 x 102 620 g 15 mm 25 mm each 15 mm • SL5.300 73 x 124 x 117 730 g 15 mm 50 mm each 15 mm • SL10 120 x 124 x 102 980 g 15 mm 25 mm each 15 mm Overall depth = depth value as mentioned + DIN rail depth Connections • Input/Output • Current handling capacity • Grid Screw terminals, connector size range: solid 0.5- 6 mm2 / flexible 0.5- 4 mm2 30 A per output Two connectors per output, 9 mm distance between adjacent connectors Design advantages: • All connection blocks are easy to reach as mounted at the the front panel. • Input and output are strictly apart from each other and so cannot be mixed up Robust metal housing with fine ventilat. grid ( 3,5 mm, IP20), to keep out small parts (e.g. screws) Mounting on DIN-Rail (TS35/7.5 or TS35/15, 1...1.5 mm thick), thus • Simple snap-on system • Sits safely and firmly on the DIN-Rail • No tools required to remove or backplane-mounted (two optional screw mounting sets SLZ01 required) sledrw1 / 040114 Bottom view SL2.5 Order information Order number Description SL2.100 SL2.103 SL5.100 SL5.102 SL5.105 SL5.300 SL10.100 and SL10.105 SL10.101 SLZ01 24V/2.5A 12-15V/40W 24V/5A 24-28V/120W 24-28V/120W 24-28V/120W, 3AC400-500V input 24-28V/240W 48-56V/240W Screw mounting set, two needed per unit 1/2 Data sheet All views SL5.300 120 Bottom view SL10 SL5.10x Side view and front view SL10, SL5.10x his ’mechanics data sheet’ exclusively deals with the mechanical properties of the product. For further information (especially concerning electrical properties), please refer to the generic data sheet of the SL2.5, SL5 and SL10 and to the basic data sheet „The SilverLine“ dealing with common features of all SilverLine units. This data sheet is subject to change without prior notice. Your partner in power supply: European Power Supply Manufacturers Association Bayerns Best 50 Czech 100 Best EuropeÕs 500 PULS GmbH Arabellastraße 15 D-81925 München Tel.: +49 89 9278-0 Fax: +49 89 9278-199 www.puls-power.com 2/2 sledrw1 / 040114
SL2.100 价格&库存
很抱歉,暂时无法提供与“SL2.100”相匹配的价格&库存,您可以联系我们找货
