CS10.243
CS10.243
    PULS
    AC/DCCONVERTER24V240W
CS10.243 数据手册
CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series POWER SUPPLY ▪ ▪ ▪ ▪ ▪ ▪ ▪ AC 100-120V Single-Phase Input Width only 60mm Efficiency up to 91.3% Easy Fuse Breaking due to High Overload Peak Current 20% Output Power Reserves (PowerBoost) Full Output Power up to +60°C 3 Year Warranty PRODUCT DESCRIPTION SHORT-FORM DATA The DIMENSION CS-Series units are cost optimized power supplies without compromising quality, reliability and performance. The CS-Series is part of the DIMENSION power supply family, existing alongside the high featured Q-Series. Output voltage Adjustment range Output current The CS10.243 includes all the essential basic functions. The devices also offer PowerBoost: Power reserves of 20%, which may even be used continuously at temperatures up to +45°C. The most important features are the small size, high efficiency and the wide temperature range. PowerBoost DC 24V 24 - 28V 10.0 – 8.6A up to +60°C ambient 7.5 – 6.4A at +70°C ambient Derate linearly between +60°C and +70°C 12.0A up to +45°C ambient Linear decrease to nominal power between +45°C and +60°C < 50mVpp 20Hz to 20MHz AC 100-120V ±10% 50-60Hz ±6% 3.84A at 120Vac not allowed 0.57 at 120Vac 85A peak at 120Vac 91.3% at 120Vac 22.9W at 120Vac 0°C to +70°C operational 46ms at 120Vac 60x124x117mm WxHxD 700g High immunity to transients and power surges as well as low electromagnetic emission and a large international approval package for a variety of applications makes this unit suitable for nearly every situation. Output ripple AC Input voltage Mains frequency AC Input current DC Input voltage Power factor AC Inrush current Efficiency Losses Temperature range Hold-up time Dimensions Weight ORDER NUMBERS MAIN APPROVALS The unit has an input for 100-120V mains only. This supports regional applications and offers additional cost savings without sacrificing functionality. Power Supply CS10.243 24-28V Standard unit (AC 100-120V-Version) Accessory ZM1.WALL ZM13.SIDE YRM2.DIODE YR40.241 Wall mount bracket Side mount bracket Redundancy module Redundancy module For details and the complete approval list, see chapter 18. UL 508 UL 60950-1 Marine Marine Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany Class I Div 2 1/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series INDEX Page 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. Intended Use ................................................................ 3 Installation Instructions ................................................ 3 AC-Input ....................................................................... 5 DC-Input ....................................................................... 7 Input Inrush Current ..................................................... 7 Output .......................................................................... 8 Hold-up Time ................................................................ 9 Efficiency and Power Losses ....................................... 10 Lifetime Expectancy and MTBF .................................. 11 Functional Diagram .................................................... 11 Terminals and Wiring ................................................. 12 Front Side and User Elements .................................... 13 EMC ............................................................................ 14 Environment ............................................................... 15 Protection Features .................................................... 16 Safety Features........................................................... 16 Dielectric Strength ...................................................... 17 Approved, Fulfilled or Tested Standards .................... 18 Regulatory Product Compliance ................................. 19 Page 20. Physical Dimensions and Weight ............................... 20 21. Accessories................................................................. 21 21.1. ZM1.WALL - Wall Mounting Bracket ................ 21 21.2. ZM13.SIDE - Side Mounting Bracket................. 21 21.3. Redundancy Modules ....................................... 22 21.4. YR40.241 - Redundancy Modules..................... 22 22. Application Notes....................................................... 23 22.1. Peak Current Capability .................................... 23 22.2. Back-feeding Loads .......................................... 24 22.3. External Input Protection ................................. 24 22.4. Output Circuit Breakers .................................... 24 22.5. Parallel Use to Increase Output Power ............ 25 22.6. Parallel Use for Redundancy ............................ 25 22.7. Series Operation............................................... 