SL20.115
SL20.115
    PULS
    AC/DCCONVERTER24V480W
SL20.115 数据手册
SL20 with remote shut-down CB scheme SL20.115 IEC60950 Data sheet UL508 LISTED IND. CONT. EQ. 18 WM, 60°C • • • • • Input: AC 115/230V auto select Output: 24...28V / 480W (600W) 90% efficiency Ideal for parallel operation Remote shut-down UL60950 E137006 CUL/CSA-C22.2 No 60950 Type approval acc. to: • IEC / EN60950 • EN50178 Overvolt. cat. III • EN60204 EMC and Low Volt. Directive Datasheet Input Input voltage Rated tolerances • Continuous operation • Short-term (1 min) at 24V/20A Input current In Output (signal terminals see overleaf) AC 100-120V/220-240V, 47-63Hz, auto select AC 85...132V resp. AC 184...264V AC 85...140V resp. AC 170...280V
SL20.115 价格&库存
很抱歉,暂时无法提供与“SL20.115”相匹配的价格&库存,您可以联系我们找货
