SL2.103
SL2.103
    PULS
    AC/DCCONVERTER12V40W
SL2.103 数据手册
12...15 V / 40 W SL2.103 Data sheet EMC and Low Volt. Directive • Input: AC 230V / 115 V, DC 160-375 V • Output: 12...15 VDC / 40 W • High overload current, no switch-off • Robust mechanics and EMC Datasheet Input Input voltage Output AC100-120/220-240 V (switchable), 47-63 Hz (85-132 VAC / 176-264 VAC, 160-375 VDC, see also „Output: Continuous Loading“) Note: At DC input, always leave the switch in the 230V position. Input current < 0.9 A (switch in 115V position) < 0.5 A (switch in 230V position) DC input current at open output typ. 5.3 mA at 110 VDC, 3.9 mA at 300 VDC (preserves battery sources) Inrush current typ. < 25 A at 264 V AC and cold start To be fused with a 10A, B-type 'circuit-breaker' switch based on the usual thermomagn. overload sensing principle (used anyway to fuse the input lines). In addition, the unit contains an internal fuse (not accessible). Output voltage 12...15 V DC, adjustable by (covered) front panel potentiometer; preset: 12 V±0.5% Adj. range guaranteed Output noise suppression Radiated EMI values below EN 61000-6-3, even when using long, unscreened output cables. Ambient temperature range Tamb Operation: -10°C...+70°C (>60°C: Derating) Storage: -25°C...+85°C Continuous loading Switch AC/DCin Iout @ 12V Iout @ 15V (at Tamb = -10°C...+60°C, 230V 176-264 V ≈ 3.0 A 2.7 A convection cooling), 210-375 V = 3.0 A 2.7 A see also diagram overleaf. 160-210 V = 2.0 A 1.8 A For start at Tamb 60 ms at 196 VAC, 12 V / 36 W Voltage regulation better than 2% Vout overall Ripple / Noise < 25 mVPP, (20 MHz bandw., 50 Ω measurem.) Overvolt. protection typ. 21 V, max. 25 V Parallel operation Yes, current sharing on request Power back immunity 20 V Front panel indicator Green LED Efficiency, Reliability etc.* Efficiency typ. 85 % (230 VAC, 12 V / 36 W) Losses typ. 8.2 W (230 VAC, 12 V / 36 W) MTBF 680.000 h acc. to Siemensnorm SN 29500 (12 V / 3 A, 230 VAC, Tamb = +40 °C) Life cycle (electrolytics) The unit exclusively uses longlife electrolytics, specified for +105°C (cf. ’The SilverLine’, p.2). (at Tamb=+60°C...+70°C) Start / Overload Behaviour Startup delay typ. 0.1 s Rise time ca. 5-20 ms, depending on load Overload Behaviour • Special PULS Overload Design (see diagram overleaf) – no disconnection, no hiccup if overloaded – high overload current (up to 1.5 INom). Vout is gradually reduced with increasing current. Advantages: • High short-circuit current, giving large ’start-up window’: unit starts reliably even with awkward loads (DC-DC converters, motors). • No ’sticking’ which can occur with fold-back characteristics • Secondary fuses operate reliably Order information sl2e103 / 040907 Order number Description SL2.103 SLZ01 (Screw mounting set, two needed per unit) 1/2 Data sheet Construction / Mechanics* Efficiency (min.) Housing dimensions and Weight 49 mm x 124 mm x 102 mm (+ DIN rail) • WxHxD above/below 25 mm recommended • Free space for right 10 mm recommended (front view) ventilation 460 g • Weight 90 85 80 Efficiency [%] Design advantages: • All connection blocks are easy to reach as mounted at the front panel. • Input and output are strictly apart from each other and so cannot be mixed up (input below, output above). 