SL40.300
SL40.300
    PULS
    AC/DCCONVERTER24V960W
SL40.300 数据手册
Clever Power CB scheme SL40.300/.301 Data sheet • • • • • IEC60950 Input: 3 AC 400...500V Output: 24...28V / 960W (1080W) No switch-off at overload Ideal for parallel operation Output for measurement and logical signals (.301) Input Input voltage 3 AC 400...500 V, – 15 %, + 15 % 47-63 Hz, Suitable for IT power systems 340-575 V AC 300-620 V AC Input current 3.0 A Inrush current < 30 A Inrush current limiting done with a fixed 23R resistor (not a thermistor) which is bridged after the unit is running, so losses are minimized. That means no reset time even at a warm-start. 3 A2s To be fused with a 3 x 10A, B-type 'circuit-breaker' switch based on the usual thermomagnetic overload sensing principle (used anyway to fuse the input lines; unit has no internal fuses). Harmonic current emissions (PFC) acc. EN 61000-3-2 Transient handling Active transient filter incorporated, so transient resistance acc.to VDE 0160 / W2 (1300 V / 1.3 ms), for all load conditions. Hold up time min. 15 ms at 400 V AC, 24 V / 40 A Construction / Mechanics * Housing dimensions and Weight 275 mm x 124 mm x 117 mm (+ DIN rail) • WxHxD above/below each 70 mm recommended • Free space for ventilation left/right each 25 mm recommended • Weight 3.3kg Connections (input and output) UL60950 E137006 CUL/CSA-C22.2 No 950-M90 EMC and Low Volt. Directive Output (signal outputs see overleaf) Rated Tolerances • Continuous operat. • Short term (1 min) at 24 V/40 A Fuse loading UL508 LISTED IND. CONT. EQ. 18 WM, 60°C robust screw terminals, connector size range: • solid: 1.5...6 mm2 (Outp.: 0.5...16 mm2) • flexible: 1.5...4 mm2 (Outp.: 0.5...10 mm2) Output: Minus terminal with 2 connectors, current handling per output: 40 A (max. acc. to UL) resp. 56 A (max. acc. to VDE) Design advantages: • All connection blocks mounted on front panel for ease of access. • PVC insulated cable can be used for all connections, as the connection blocks are mounted in the cooler area on the underside of the unit. • Power density: 230 W per litre housing volume. Output voltage 24...28 V DC, adjustable by (covered) front panel potentiometer. Adj. range guaranteed Output noise suppression Radiated EMI values below EN 61000-6-3, even when using long, unscreened output cables. Ambient temperature range Tamb Operation: 0°C...+70°C (>60°C: Derating) Storage: -25°C...+85°C Rated continuous loading with convection cooling • Tamb=0°C - 60°C 24 V / 40 A (960 W) resp. 28 V / 35 A (980 W) • Tamb=0°C - 45°C 24 V / 45 A (1080 W) resp. 28 V / 38 A (1064 W) short-term (< 1 min.) also at 60°C admissible Derating typ. 24 W/K Voltage regulation better than 2% over all (at Tamb=+60°C...+70°C) Ripple (incl. spikes) < 50 mVPP (20 MHz bandw., 50 Ω measurem.) Over-voltage protection At 32 V ± 10%: switch to hiccup mode Front panel indicators: • Green LED on, when Vout > UT, where UT is ca. 2 V below Vout adjusted (24V...28V) • Red LED on, when Vout< UT Parallel operation SL40.300: yes, no active current sharing SL40.301: yes, active current sharing, please refer to “Output Signaling” - “Current Balance” Current sharing by balancing line (active sharing principle, SL40.301) or ’soft’ output characteristic (passive sharing principle, SL40.300; characteristic switch-over by jumper as in SL20/SL30 without opening the unit) Power Back Immunity < 35 V Efficiency, Reliability etc. * Efficiency typ. 92.5% (400 VAC, 24 V / 40 A) Losses typ 78 W (400 VAC, 24 V / 40 A) MTBF SL40.300: 305,000 h SL40.301: 268,000 h acc. to Siemensnorm SN 29500 (24 V/40 A, 400 VAC, Tamb = +40 °C) Life cycle (electrolytics) The unit exclusively uses longlife electrolytics, specified for +105°C (cf. ’The SilverLine’, p.2). High reliability and lifetime, as • only 6 aluminum electrolytics and • no small aluminum electrolytics are used. Order information Order number Description SL40.300 SL40.301 SLZ01 basic version, passive load sharing with signal/measurement outputs, signal output connector included: Order number XFB-S-W8-MSTB 06-W8) Screw mounting set, two needed per unit sl40e300 / 040211 1/2 Data sheet Start / Overload Behaviour Output V/I characteristic (typ.) < 0.5 s 32 Rise time < 0.1 s (40 A, 20,000 µF) 28 Overload behaviour PULS Overload Design (see diagram at the right), thus neither switch-off nor hiccup at overload 24 Advantages: • High short-circuit current, giving large ’start-up window’: unit starts reliably even with awkward loads (DC-DC converters, motors). No ’sticking’ as can occur with fold-back characteristics. • Even longer overload possible as unit does not switch off. Output voltage Vout [V] Startup delay 20 (SL40.301 only) 0 10 20 30 40 50 Efficiency (typ., at Vout =24V) 94% 92% 90% 88% 3 x 340 VACin 3 x 400 VACin 3 x 480 VACin 86% 84% 82% 5 10 15 20 25 30 35 40 45 Output current Iout [A] Hold-up time (min., at Vout =24V) 80 60 Hold-up time [ms] ’Signal GND’: Ground terminal for all signal outputs of this unit (not ’Current Balance’) • Do not connect this terminal to the terminal of this unit (not even across a load: risk of overload) • Do not connect this terminal to any output of another unit (not even with ’Signal GND’ of another unit) • max. load current: 0.3 A Signal ground is internally