SL20.100
SL20.100
    PULS
    AC/DCCONVERTER24V480W
SL20.100 数据手册
Single-Phase Power CB scheme SL20.100 IEC60950 Data sheet UL508 LISTED IND. CONT. EQ. 18 WM, 60°C • • • • • Input: AC 230V Output: 24-28V / 480W (600W) 91% efficiency Ideal for parallel operation Simple fusing Input Input voltage EMC and Low Volt. Directive Output AC 230V, +15%, – 20% 47...63Hz (SL20.300/.301: 3 AC 400/480V, see separate data sheet) Rated Tolerances • Continuous operation • Short term (1 min) at 24 V/20 A AC 184...264V resp. DC 270...370V AC 170...280V resp. DC 250...400V Input current 5A Inrush current typ. 33A at AC 264V Inrush current limiting done with a fixed 15R resistor (not a thermistor) which is bridged after the unit is running, so losses are minimised. That means no reset time even at a warm-start. Fuse loading UL60950 E137006 CUL/CSA-C22.2 No 60950 60°C: Derating) Storage: -25°C...+85°C Rated continuous loading with convection cooling • Tamb=0°C - 60°C • Tamb=0°C - 45°C 24V/20A (480W) resp. 28V/18A (504W) 24V/25A (600W) resp. 28V/22A (616W) short-term also at 60°C Derating typ. 12W/K Voltage regulation better than 2% over all Ripple • Output charact. S • Output charact. P (incl. spikes (20MHz bandw.), 50Ω measurem.)
SL20.100 价格&库存
很抱歉,暂时无法提供与“SL20.100”相匹配的价格&库存,您可以联系我们找货
