SL5.100
SL5.100
    PULS
    AC/DCCONVERTER24V120W
SL5.100 数据手册
5 A with power boost CB scheme SL5.100 IEC60950 Data sheet UL508 LISTED IND. CONT. EQ. 18 WM, 60°C • • • • • • Input: AC 230V / 115V Output: 24V / 5A Power boost up to 6A High overload current, no switch-off Quasi-Wide-Range Input Robust mechanics and EMC Input Input voltage AC100-120/200-240 V (switchable), 47-63 Hz (85-132 VAC / 176-264 VAC, 210-375 VDC, see also „Output: Continuous Loading“) < 2.6 A (switch in 115V position) < 1.4 A (switch in 230V position) • DCin at open output typ. 5 mA (preserves battery sources) Inrush current EMC and Low Volt. Directive Output Quasi-Wide-Range Input: With the switch in the 230V position the power-supply unit operates at low and moderate loads (until 3 A) at any input voltage between 95 and 264 V AC (see ’Output’ below). Note: At DC input, always leave the switch in the 230V position Input current UL60950 E137006 CUL/CSA-C22.2 No 60950 typ. 15 A at 264 V AC and cold start Output voltage 24 V DC +5% –1% Output noise suppression Radiated EMI values below EN 61000-6-3, even when using long, unscreened output cables. Ambient temperature range Tamb Operation: -10°C...+70°C (>60°C: Derating) Storage: -25°C...+85°C Continuous loading Switch AC/DCin Iout (at Tamb= -10°C...+60°C, 230V 176-264 V ACin 5 A / 6 A * convection cooling), see 95-176 V ACin 3 A also diagram overleaf. 210-375 V DCin 5 A / 6 A * For start at Tamb< 0°C and 150-210 V DCin 3 A low input voltage, please contact PULS. 100-150 V DCin 2 A Output is protected 115V 85-132 V ACin 5 A / 6 A * against short circuit, * short-term 6 A (< 1 min), at 45°C or forced cooling open circuit and overload even continuous To be fused with a 10A, B-type 'circuit-breaker' switch based on the usual thermomagn. overload sensing principle (used anyway to fuse the input lines). In addition, the unit contains an internal fuse (not accessible) Derating typ. 3 W/K EN 61000-3-2 (harmonic current emissions) is fulfilled Voltage regulation better than 2% Vout overall Transient handling Transient resistance acc. to VDE 0160 / W2 (750 V / 1.3 ms), for all load conditions. Ripple / Noise < 50 mVPP, (20 MHz bandw., 50 Ω measurem.) Hold up time > 37 ms at 196 VAC, 24 V / 5 A (see Diagram overleaf) Overvolt. protection typ. 29 V Parallel operation yes; current sharing available on request Power back immunity 26 V Front panel indicator Green LED, goes out at Vout
SL5.100 价格&库存
很抱歉,暂时无法提供与“SL5.100”相匹配的价格&库存,您可以联系我们找货
