SLR2.100
SLR2.100
    PULS
    AC/DCCONVERTER24V60W
SLR2.100 数据手册
Baby with redundancy CB scheme SLR2.5 IEC60950 Data sheet UL508 LISTED IND. CONT. EQ. 18 WM, 60°C • • • • • • Input: AC 230V/115V, DC 160-375V Output: 24V/2.5A High overload current, no switch-off Quasi-Wide-Range Input N+1 redundancy, RDY relay contact NEC Class 2 Power Supply Input Input voltage The Redundant Variant UL60950 E137006 CUL/CSA-C22.2 No 950-M90 EMC and Low Volt. Directive Output AC100-120/220-240 V (switchable), 47-63 Hz (85-132 VAC / 176-264 VAC, 160-375 VDC, see also „Output: Continuous Loading“) Quasi-Wide-Range Input: With the switch in the 230V position the power-supply unit operates at low and moderate loads at any input voltage between 95 and 264 V AC (see ’Output’ at the right side). Note: At DC input, always leave the switch in the 230V position Input current < 1.3 A (switch in 115V position) < 0.7 A (switch in 230V position) DC input current at open output typ. 5.3 mA at 110 VDC, 3.9 mA at 300 VDC (preserves battery sources) Inrush current typ. < 25 A at 264 V AC and cold start To be fused with a 10A, B-type 'circuit-breaker' switch based on the usual thermomagn. overload sensing principle (used anyway to fuse the input lines). In addition, the unit contains an internal fuse (not accessible) Transient handling Transient resistance acc. to VDE 0160 / W2 (750 V / 1.3 ms), for all load conditions. Hold up time > 20 ms at 196 VAC, 24 V / 2.5 A (see diagram overleaf) Efficiency, Reliability etc.* Rated output voltage 24 V DC For balanced current sharing during parallel operation: Soft characteristic (25.2 V DC ±2% at no-load, 24 V DC ±0.5% at nominal load, almost linear characteristic curve) Output noise suppression Radiated EMI values below EN 61000-6-3, even when using long, unscreened output cables. Ambient temperature Operation: -10°C...+70°C (>60°C: Derating) range Tamb Storage: -25°C...+85°C Switch Continuous loading (at Tamb = -10°C...+60°C, 230V convection cooling), see also diagram overleaf. For start at Tamb 95 V DC needed AC/DCin 176-264 V Iout ACin 2,5 A 95-176 V ACin 1,5 A 160-375 V DCin 2,5 A 120-160 V DCin 2,0 A 80*-120 V DCin 1,5 A Output protected against short circuit, open circuit and overload (at Tamb=+60°C...+70°C) Derating typ. 1.5 W/K Voltage regulation better than 2% Vout overall Ripple / Noise < 30 mVPP, (20 MHz bandw., 50 !"measurem.) Efficiency typ. 86.5 % (230 VAC, 24 V / 2.5 A) Overvolt. protection typ. 32 V Losses typ. 9.4 W (230 VAC, 24 V / 2.5 A) Parallel operation MTBF 700,000 h acc. to Siemensnorm SN 29500 (24 V/2.5 A, 230 VAC, Tamb = +40 °C) yes; current sharing via soft characteristic (see diagram) Power back immunity 26 V Front panel indicator Green LED RDY relay contact • Type • closes • opens • Electrical isolation • Contact rating normally open contact when output voltage > 22.1V ±4% when output voltage < 19.8V ±4% 500V DC to output voltage 1A at 28V DC Life cycle (electrolytics) The unit exclusively uses longlife electrolytics, specified for +105°C (cf. ’The SilverLine’, p.2). Construction / Mechanics* Housing dimensions and Weight • WxHxD • Free space for ventilation • Weight 49 mm x 124 mm x 102 mm (+ DIN rail) above/below 25 mm recommended right 10 mm recommended (front view) 470 g * *For further information see data sheets „The SilverLine“, „SilverLine Family Branches“ and mechanics data sheet Design advantages: • Input and output pluggable by means of Combicon® plug connector. • Ensure strain relief of the plug connectors when installing the unit. • Input and output are strictly apart from each other and so cannot be mixed up (input below, output above). Order information Order number Description SLR2.100 SL2.100 SLZ01 N+1 redundancy* Basic version without redundancy* Screw mounting set, two needed per unit slr2e100 / 040121 1/2 Data sheet Start / Overload Behaviour Start-up delay typ. 0.1 s Rise time ca. 5-20 ms, depending on load 28 Tamb = 60°C / 45°C / 25°C / 0 °C 24 – no disconnection, no hiccup if overloaded – high overload current (up to 1.5 INom), Vout is gradually reduced with increasing current. 