75 230V ACin / 12 V DCout 230V ACin / 15 V DCout 70 65 * For further information see data sheets „The SilverLine“, „SilverLine Family Branches“ and mechanics data sheet 60 0,3 0,6 0,9 1,2 1,5 1,8 2,1 2,4 2,7 3 Output current Iout [A] For further information, especially about • EMC • Connections • Safety, Approvals • Mechanics und Mounting, see page 2 of the „The SilverLine“ data sheet. Output characteristic (min.) 18 Tamb = 60°C / 45°C / 25°C / 0°C 15 Vout range For detailed dimensions see SilverLine mechanics data sheet SL2.5/ SL5/ SL10 Output voltage Vout [V] 12 9 6 3 0 0 1 2 3 4 5 6 7 Output current Iout [A] Hold-up time (min., at Vout =12V) 100 100 90 DCin 70 60 ACin Iout=3A 50 40 30 20 Iout=2A Iout=3A 80 Hold-up time [ms] Hold-up time [ms] 90 Iout=2A 80 70 60 Iout=3A Switch pos. 115V 50 40 Switch pos. 230V 30 20 10 10 0 80 120 160 200 Input voltage VDCin [V] 240 280 320 0 90 120 150 180 Input voltage VACin [V] 210 240 Unless otherwise stated, specifications are valid for AC 230V input voltage, +25°C ambient temperature, and 5 min. run-in time. They are subject to change without prior notice. Your partner in power supply: European Power Supply Manufacturers Association Bayerns Best 50 Czech 100 Best Europe’s 500 PULS GmbH Arabellastraße 15 D-81925 München Tel.: +49 89 9278-0 Fax: +49 89 9278-199 www.puls-power.com 2/2 sl2e103 / 040907 Mechanics Data sheet SL2.5/ SL5/ SL10 • Innovative DIN-Rail mount, unit holds even at vibration or lateral pressure • Clearly arranged and user oriented • Large, robust screw terminals • Sealed metal housing • Fine ventilating grid Side view SL2.5 Front view SL2.5 Construction / Mechanics Connections Housing dimensions and Weight Free space for ventilation Unit W x H x D [mm] weight left above/below right • SL2.5 49 x 124 x 102 460 g 0 mm 25 mm each 10 mm • SL5.10x 64 x 124 x 102 620 g 15 mm 25 mm each 15 mm • SL5.300 73 x 124 x 117 730 g 15 mm 50 mm each 15 mm • SL10 120 x 124 x 102 980 g 15 mm 25 mm each 15 mm Overall depth = depth value as mentioned + DIN rail depth Connections • Input/Output • Current handling capacity • Grid Screw terminals, connector size range: solid 0.5- 6 mm2 / flexible 0.5- 4 mm2 30 A per output Two connectors per output, 9 mm distance between adjacent connectors Design advantages: • All connection blocks are easy to reach as mounted at the the front panel. • Input and output are strictly apart from each other and so cannot be mixed up Robust metal housing with fine ventilat. grid ( 3,5 mm, IP20), to keep out small parts (e.g. screws) Mounting on DIN-Rail (TS35/7.5 or TS35/15, 1...1.5 mm thick), thus • Simple snap-on system • Sits safely and firmly on the DIN-Rail • No tools required to remove or backplane-mounted (two optional screw mounting sets SLZ01 required) sledrw1 / 040114 Bottom view SL2.5 Order information Order number Description SL2.100 SL2.103 SL5.100 SL5.102 SL5.105 SL5.300 SL10.100 and SL10.105 SL10.101 SLZ01 24V/2.5A 12-15V/40W 24V/5A 24-28V/120W 24-28V/120W 24-28V/120W, 3AC400-500V input 24-28V/240W 48-56V/240W Screw mounting set, two needed per unit 1/2 Data sheet All views SL5.300 120 Bottom view SL10 SL5.10x Side view and front view SL10, SL5.10x his ’mechanics data sheet’ exclusively deals with the mechanical properties of the product. For further information (especially concerning electrical properties), please refer to the generic data sheet of the SL2.5, SL5 and SL10 and to the basic data sheet „The SilverLine“ dealing with common features of all SilverLine units. This data sheet is subject to change without prior notice. Your partner in power supply: European Power Supply Manufacturers Association Bayerns Best 50 Czech 100 Best EuropeÕs 500 PULS GmbH Arabellastraße 15 D-81925 München Tel.: +49 89 9278-0 Fax: +49 89 9278-199 www.puls-power.com 2/2 sledrw1 / 040114
SL2.103 价格&库存
很抱歉,暂时无法提供与“SL2.103”相匹配的价格&库存,您可以联系我们找货