25 22.8. Inductive and Capacitive Loads ........................ 25 22.9. Charging of Batteries ........................................ 25 22.10. Use in a Tightly Sealed Enclosure ..................... 26 22.11. Mounting Orientations ..................................... 27 The information presented in this document is believed to be accurate and reliable and may change without notice. No part of this document may be reproduced or utilized in any form without permission in writing from the publisher. TERMINOLOGY, ABREVIATIONS AND DEFINITIONS PE and symbol PE is the abbreviation for Protective Earth and has the same meaning as the symbol . Earth, Ground This document uses the term “earth” which is the same as the U.S. term “ground”. t.b.d. To be defined, value or description will follow later. AC 120V A figure displayed with the AC or DC before the value represents a nominal voltage with standard tolerances included. E.g.: DC 12V describes a 12V battery disregarding whether it is full (13.7V) or flat (10V) 120Vac A figure with the unit (Vac) at the end is a momentary figure without any additional tolerances included. 50Hz vs. 60Hz As long as not otherwise stated, AC 100V parameters are valid at 50Hz mains frequency and AC 120V parameters are valid for 60Hz mains frequency. may A key word indicating flexibility of choice with no implied preference. shall A key word indicating a mandatory requirement. should A key word indicating flexibility of choice with a strongly preferred implementation. Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 2/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 1. INTENDED USE This device is designed for installation in an enclosure and is intended for commercial use, such as in industrial control, process control, monitoring, measurement equipment or the like. Do not use this device in equipment, where malfunctioning may cause severe personal injury or threaten human life without additional appropriate safety devices, that are suited for the end-application. If this device is used in a manner outside of its specification, the protection provided by the device may be impaired. 2. INSTALLATION INSTRUCTIONS WARNING - Risk of electrical shock, fire, personal injury or death. Turn power off before working on the device and protect against inadvertent re-powering. Do not open, modify or repair the device. Use caution to prevent any foreign objects from entering into the housing. Do not use in wet locations or in areas where moisture or condensation can be expected. Do not touch during power-on, and immediately after power-off. Hot surface may cause burns. Obey the following installation instructions: This device may only be installed and put into operation by qualified personnel. This device does not contain serviceable parts. The tripping of an internal fuse is caused by an internal defect. If damage or malfunction should occur during installation or operation, immediately turn power off and send unit to the factory for inspection. Install device in an enclosure providing protection against electrical, mechanical and fire hazards. Install the device onto a DIN rail according to EN 60715 with the input terminals on the bottom of the device. Other mounting orientations require a reduction in output current. Make sure that the wiring is correct by following all local and national codes. Use appropriate copper cables that are designed for a minimum operating temperature of 60°C for ambient temperatures up to +45°C, 75°C for ambient temperatures up to +60°C and 90°C for ambient temperatures up to +70°C. Ensure that all strands of a stranded wire enter the terminal connection. Use ferrules for wires on the input terminals. Unused screw terminals should be securely tightened. The device is designed for pollution degree 2 areas in controlled environments. No condensation or frost is allowed. The enclosure of the device provides a degree of protection of IP20.The housing does not provide protection against spilled liquids. The device is designed for overvoltage category II zones. Below 2000m altitude the device is tested for impulse withstand voltages up to 4kV, which corresponds to OVC III according to IEC 60664-1. The device is designed as “Class of Protection I” equipment according to IEC 61140. Do not use without a proper PE (Protective Earth) connection. The device is suitable to be supplied from TN, TT and IT mains networks. The continuous voltage between the input terminals and the PE potential must not exceed 300Vac. A disconnecting means shall be provided for the input of the device. The device is designed for convection cooling and does not require an external fan. Do not obstruct airflow and do not cover ventilation grid! The device is designed for altitudes up to 5000m. Above 2000m a reduction in output current is required. Keep the following minimum installation clearances: 40mm on top, 20mm on the bottom, 5mm left and right side. Increase the 5mm to 15mm in case the adjacent device is a heat source. When the device is permanently loaded with less than 50%, the 5mm can be reduced to zero. Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 3/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series The device is designed, tested and approved for branch circuits up to 20A without additional protection device. If an external fuse is utilized, do not use circuit breakers smaller than 16A B- or 10A C-Characteristic to avoid a nuisance tripping of the circuit breaker. The maximum surrounding air temperature is +70°C. The operational temperature is the same as the ambient or surrounding air temperature and is defined 2cm below the device. The device is designed to operate in areas between 5% and 95% relative humidity. Installation Instructions for Hazardous Location Areas The device is suitable for use in Class I Division 2 Groups A, B, C, D locations. Substitution of components may impair suitability for this environment. Do not disconnect the device or operate the voltage adjustment unless power has been switched off or the area is known to be nonhazardous. Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 4/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 3. AC-INPUT AC input Mains network systems AC input range nom. Allowed voltage L or N to earth Input frequency Turn-on voltage Shut-down voltage External input protection Input current Power factor*) Crest factor**) Start-up delay Rise time Turn-on overshoot AC 100-120V ±10% TN, TT or IT 90-132Vac 85-90Vac short-term or with reduced output current 132-150Vac max. 500ms max. 300Vac continuous, IEC 62103 nom. 50–60Hz ±6% typ. 82Vac steady-state value, see Fig. 3-1 typ. 78Vac steady-state value, see Fig. 3-1 See recommendations in chapter 22.3. typ. typ. typ. typ. typ. AC 100V 4.32A 0.61 2.6 250ms 35ms AC 120V 3.71A 0.59 2.8 215ms 35ms typ. 75ms 75ms max. 100mV 100mV at 24V, 10A, see Fig. 3-3 at 24V, 10A, see Fig. 3-4 at 24V, 10A see Fig. 3-2 at 24V, 10A const. current load, 0mF load capacitance, see Fig. 3-2 at 24V, 10A const. current load, 10mF load capacitance,, see Fig. 3-2 see Fig. 3-2 *) The power factor is the ratio of the true (or real) power to the apparent power in an AC circuit. **) The crest factor is the mathematical ratio of the peak value to RMS value of the input current waveform. Fig. 3-1 Input voltage ranges Fig. 3-2 Turn-on behavior, definitions POUT Rated Input Range Output Voltage VIN (85) 90 - 5% Start-up delay Rise Time 132 150Vac Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany Overshoot Turn-on Shut -dow n Input Voltage 5/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series Fig. 3-3 Input current vs. output load at 24V Fig. 3-4 Power factor vs. output load Input Current, typ. Power Factor, typ. 6A 0.65 (a) 5 a) 100Vac b) 120Vac 4 (a) (b) 0.60 (b) 0.55 3 0.50 2 0.45 a) 100Vac b) 120Vac 0.40 1 Output Current 0 2 3 4 5 6 7 8 9 10 11 12A Output Current 0.35 2 3 4 5 6 7 8 9 10 11 12A Fig. 3-5 Input voltage derating Allowable Output Current at 85Vac 12A B 10 A 8 6 A... at 85Vac, continuous B... short term 4 2 Ambient Temperature 0 30 40 50 60 70°C Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 6/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 4. DC-INPUT Do not operate this power supply with DC-input voltage. Use the CP10.241 or CP10.242 units instead. 5. INPUT INRUSH CURRENT A NTC inrush limitation circuit limits the input inrush current after turn-on of the input voltage. The charging current into the EMI suppression capacitors is disregarded in the first microseconds after switch-on. Inrush current Inrush energy AC 100V 90Apeak 71Apeak 6A2s max. typ. max. AC 120V 108Apeak 85Apeak 8.5A2s at +40°C ambient, cold start at +40°C ambient, cold start at +40°C ambient, cold start Fig. 5-1 Typical input inrush current behavior           Input: Output: Ambient: 120Vac 24V, 10A +40°C Upper curve: Medium curve: Lower curve: Time scale: Input current (50A / DIV) Input voltage (100V / DIV) Output voltage (10V / DIV) 20ms / DIV   Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 7/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 6. OUTPUT Output voltage Adjustment range nom. 24V 24-28V guaranteed max. 30V***) at clockwise end position of potentiometer typ. 24.1V ±0.2%, at full load, cold unit, max. 70mV 90-132Vac max. 100mV static value, 0A → 10A; see Fig. 6-1 max. 50mVpp 20Hz to 20MHz, 50Ohm nom. 10A at 24V and up to +60°C ambient temperature, see Fig. 6-1 nom. 7.5A at 24V and +70°C ambient temperature nom. 8.6A at 28V and up to +60°C ambient temperature, see Fig. 6-1 nom. 6.5A at 28V and +70°C ambient temperature