SL4.100
SL4.100
    PULS
    AC/DCCONVERTER24V96W
SL4.100 数据手册
4 A with power limitation CB scheme SL4.100 IEC60950 Data sheet UL508 LISTED IND. CONT. EQ. 18 WM, 60°C • • • • • • • Input: AC 230V / 115V, DC 210-375V Output: 24V / 4A 100 VA Limited Power Source No switch-off at overload Quasi-Wide-Range Input Robust mechanics and EMC NEC Class 2 Power Supply Input Input voltage UL60950 E137006 CUL/CSA-C22.2 No 950-M90 EMC and Low Volt. Directive Output AC100-120/220-240 V (switchable), 47-63 Hz (85-132 VAC / 176-264 VAC, 210-375 VDC, see also „Output: Continuous Loading“) Output voltage 24 V DC +5% –1% Output noise suppression Radiated EMI values below EN 61000-6-3, even when using long, unscreened output cables. Quasi-Wide-Range Input: With the switch in the 230V position the powAmbient temperature Operation: -10°C...+70°C (>60°C Derating) er-supply unit operates at low and moderate loads (up to 2 A) at any inrange Tamb Storage: -25°C...+85°C put voltage between 95 and 264 VAC. Note: At DC input, always leave the switch in the 230V position Continuous loading Switch AC/DCin Iout (Tamb = -10°C...+60°C, 230V 176-264 V ACin 4 A Input current < 2.0 A (switch in 115V position) convection cooling), see 95-176 V ACin 3 A < 1.1 A (switch in 230V position) also diagram overleaf 210-375 V DCin 4 A For start at Tamb 20 ms at 196 VAC, 24 V / 4 A (see diagram overleaf) Ripple / Noise < 25 mVPP (20 MHz bandw., 50 !"measurem.) Overvolt. protection typ. 29 V Parallel operation yes Power back immunity 26 V Front panel indicator Green LED on front panel, goes out at Vout < 12 V Efficiency, Reliability etc.* Efficiency typ. 88 % (230 VAC, 24 V / 4 A) Losses typ. 13.6 W Life cycle (electrolytics) The unit exclusively uses longlife electrolytics, specified for +105°C (cf. ’The SilverLine’, p.2). (230 VAC, 24 V / 4 A) Construction / Mechanics* Housing dimensions and Weight 65 mm x 124 mm x 102 mm (+ DIN rail) • WxHxD above/below 25 mm recommended • Free space for left/right 15 mm recommended ventilation 620 g • Weight Start / Overload Behaviour Start-up delay typ. 0.1 s Rise time appr. 5-30 ms, depending on load Overload behaviour Unit fulfills the requirements under Ltd. Power Source acc. to EN60950, para. 2.11, as follows: • Pout • Iout < 100 VA at all load conditions < 8 A at all load conditions Design advantages: • All connection blocks are easy to reach as mounted at the front panel. • Input and output are strictly apart from each other and so cannot be mixed up (Input below, output above). * For further information see data sheets „The SilverLine“, „SilverLine Family Branches“ Order information Order number Description SL4.100 SLZ01 Screw mounting set, two needed per unit sl4e100 / 040121 1/2 Data sheet Output characteristic (typ.) 6 DCin 25 UL Limited Power Source Class 2 4 20 2 Output voltage Vout [V] Output current Iout [A] Output Current over Input Voltage (min.) 210 100 200 375 300 400 Output current Iout [A] Input voltage DCin [V] 6 ACin switch at 115V 4 switch at 230V Pmax 100 W Imax < 8A 15 10 5 2 95 85 132 100 176 200 264 0 300 0 400 2 Input voltage ACin [V] 4 6 Output current Iout [A] 8 10 90 89 88 87 86 85 84 83 82 81 80 Efficiency [%] Efficiency [%] Efficiency (min.) 85 VAC 115 VAC 132 VAC 1 2 3 Output current Iout [A] 4 90 89 88 87 86 85 84 83 82 81 80 5 176 VAC 230 VAC 264 VAC 1 2 3 Output current Iout [A] 4 5 Hold-up time (min.) 100 90 