20 Output voltage Vout [V] Overload Behaviour • Special PULS Overload Design (see right diagram) Output characteristic (min.) Advantages: • High short-circuit current, giving large ’start-up window’: unit starts reliably even with awkward loads (DC-DC converters, motors). • No ’sticking’ such as can occur with fold-back characteristics • Secondary fuses operate reliably 16 12 8 4 0 0 1 2 3 4 5 6 Output current Iout [A] Further information Output Current over Input Voltage (min.) Further information, especially about • EMC • Connections • Safety, Approvals • Mechanics and Mounting see page 2 of „The SilverLine“ data sheet. 3 DCin 2 Output current Iout [A] 1 For detailed dimensions see SilverLine mechanics data sheet SLR2.5/ 5/ 10 >95 VDC für Start 80 160 100 200 3 Power wiring switch at 115V 400 ACin 2 GND 375 300 Input voltage VDCin [V] switch at 230V 1 +24V 95 85 100 132 + – SLR2.5 176 200 264 300 400 Input voltage VACin [V] Hold-up time (min.) 100 90 DCin Iout=1,0 N L Hold-up time [ms] 80 70 60 Iout=1,5 50 40 30 Iout=2,5 20 10 0 80 120 + – 160 200 240 Input voltage VDCin [V] 100 Hold-up time [ms] N L 80 Iout=1,5 A 70 60 Iout=2,5 A 50 320 Iout=1,0 A ACin 90 SLR2.5 280 40 Switch pos. 115V Iout=1,5 A Iout=2,5 A Switch pos 230V 30 20 10 0 90 120 150 180 Input voltage VACin [V] 210 240 Unless otherwise stated, specifications are valid for AC 230V input voltage, +25°C ambient temperature, and 5 min. run-in time. They are subject to change without prior notice. Your partner in power supply: European Power Supply Manufacturers Association Bayerns Best 50 Czech 100 Best EuropeÕs 500 PULS GmbH Arabellastraße 15 D-81925 München Tel.: +49 89 9278-0 Fax: +49 89 9278-199 www.puls-power.com 2/2 slr2e100 / 040121 Mechanics Data sheet SLR2.5 /SLR5 / SLR10 • Innovative DIN-Rail mount, unit holds even at vibration or lateral pressure • Clearly arranged and user oriented • Large, robust plug connectors • Sealed metal housing • Fine ventilating grid Side view SLR2.5 Front view SLR2.5 Bottom view SLR2.5 102 Construction / Mechanics Connections Housing dimensions and Weight Unit W x H x D [mm] weight • SLR2.5 49 x 124 x 102 470 g • SLR5.100 64 x 124 x 102 620 g • SLR10.10 120 x 124 x 102 980 g Connections • Input • Output • Current handling capacity • Grid stable plug connectors, connector size range: 0.2 – 2.5 mm2 0.2 – 2.5 mm2 , SLR10: 0.2 – 4 mm2 Design advantages: • All connection blocks are easy to reach as mounted at the the front panel. • Input and output are strictly apart from each other and so cannot be mixed up Free space for ventilation left above/below right 0 mm 25 mm each 10 mm 15 mm 25 mm each 15 mm 15 mm 25 mm each 15 mm Overall depth = depth value as mentioned + DIN rail depth Robust metal housing with fine ventilat. grid ( 3,5 mm, IP20), to keep out small parts (e.g. screws) Mounting on DIN-Rail (TS35/7.5 or TS35/15, 1...1.5 mm thick), thus • Simple snap-on system • Sits safely and firmly on the DIN-Rail • No tools required to remove or backplane-mounted (two optional screw mounting sets SLZ01 required) slredrw1 / 040114 12 A each (SLR10: 20 A each) 7.62 mm (input) / 5.08 mm (output) distance between adjacent connectors SLR10: 7.62 mm (output) Order information Order number Description SLR2.5: 24V/2.5A SLR5.100: 24V/5A SLR10.100: 24V/10A SLZ01 Screw mounting set, two needed per unit 1/2 Data sheet Side view and front view SLR5.100 Bottom view SLR5.100 Side view and front view SLR10.100 Bottom view SLR10.100 his ’mechanics data sheet’ exclusively deals with the mechanical properties of the product. For further information (especially concerning electrical properties), please refer to the generic data sheet of the SLR2.5, SLR5.100 and SLR10.100 and to the basic data sheet „The SilverLine“ dealing with common features of all SilverLine units. This data sheet is subject to change without prior notice. Your partner in power supply: European Power Supply Manufacturers Association Bayerns Best 50 Czech 100 Best EuropeÕs 500 PULS GmbH Arabellastraße 15 D-81925 München Tel.: +49 89 9278-0 Fax: +49 89 9278-199 www.puls-power.com 2/2 slredrw1 / 040114
SLR2.100
物料型号:SLR2.5
器件简介:这是一个N+1冗余电源模块,具有高过载电流能力,不自动断开,适用于工业控制设备。
引脚分配:输入和输出通过Combicon®插件连接器进行分配,输入和输出严格分开以避免混淆。
参数特性: - 输入电压:AC 100-240V,DC 160-375V - 输出:24V/2.5A - 效率:典型86.5%,损耗9.4W(230VAC,24V/2.5A) - MTBF:700,000小时(根据西门子标准SN 29500) - 环境温度范围:操作 -10°C...+70°C,存储 -25°C...+85°C
功能详解: - 准宽输入范围,允许在95至264V AC的任何输入电压下工作。 - 辐射EMI值低于EN 61000-6-3标准。 - 瞬态处理符合VDE 0160 / W2标准。 - 保持时间典型值为1.5 W/K。
应用信息:适用于需要高可靠性和冗余电源的工业应用。
封装信息: - 尺寸:49 mm x 124 mm x 102 mm - 重量:470克 - 安装方式:DIN导轨安装或背板安装
SLR2.100 价格&库存
很抱歉,暂时无法提供与“SLR2.100”相匹配的价格&库存,您可以联系我们找货
