SLR10.100
SLR10.100
    PULS
    AC/DCCONVERTER24V240W
SLR10.100 数据手册
Redundancy in square CB scheme SLR10.100 IEC60950 Data sheet UL508 LISTED IND. CONT. EQ. 18 WM, 60°C • • • • • Input: AC 230V/115V, DC 240-375 V Output: 24 V/10 A High overload current, no switch-off N+1 redundancy, RDY relay contact Robust mechanics and EMC Input Input voltage EMC and Low Volt. Directive The Redundant Variant Output AC100-120/220-240 V (switchable), 47-63 Hz (85-132 VAC / 176-264 VAC, 240-375 VDC) Note: At DC input, always leave the switch in the 230V position. Input current UL60950 E137006 CUL/CSA-C22.2 No 950-M90 < 6 A (switch in 115V position) < 2.8 A (switch in 230V position) DCin at open output 8 mA (preserves battery sources) Inrush current typ. < 30 A at 264 V AC and cold start Unit is internally fused (fuse not accessible). External fuse not necessary, but recommended (common 10A, B-type 'circuit-breaker' switch used anyway to fuse the input lines). Transient handling Transient resistance acc. to VDE 0160 / W2 (750 V / 1.3 ms), for all load conditions. Hold-up time > 25 ms at 196 VAC, 24 V / 10 A (see diagram overleaf) Rated output voltage 24 V DC For balanced current sharing during parallel operation: Soft characteristic (25.2 V DC ±2% at no-load, 24 V DC ±0.5% at nominal load, almost linear characteristic curve) Output noise suppression Radiated EMI values below EN50081-1, even when using long, unscreened output cables. Ambient temperature range Tamb Operation: 0°C...+70°C (>60°C: Derating) Storage: -25°C...+85°C Rated continuous loading with convection cooling • Tamb=0°C - 60°C 24 V / 10 A • Tamb=0°C - 45°C 12 A short-term also at 60 °C Output is protected against short circuit, open circuit and overload Derating typ. 12 W/K Efficiency, Reliability etc.* Voltage regulation better than 2% Vout overall Ripple / Noise < 30 mVPP, (20 MHz bandw., 50 !"measurem.) Efficiency typ. 89 % Overvolt. protection typ. 35 V Losses typ. 26.7 W (230 VAC, 24 V / 10 A) Parallel operation MTBF 390.000 h acc. to Siemensnorm SN 29500 (24 V/10 A, 230 VAC, Tamb = +40 °C) yes, current sharing via soft characteristic (see diagram) Front panel indicator Green LED RDY relay contact • Type • closes • opens • Electrical isolation • Contact rating normally open contact when output voltage > 22.1V ±4% when output voltage < 19.8V ±4% 500V DC to output voltage 1A at 28V DC (230 VAC, 24 V / 10 A) Life cycle (electrolytics) The unit exclusively uses longlife electrolytics specified for +105°C (cf. ’The SilverLine’, p.2). Start / Overload Behaviour Start-up delay typ. 0.1 s Rise time ca. 5-20 ms, depending on load Overload Behaviour • Special PULS Overload Design (see diagram overleaf) • 20% power boost * – no disconnection, no hiccup if overloaded – high overload current (up to 1.6 INom), Vout is gradually reduced with increasing current. – 12A short-term, at 45°C or forced cooling even continuous (at Tamb=+60°C...+70°C) For further information see data sheets „The SilverLine“, „SilverLine Family Branches“ and mechanics data sheet Advantages: • High short-circuit current, giving large ’start-up window’: unit starts reliably even with awkward loads (DC-DC converters, motors). • No ’sticking’ such as can occur with fold-back characteristics • Secondary fuses operate reliably Order information Order number Description SLR10.100 SL10.100 SLS10.100 SLZ01 N+1 redundancy* Basic version without redundancy* Safety Cover* Screw mounting set, two needed per unit slr10e100 / 031217 1/2 Data sheet Output characteristic (min.) Construction / Mechanics* 32 Design advantages: • Input and output pluggable by means of Combicon® plug connector • Ensure strain relief of the plug connectors when installing the unit. 28 Tamb = 60°C / 45°C / 25°C / 0°C 24 Output voltage Vout [V] Housing dimensions and Weight 120 mm x 124 mm x 102 mm (+ DIN Rail) • WxHxD above/below 25 mm recommended • Free space for left/right 15 mm recommended ventilation 980 g • Weight 20 16 12 8 Further information 4 0 Further information, especially about • EMC • Connections • Safety, Approvals • Mechanics and Mounting see page 2 of „The SilverLine“ data sheet. 