Derate linearly between +60°C and +70°C, see chapter 14 nom. 12A at 24V and up to +45°C ambient temperature nom. 10.3A at 28V and up to +45°C ambient temperature, see Fig. 6-1 PowerBoost decreases linearly to nominal power between +45°C and +60°C, see chapter 14 Factory settings Line regulation Load regulation Ripple and noise voltage Output current PowerBoost*) Overload behavior Short-circuit current Output capacitance *) **) ***) min. max. continuous current 14A**) 18A**) see Fig. 6-1 load impedance 2000m, see Fig. 14-2 IEC 62103, EN 50178, altitudes up to 2000m altitudes from 2000m to 6000m IEC 62103, EN 50178, not conductive 15W/1000m or 5K/1000m III II 2 Degree of pollution *) Operational temperature is the same as the ambient or surrounding temperature and is defined as the air temperature 2cm below the unit. **) Do not energize while condensation is present ***) Tested in combination with DIN rails according to EN 60715 with a height of 15mm and a thickness of 1.3mm and standard orientation. Fig. 14-1 Output current vs. ambient temp. (Inom 10A; Iout with PowerBoost = 12A) Allowable Output Current at 24V 12A Fig. 14-2 Output current vs. altitude short t erm continuous 10 Allowable Output Current at 24V 12A D 10 C B A 8 8 6 6 4 4 A... Tamb < 60°C B... Tamb < 50°C C... Tamb < 40°C D... Short t erm 2 2 Ambient Temperature 0 0 20 40 60 70°C Altitude 0 0 2000 4000 Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 6000m 15/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 15. PROTECTION FEATURES Output protection Output over-voltage protection Degree of protection Penetration protection Over-temperature protection Input transient protection Internal input fuse *) Electronically protected against overload, no-load and short-circuits*) typ. 35Vdc In case of an internal power supply defect, a redundant circuit limits the maximum output voltage. The output shuts down and max. 39Vdc automatically attempts to restart. IP 20 EN/IEC 60529 Caution: For use in a controlled environment according to CSA 22.2 No 107.1-01. > 3.5mm e.g. screws, small parts yes Output shut-down with automatic restart MOV (Metal Oxide Varistor) included not user replaceable In case of a protection event, audible noise may occur. 16. SAFETY FEATURES Input / output separation*) Class of protection Isolation resistance PE resistance Touch current (leakage current) SELV PELV double or reinforced insulation I > 5MOhm < 0.1Ohm typ. 0.36mA / 0.91mA typ. 0.50mA / 1.25mA max. 0.45mA / 1.13mA max. 0.62mA / 1.55mA IEC/EN 60950-1 IEC/EN 60204-1, EN 50178, IEC 62103, IEC 60364-4-41 PE (Protective Earth) connection required input to output, 500Vdc between housing and PE terminal 100Vac, 50Hz, TN-,TT-mains / IT-mains 120Vac, 60Hz, TN-,TT-mains / IT-mains 110Vac, 50Hz, TN-,TT-mains / IT-mains 132Vac, 60Hz, TN-,TT-mains / IT-mains Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 16/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 17. DIELECTRIC STRENGTH The output voltage is floating and has no ohmic connection to the ground. Type and factory tests are conducted by the manufacturer. Field tests may be conducted in the field using the appropriate test equipment which applies the voltage with a slow ramp (2s up and 2s down). Connect all input-terminals together as well as all output poles before conducting the test. When testing, set the cut-off current settings to the value in the table below. Type test 60s A 2500Vac B 3000Vac C 500Vac Factory test 5s 2500Vac 2500Vac 500Vac Field test 5s 2000Vac 2000Vac 500Vac Cut-off current setting > 15mA > 15mA > 20mA Fig. 17-1 Dielectric strength Input L N B + A Earth, PE Output - C To fulfil the PELV requirements according to EN60204-1 § 6.4.1, we recommend that either the + pole, the – pole or any other part of the output circuit shall be connected to the protective earth system. This helps to avoid situations in which a load starts unexpectedly or can not be switched off when unnoticed earth faults occur. Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 17/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 18. APPROVED, FULFILLED OR TESTED STANDARDS UL 508 IEC 61010-2-201 IEC 60950-1 UL 60950-1 Class I Div 2 Marine (DNV) Marine (ABS) ISA-71.04 G3 VDMA 24364 UL Certificate Listed equipment for category NMTR - Industrial Control Equipment Applicable for US and Canada E-File: E198865 Manufacturer's Declaration Electrical Equipment for Measurement, Control and Laboratory Use Particular requirements for control equipment CB Scheme Certificate General safety requirements for Information Technology Equipment (ITE) UL Certificate Recognized component for category QQGQ - Information Technology Equipment (ITE) Applicable for US and Canada E-File: E137006 CSA Certificate Power Supplies for Hazardous Location Applicable for Canada