SL5.300
SL5.300
    PULS
    AC/DCCONVERTER24V120W
SL5.300 数据手册
3-phase 5 A Data sheet SL5.300 • • • • • • Input: 3 AC 400–500 V Output: 24...28V / 120 W Power boost up to 144 W High overload current, no switch-off 3 phase wide range input Robust mechanics and EMC UL60950 E137006 CUL/CSA-C22.2 No. 60950 UL508 LISTED IND. CONT. EQ. 18 WM, 60°C CB scheme IEC60950 Input Output Input voltage 3 AC 400–500 V, ± 15 % 47-63 Hz, suitable for IT power systems Rated tolerances • Continuous operat. • Short term (1 min.) (at 24V/5A) 340...576 V AC resp. 450...820 V DC 300...620 V AC resp. 420...890 V DC Even if one phase fails, the unit’s operation with nominal current can be continued (limitations: EN 61000-3-2 (harmonic current emissions) is then not fulfilled, the unit has noise suppression level A instead of level B and the hold-up time is shorter). Continued operat. with two phases is also permissible; however, it reduces the unit’s reliability and lifetime. Input current 3 x 0.5 A Inrush current typ. 16 ms (3 phase op. at 400 VAC, 24 V / 5 A) >10 ms (2 phase op. at 400 VAC, 24 V / 5 A) Efficiency, Reliability etc.* Efficiency typ. 89% (3 AC 400V, 24 V / 5 A) Losses typ. 15 W (3 AC 400V, 24 V / 5 A) MTBF 410.000 h acc. to Siemensnorm 29500 (24 V/5 A, 3 AC 400V, TU = 40 °C) Life cycle (electrolytics) The unit exclusively uses longlife electrolytics, specified for +105°C (cf. ’The SilverLine’, p.2). * EMV und Nied.-Spg. Richtlinie For further information see data sheets „The SilverLine“, „SilverLine Family Branches“ and mechanics data sheet (mechanical design equals that of the SL20.100). Start / Overload Behaviour Startup delay typ. 0.1 s Rise time ca. 5-20 ms, depending on load Output voltage 24...28 V DC, adjustable by (covered) front panel potentiometer, preset: 24.5 V ± 0.5% Adjusting range guaranteed Output noise suppression EN 61000-6-3 (class B) is fulfilled even when using long, unscreened output cabels Ambient temperature Operation: -10°C...+70°C (>60°C: Derating) range Tamb Storage: -25°C...+85°C Rated continuous loading with convection cooling Output is protected against short-circuit, open circuit and overload Input Tamb Iout @ 24V Iout @ 28V 3-phase -10°C...+60°C 5 A 4,3 A -10°C...+45°C 6 A* 5,1 A* 2-phase -10...+60 5A 4,3 A DC in -10...+60 5A 4,3 A -10°C...+45°C 6 A* 5,1 A* * * short-term (< 1 min) or with forced air-cooling Derating Voltage regulation Ripple / Noise typ. 6W/K (at Tamb=+60°C...+70°C) better than 2% Vout overall < 25 mVPP, (20 MHz bandw., 50 Ω measurem.) also at 60°C admissible Overvolt. protection typ. 33 V Serial connection Parallel operation Power back immunity not allowed yes; current sharing available on request 34 V; inapplicable for inductive loads Front panel indicator green LED off, at Vout
SL5.300 价格&库存
很抱歉,暂时无法提供与“SL5.300”相匹配的价格&库存,您可以联系我们找货
SL5.300