90 80 80 Iout=2A Iout=2A 70 60 Holdu-up time [ms] Hold-up time [ms] 100 Iout=3A 50 40 Iout=4A 30 70 switch pos. 115V Iout=2A Iout=3A Iout=3A 60 50 switch pos. 40 Iout=4A 230V 30 20 20 DCin 10 ACin 10 0 0 130 170 210 250 Input voltage VDCin [V] 290 330 90 110 130 150 170 190 Input voltage VACin [V] 210 230 For further information, especially about • EMC • Connections • Safety, Approvals • Mechanics and Mounting, see page 2 of the „The SilverLine“ data sheet. Unless otherwise stated, specifications are valid for AC 230V input voltage, +25°C ambient temperature, and 5 min. run-in time. They are subject to change without prior notice. Your partner in power supply: European Power Supply Manufacturers Association Bayerns Best 50 Czech 100 Best EuropeÕs 500 PULS GmbH Arabellastraße 15 D-81925 München Tel.: +49 89 9278-0 Fax: +49 89 9278-199 www.puls-power.com 2/2 sl4e100 / 040121 Mechanics Data sheet SL2.5/ SL5/ SL10 • Innovative DIN-Rail mount, unit holds even at vibration or lateral pressure • Clearly arranged and user oriented • Large, robust screw terminals • Sealed metal housing • Fine ventilating grid Side view SL2.5 Front view SL2.5 Construction / Mechanics Connections Housing dimensions and Weight Free space for ventilation Unit W x H x D [mm] weight left above/below right • SL2.5 49 x 124 x 102 460 g 0 mm 25 mm each 10 mm • SL5.10x 64 x 124 x 102 620 g 15 mm 25 mm each 15 mm • SL5.300 73 x 124 x 117 730 g 15 mm 50 mm each 15 mm • SL10 120 x 124 x 102 980 g 15 mm 25 mm each 15 mm Overall depth = depth value as mentioned + DIN rail depth Connections • Input/Output • Current handling capacity • Grid Screw terminals, connector size range: solid 0.5- 6 mm2 / flexible 0.5- 4 mm2 30 A per output Two connectors per output, 9 mm distance between adjacent connectors Design advantages: • All connection blocks are easy to reach as mounted at the the front panel. • Input and output are strictly apart from each other and so cannot be mixed up Robust metal housing with fine ventilat. grid ( 3,5 mm, IP20), to keep out small parts (e.g. screws) Mounting on DIN-Rail (TS35/7.5 or TS35/15, 1...1.5 mm thick), thus • Simple snap-on system • Sits safely and firmly on the DIN-Rail • No tools required to remove or backplane-mounted (two optional screw mounting sets SLZ01 required) sledrw1 / 040114 Bottom view SL2.5 Order information Order number Description SL2.100 SL2.103 SL5.100 SL5.102 SL5.105 SL5.300 SL10.100 and SL10.105 SL10.101 SLZ01 24V/2.5A 12-15V/40W 24V/5A 24-28V/120W 24-28V/120W 24-28V/120W, 3AC400-500V input 24-28V/240W 48-56V/240W Screw mounting set, two needed per unit 1/2 Data sheet All views SL5.300 120 Bottom view SL10 SL5.10x Side view and front view SL10, SL5.10x his ’mechanics data sheet’ exclusively deals with the mechanical properties of the product. For further information (especially concerning electrical properties), please refer to the generic data sheet of the SL2.5, SL5 and SL10 and to the basic data sheet „The SilverLine“ dealing with common features of all SilverLine units. This data sheet is subject to change without prior notice. Your partner in power supply: European Power Supply Manufacturers Association Bayerns Best 50 Czech 100 Best EuropeÕs 500 PULS GmbH Arabellastraße 15 D-81925 München Tel.: +49 89 9278-0 Fax: +49 89 9278-199 www.puls-power.com 2/2 sledrw1 / 040114
SL4.100 价格&库存
很抱歉,暂时无法提供与“SL4.100”相匹配的价格&库存,您可以联系我们找货