and US CSA Class: 5318-01 (Canada), 5318-81 (USA) Temperature Code: T3 Groups: A, B, C and D DNV Certificate DNV Type approved product Certificate: TAA00001ST Temperature: Class B Humidity: Class B Vibration: Class C EMC: Class A Enclosure: Class A ABS Design Assessment Certificate ABS (American Bureau of Shipment) assessed product Certificate: 17-HG1599236-PDA Manufacturer's Declaration (Online Document) Airborne Contaminants Corrosion Test Severity Level: G3 Harsh H2S: 100ppb NOx: 1250ppb Cl2: 20ppb SO2: 300ppb Test Duration: 3 weeks, which simulates a service life of 10 years. Paint Wetting Impairment Substances Test (or LABS-Test) Tested for Zone 2 and test class C1 according to VDMA 24364-C1-L/W for solvents and water-based paints Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 18/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 19. REGULATORY PRODUCT COMPLIANCE EU Declaration of Conformity REACH Regulation (EU) WEEE Regulation The CE mark indicates conformance with the - EMC directive - Low-voltage directive - RoHS directive Manufacturer's Declaration EU regulation regarding the Registration, Evaluation, Authorisation and Restriction of Chemicals (REACH) fulfilled. EU Regulation (EC) 1907/2006. Manufacturer's Declaration EU Regulation on Waste Electrical and Electronic Equipment Registered as business to business (B2B) products. EU Regulation 2012/19/EU Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 19/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 20. PHYSICAL DIMENSIONS AND WEIGHT Width Height Depth Weight DIN rail Housing material Installation clearances 60mm 124mm 117mm The DIN rail depth must be added to the unit depth to calculate the total required installation depth. 700g Use 35mm DIN rails according to EN 60715 or EN 50022 with a height of 7.5 or 15mm. Body: Aluminium alloy Cover: Zinc-plated steel See chapter 2 Fig. 20-1 Front view Fig. 20-2 Side view Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 20/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 21. ACCESSORIES 21.1. ZM1.WALL - WALL MOUNTING BRACKET This bracket is used to mount the power supply onto a flat surface without utilizing a DIN rail. 21.2. ZM13.SIDE - SIDE MOUNTING BRACKET This bracket is used to mount Dimension units sideways with or without utilizing a DIN rail. The two aluminum brackets and the black plastic slider of the unit must be detached so that the steel brackets can be installed. For sideway DIN rail mounting, the removed aluminum brackets and the black plastic slider need to be mounted on the steel bracket. Side mounting with DIN rail brackets Side mounting without DIN rail brackets Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 21/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 21.3. REDUNDANCY MODULES (2x 10A Inputs, 1x 20A output) The YRM2.DIODE is a dual redundancy module, which can be used to build 1+1 and N+1 redundant systems. It is equipped with two input channels, which are individually decoupled by utilizing diodes. The YRM2.DIODE does not require an additional auxiliary voltage and is self-powered even in case of a short circuit across the output. The YRM2.DIODE has a monitoring circuit included and is the perfect solution when the power supply has no DC-OK function. Two LEDs and two relay contacts signal when one of the two DCinput voltages is not in range due to a non-functioning or disconnected power supply. Due to the compact design, the unit is very slender and only requires 32mm width on the DIN rail. 21.4. YR40.241 - REDUNDANCY MODULES (2x 20A input, 1x 40A output) The YR40.241 is a dual redundancy module, which can be used to build redundant systems. It is equipped with two input channels, which are individually decoupled by utilizing MOSFET technology. Using MOSFET instead of diodes reduces the heat generation and the voltage drop between input and output. The YR40.241 does not require an additional auxiliary voltage and is selfpowered even in case of a short circuit across the output. Due to the low power losses, the unit is very slender and only requires 36mm width on the DIN rail. Fig. 21-1 Typical 1+1 Redundant configuration for 10A load current Failure Monitor + + - 24V, 10A + -+ IN 1 IN 2 IN 1IN 2 + + - 24V, 10A CS10 Power Supply YRM2.DIODE CS10 Power Supply L N PE OUT + - L N PE optional I I 10A Load L N PE Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 22/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 22. APPLICATION NOTES 22.1. PEAK CURRENT CAPABILITY The unit can deliver peak currents (up to several milliseconds) which are higher than the specified short term currents. This helps to start current demanding loads. Solenoids, contactors and pneumatic modules often have a steady state coil and a pick-up coil. The inrush current demand of the pick-up coil