0 5 10 15 Output current Iout [A] 20 25 11 13 Efficiency (typ.) 90 For detailed dimensions see SilverLine mechanics data sheet SLR2.5/ 5/ 10 89 GND +24V 88 Efficiency [%] Power wiring 87 230 V ACin / 24 V DCout 86 SLR10.100 85 3 5 7 9 Output current Iout [A] N L + – Hold-up time (typ.) 60 Partial load 50 Nominal load Partial load SLR10.100 Hold-up time [ms] Nom. load 40 Switch pos. 115V 30 Power Boost Power Boost 20 10 Switch pos. 230V ACin 0 80 N L 100 120 + – 140 160 180 Input voltage VACin [V] 200 220 240 100 90 Partial load 80 Nominal load Hold-up time [ms] 70 60 50 Power Boost 40 30 20 DCin 10 0 210 230 250 270 290 310 330 350 370 390 Input voltage VDCin [V] with Partial Load = 120 W Nominal Load = 240 W Power Boost = 288 W Unless otherwise stated, specifications are valid for AC 230V input voltage, +25°C ambient temperature, and 5 min. run-in time. They are subject to change without prior notice. Your partner in power supply: European Power Supply Manufacturers Association Bayerns Best 50 Czech 100 Best EuropeÕs 500 PULS GmbH Arabellastraße 15 D-81925 München Tel.: +49 89 9278-0 Fax: +49 89 9278-199 www.puls-power.com 2/2 slr10e100 / 031217 Mechanics Data sheet SLR2.5 /SLR5 / SLR10 • Innovative DIN-Rail mount, unit holds even at vibration or lateral pressure • Clearly arranged and user oriented • Large, robust plug connectors • Sealed metal housing • Fine ventilating grid Side view SLR2.5 Front view SLR2.5 Bottom view SLR2.5 102 Construction / Mechanics Connections Housing dimensions and Weight Unit W x H x D [mm] weight • SLR2.5 49 x 124 x 102 470 g • SLR5.100 64 x 124 x 102 620 g • SLR10.10 120 x 124 x 102 980 g Connections • Input • Output • Current handling capacity • Grid stable plug connectors, connector size range: 0.2 – 2.5 mm2 0.2 – 2.5 mm2 , SLR10: 0.2 – 4 mm2 Design advantages: • All connection blocks are easy to reach as mounted at the the front panel. • Input and output are strictly apart from each other and so cannot be mixed up Free space for ventilation left above/below right 0 mm 25 mm each 10 mm 15 mm 25 mm each 15 mm 15 mm 25 mm each 15 mm Overall depth = depth value as mentioned + DIN rail depth Robust metal housing with fine ventilat. grid ( 3,5 mm, IP20), to keep out small parts (e.g. screws) Mounting on DIN-Rail (TS35/7.5 or TS35/15, 1...1.5 mm thick), thus • Simple snap-on system • Sits safely and firmly on the DIN-Rail • No tools required to remove or backplane-mounted (two optional screw mounting sets SLZ01 required) slredrw1 / 040114 12 A each (SLR10: 20 A each) 7.62 mm (input) / 5.08 mm (output) distance between adjacent connectors SLR10: 7.62 mm (output) Order information Order number Description SLR2.5: 24V/2.5A SLR5.100: 24V/5A SLR10.100: 24V/10A SLZ01 Screw mounting set, two needed per unit 1/2 Data sheet Side view and front view SLR5.100 Bottom view SLR5.100 Side view and front view SLR10.100 Bottom view SLR10.100 his ’mechanics data sheet’ exclusively deals with the mechanical properties of the product. For further information (especially concerning electrical properties), please refer to the generic data sheet of the SLR2.5, SLR5.100 and SLR10.100 and to the basic data sheet „The SilverLine“ dealing with common features of all SilverLine units. This data sheet is subject to change without prior notice. Your partner in power supply: European Power Supply Manufacturers Association Bayerns Best 50 Czech 100 Best EuropeÕs 500 PULS GmbH Arabellastraße 15 D-81925 München Tel.: +49 89 9278-0 Fax: +49 89 9278-199 www.puls-power.com 2/2 slredrw1 / 040114
SLR10.100 价格&库存
很抱歉,暂时无法提供与“SLR10.100”相匹配的价格&库存,您可以联系我们找货