fused by a self-curing fuse (polyswitch) Vout=28V, Parallel Mode SL40.301: no switch-over, charact. as SL40.300, Single Mode Output current Iout [A] ’Current Monitor’: Current measurement output, usable with • Voltmeter 1 V per 10 A output current (to ’Signal GND’ output, Rin(voltmeter) > 100 kΩ) • Ammeter 1 mA per 10 A output current (to ’Signal GND’ output, Rin(ammeter) < 100 Ω) ’Current Balance’: balancing output for current sharing • For active current sharing at parallel operation interconnect the "Current Balance" output terminals of all paralleled units. The corresponding ground is the pole. Do not interconnect the "Signal GND" outputs. Exact output voltage regulation is effective when the output current is greater than 0.4A. Current sharing also works reliable with decoupling diodes and modules for redundancy applications. Vout=28V, Single Mode 0 Efficiency [%] ’Thermal Alarm’: warning signal at over-temperature • Signal: High (24 V) at correct operation (no over-temperature). If signal switches to ’low’ and temperature increases further, output current is lowered, • Ground and permissable load resistance: see ’Power Good’ output Vout=24V, Parallel Mode 8 4 ’Power Good’: Power-Fail / -Good • Signal: High (24 V) at correct operation (no overload, over-temp., short-circuit). At ’low’ signal and nominal load, output remains at nominal voltage for at least 5 ms. • Corresponding ground is ’Signal GND’ output (current source) • Permissable load resistance: ≥ 300 Ω, e.g. 24V relais, control lamp (no dropping resistor needed for LED), scoring logic. To get 5V level: connect this output and ’Signal GND’ via 5V zener diode (0.5W) + 1kΩ resistor switched in parallel Vout=24V, Single Mode 12 Output for measurements and signalling ’Shut-Down’: Shut-down input: units switches off, if • Input is connected to ’Signal GND’ (∆U < 1V) or • +20...28 V Voltage are applied to this input and ’Signal GND’ (max. 20 mA). SL40.300: 16 Iout Iout Iout Iout Iout = = = = = 16 A 24 A 32 A 40 A 45 A 40 20 Further Information For further information, especially about EMC, Connections, Safety, Approvals, Mechanics und Mounting see page 2 of the „The SilverLine“ data sheet. For detailed dimensions please see the SilverLine mechanics data sheet SL40. 0 340 380 420 460 500 Input voltage Vin [V] Specifications valid for 3 x AC 400V input voltage, +25°C ambient temperature, and 5 min run-in time, unless otherwise stated. They are subject to change without prior notice. Your partner in power supply: European Power Supply Manufacturers Association Bayerns Best 50 Czech 100 Best EuropeÕs 500 PULS GmbH Arabellastraße 15 D-81925 München Tel.: +49 89 9278-0 Fax: +49 89 9278-199 www.puls-power.com 2/2 sl40e300 / 040211 Mechanics Data sheet SL40 • Innovative DIN-Rail mount, unit holds even at vibration or lateral pressure • Clearly arranged and user oriented • Large, robust screw terminals • Sealed metal housing • Fine ventilating grid Front view SL40.300/ .301 Construction / Mechanics Connections Housing dimensions and Weight 275 mm x 124 mm x 117 mm (+ DIN rail) • WxHxD • Free space for above/below each 70 mm recommended ventilation left/right each 25 mm recommended • Weight 3.3kg Connections • solid • flexible • Current handling capacity • Grid (distance betw. adjacent connectors) Robust metal housing with fine ventilat. grid ( 3,5 mm, IP20), to keep out small parts (e.g. screws) Mounting on DIN-Rail (TS35/7.5 or TS35/15, 1...1.5 mm thick) therefore • Simple snap-on system • Sits safely and firmly on the DIN-Rail • No tools required to remove or backplane-mounted (two optional screw mounting sets SLZ01 required) Design advantages: • All connectors easy to reach as mounted at the front panel. Input and output are strictly apart from each other and so cannot be mixed up • PVC insulated cable can be used for all connections, no thermal protection is needed Order information Order number Description SL40.300 SL40.301 Basic version with signal outputs, signal output connector included: Order number XFB-S-W8-MSTB 06-W8 Screw mounting set, two needed per unit SLZ01 sledrw40 / 040114 Screw terminals, connector size range: 1,5...6 mm2 (Outp.: 0,5...16 mm2) 1,5...4 mm2 (Outp.: 0,5...10 mm2) 40 A each (max. acc. to UL) resp. 56 A (max. acc. to VDE) Output: minus terminal with 2 connectors, 9.52 mm (Input) / 10.16 mm (Output) / 5 mm (Signal output) 1/2 Data sheet Bottom view SL40.300/ .301 SL40.300: Switch for output characteristic (parallel / single mode) SL40.301: Signal output 117 106 5 (18) 62 62 Side view SL40.300/ .301 (69) 111 This ’mechanics data sheet’ exclusively deals with the mechanical properties of the product. For further information (especially concerning electrical properties), please refer to the generic data sheet of this product and to the basic data sheet „The SilverLine“ dealing with common features of all SilverLine units. This data sheet is subject to change without prior notice Your partner in power supply: European Power Supply Manufacturers Association Bayerns Best 50 Czech 100 Best EuropeÕs 500 PULS GmbH Arabellastraße 15 D-81925 München Tel.: +49 89 9278-0 Fax: +49 89 9278-199 www.puls-power.com 2/2 sledrw40 / 040114
SL40.300 价格&库存
很抱歉,暂时无法提供与“SL40.300”相匹配的价格&库存,您可以联系我们找货
SL40.300