is several times higher than the steady-state current and usually exceeds the nominal output current (including the PowerBoost). The same situation applies when starting a capacitive load. The peak current capability also ensures the safe operation of subsequent circuit breakers of load circuits. The load branches are often individually protected with circuit breakers or fuses. In case of a short or an overload in one branch circuit, the fuse or circuit breaker need a certain amount of over-current to open in a timely manner. This avoids voltage loss in adjacent circuits. The extra current (peak current) is supplied by the power converter and the built-in large sized output capacitors of the power supply. The capacitors get discharged during such an event, which causes a voltage dip on the output. The following two examples show typical voltage dips: Fig. 22-1 Peak load with 2x the nominal current for 50ms, typ. Output Voltage 24V Fig. 22-2 Peak load with 5x the nominal current for 5ms, typ. 24V Output Voltage 50A 18.5V 20A 12V Output Current 0A 1ms/DIV 10ms/DIV 20A Peak load (resistive) for 50ms Output voltage dips from 24V to 18.5V. Peak current voltage dips Output Current 0A typ. typ. typ. 50A Peak load (resistive) for 5ms Output voltage dips from 24V to 12V. from 24V to 18.5V from 24V to 17V from 24V to 12V at 20A for 50ms, resistive load at 50A for 2ms, resistive load at 50A for 5ms, resistive load Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 23/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 22.2. BACK-FEEDING LOADS Loads such as decelerating motors and inductors can feed voltage back to the power supply. This feature is also called return voltage immunity or resistance against Back- E.M.F. (Electro Magnetic Force). This power supply is resistant and does not show malfunctioning when a load feeds back voltage to the power supply. It does not matter whether the power supply is on or off. The maximum allowed feed-back-voltage is 35Vdc. The absorbing energy can be calculated according to the built-in large sized output capacitor which is specified in chapter 6. 22.3. EXTERNAL INPUT PROTECTION The unit is tested and approved for branch circuits up to 20A. An external protection is only required if the supplying branch has an ampacity greater than this. Check also local codes and local requirements. In some countries local regulations might apply. If an external fuse is necessary or utilized, minimum requirements need to be considered to avoid nuisance tripping of the circuit breaker. A minimum value of 16A B- or 10A C-Characteristic breaker should be used. 22.4. OUTPUT CIRCUIT BREAKERS Standard miniature circuit breakers (MCB’s or UL 1077 circuit breakers) are commonly used for AC-supply systems and may also be used on 24V branches. MCB’s are designed to protect wires and circuits. If the ampere value and the characteristics of the MCB are adapted to the wire size that is used, the wiring is considered as thermally safe regardless of whether the MCB opens or not. To avoid voltage dips and under-voltage situations in adjacent 24V branches which are supplied by the same source, a fast (magnetic) tripping of the MCB is desired. A quick shutdown within 10ms is necessary corresponding roughly to the ride-through time of PLC's. This requires power supplies with high current reserves and large output capacitors. Furthermore, the impedance of the faulty branch must be sufficiently small in order for the current to actually flow. The best current reserve in the power supply does not help if Ohm’s law does not permit current flow. The following table has typical test results showing which B- and C-Characteristic MCBs magnetically trip depending on the wire cross chapter and wire length. Fig. 22-3 Test circuit Power Supply AC MCB + Wire length DC S1... Fault simulation switch *) Load Maximal wire length*) for a fast (magnetic) tripping: 0.75mm² 1.0mm² 1.5mm² C-2A 21m 26m 37m 2.5mm² 68m + C-3A C-4A 15m 10m 21m 14m 30m 20m 51m 38m - C-6A C-8A C-10A 4m 1m 1m 6m 2m 2m 9m 4m 3m 16m 6m 4m B-6A B-10A 13m 10m 18m 5m 26m 9m 42m 11m S1 Don’t forget to consider twice the distance to the load (or cable length) when calculating the total wire length (+ and – wire). Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 24/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 22.5. PARALLEL USE TO INCREASE OUTPUT POWER The power supply shall not be used in parallel to increase the output current. 