SL20.113
SL20.113
    PULS
    AC/DCCONVERTER48V480W
SL20.113 数据手册
SL20 with 48...56V CB scheme SL20.113 IEC60950 Data sheet UL508 LISTED IND. CONT. EQ. 18 WM, 60°C • • • • Input: AC 115/230V auto select Output: 48...56V / 480W 93% Efficiency Ideal for parallel operation UL60950 E137006 CUL/CSA-C22.2 No 60950 Type approval acc. to: • IEC / EN60950 • EN50178 Overvolt. cat. III • EN60204 EMC and Low Volt. Directive Datasheet Input Input voltage Rated tolerances • Continuous • Short-term (30s) at 48V/10A Input current In Output AC 100-120V/220-240V, 47-63Hz, auto select Output voltage DC 48...56V, adjustable by (covered) front panel potentiometer; preset: 48V ±0.5% Adjustment range guaranteed AC 85...132V or AC 184...264V AC 85...140V or AC 175...280V Output noise suppression Radiated EMI values below EN50081-1, even when using long, unscreened output cables. Ambient temperature range Tamb Operation: 0°C...+70°C (> 60°C: Derating) Storage: -25°C...+85°C
SL20.113 价格&库存
很抱歉,暂时无法提供与“SL20.113”相匹配的价格&库存,您可以联系我们找货