22.6. PARALLEL USE FOR REDUNDANCY Power supplies can be paralleled for redundancy to gain higher system availability. Redundant systems require a certain amount of extra power to support the load in case one power supply unit fails. The simplest way is to put two power supplies in parallel. This is called a 1+1 redundancy. In case one power supply unit fails, the other one is automatically able to support the load current without any interruption, see also chapter 22.5. Please note: This simple way to build a redundant system does not cover failures such as an internal short circuit in the secondary side of the power supply. In such a case, the defective unit becomes a load for the other power supplies and the output voltage can no longer be maintained. This can be avoided by utilizing redundancy modules, which have decoupling devices (diodes or MOSFETs) included. Further information and wiring configurations can be found in chapter 21.3. Recommendations for building redundant power systems: a) b) c) Use separate input fuses for each power supply. Monitor the individual power supply units. Therefore, use the DC-OK relay contact of the YRM2.DIODE. It is desirable to set the output voltages of all units to the same value (± 100mV) or leave it at the factory setting. 22.7. SERIES OPERATION Unit A Power supplies of the same type can be connected in series for higher output voltages. It is possible to connect as many units in series as needed, providing the sum of the output voltage does not exceed 150Vdc. Voltages with a potential above 60Vdc are no longer SELV and can be dangerous. Such voltages must be installed with a protection against touching. AC Earthing of the output is required when the sum of the output voltage is above 60Vdc. AC DC + + Unit B Avoid return voltage (e.g. from a decelerating motor or battery) which is applied to the output terminals. DC Load + - Earth (see notes) Keep an installation clearance of 15mm (left / right) between two power supplies and avoid installing the power supplies on top of each other. Do not use power supplies in series in mounting orientations other than the standard mounting orientation (input terminals on bottom of the unit). Pay attention that leakage current, EMI, inrush current, harmonics will increase when using multiple power supplies. 22.8. INDUCTIVE AND CAPACITIVE LOADS The unit is designed to supply any kind of loads, including capacitive and inductive loads. 22.9. CHARGING OF BATTERIES The power supply shall not be used to charge batteries. Choose power supplies of the QP-Series or CP-Series for charging batteries. Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 25/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 22.10. USE IN A TIGHTLY SEALED ENCLOSURE When the power supply is installed in a tightly sealed enclosure, the temperature inside the enclosure will be higher than outside. In such situations, the inside temperature defines the ambient temperature for the power supply. The following measurement results can be used as a reference to estimate the temperature rise inside the enclosure. The power supply is placed in the middle of the box, no other heat producing items are inside the box Enclosure: Load: Input: Temperature inside enclosure: Temperature outside enclosure: Temperature rise: 25.6K Rittal Typ IP66 Box PK 9519 100, plastic, 180x180x165mm 24V, 8A; (=80%) load is placed outside the box 120Vac 48.9°C (in the middle of the right side of the power supply with a distance of 2cm) 23.3°C Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 26/27 CS10.243 24V, 10A, 240W SINGLE PHASE INPUT CS-Series 22.11. MOUNTING ORIENTATIONS Mounting orientations other than the input terminals on the bottom require a reduction in continuous output power or a limitation in the maximum allowed ambient temperature. The amount of reduction influences the lifetime expectancy of the power supply. Therefore, two different derating curves for continuous operation can be found below: Curve A1 Recommended output current. Curve A2 Max allowed output current (results in approximately half the lifetime expectancy of A1). Fig. 22-4 Mounting Orientation A (Standard orientation) Output Current 12A OUTPUT A1 9 Power Supply 9 3 Ambient Temperature 0 INPUT 10 Fig. 22-5 Mounting Orientation B (Upside down) 20 30 40 50 60°C Output Current INPUT 12A 9 A2 A1 Pow er Supply 6 3 Ambient Temperature OUTPUT 0 10 Fig. 22-6 Mounting Orientation C (Table-top mounting) 20 30 40 50 60°C Output Current 12A 9 A2 6 A1 3 Ambient Temperature 0 10 40 50 60°C 12A OUTPUT Pow er Supply 9 A2 A1 6 3 Ambient Temperature 0 10 20 30 40 50 60°C Output Current 9 INPUT Pow er Supply 12A OUTPUT Fig. 22-8 Mounting Orientation E (Horizontal ccw) 30 Output Current INPUT Fig. 22-7 Mounting Orientation D (Horizontal cw) 20 A2 A1 6 3 Ambient Temperature 0 10 20 30 40 50 60°C Aug. 2022/ Rev. 2.1 DS-CS10.243-EN All parameters are specified at 24V, 10A, 120Vac, 60Hz, 25°C ambient and after a 5 minutes run-in time unless otherwise noted. www.pulspower.com Phone +49 89 9278 0 Germany 27/27
CS10.243 价格&库存
很抱歉,暂时无法提供与“CS10.243”相匹配的价格&库存,您可以联系我们找货
CS10.243
    • 1+2488.263011+322.31709
