GSM7 Medical
7 Watt Single Output Global Performance Switchers
FEATURES:
World’s smallest medically approved 7 W supply
2.00" x 2.28" x 0.56"
Wide-range ac input (85-264 Vac)
Medical Approval to UL2601-1 and EN60601-1
EMI conducted to CISPR11 Class B
Ideal for ultra-compact applications
marked to LVD
SPECIFICATIONS:
Ac Input
85-264 Vac, 47-63 Hz single phase.
Holdup Time
16 ms minimum from loss of ac.
Output Power
Normal continuous output power is 7 W, 9 W peak for 60 s
maximum duration, 10% duty cycle. Factory set to begin
power limiting at approximately 9 W.
Output Regulation
Regulation from initial setpoint measured by changing
load from no-load to 50% load or 50% load to full load in
either direction. Initial sepoint tolerance is measured at
50% load. No minimum load is required to maintain
proper regulation.
Overload Protection
Fully protected against short circuit and output overload.
Short circuit protection is cycling type power limit.
No Load Turn-on/Standby
Full regulation at no load.
Output Noise
0.5% rms, 1% pk-pk, 20 MHz bandwidth, differential
mode. Measured with scope probe directly across output
terminals of the power supply with load terminated with
0.1 uF capacitor.
Voltage Adjustment
Factory set with fixed resistors to maximize reliability.
Efficiency
72% minimum for the 5.0 V model at full rated load,
nominal input voltage. Efficiency increases as output
voltage increases.
Input Protection
Internal ac fuse provided on all units. Designed to open
only if catastrophic failure occurs in the unit; fuse does not
blow on overload or short circuit. Internal 320 Vac MOV
included. Units will not be damaged when tested for input
transients in accordance with the following standards:
ESD—IEC1000-4-2 Level III
Fast Transient—IEC1000-4-4 Level III
Environmental
Designed for 0 to 50°C operation at full rated output
power; derate output current and total output power by
2.5% per °C above 50°C. See Environmental specification on next page.
Medical EMI/EMC Compliance
All models include built-in EMI filtering to meet the
following emissions requirements:
EMI SPECIFICATIONS
Conducted Emissions
Static Discharge
RF Field Susceptibility
Fast Transients/Bursts
Surge Susceptibility
COMPLIANCE LEVEL
EN55011 Class B; FCC Class B
EN61000-4-2, 6 kV contact, 8 kV air
EN61000-4-3, 3 V/meter
EN61000-4-4, 2 kV, 5 kHz
EN61000-4-5, 1 kV diff., 2 kV com.
Medical Safety
Condor D.C. Power Supplies, Inc. declares under our sole
responsibility that all GSM7 models are in conformity with
the applicable requirements of EN60601-1 following the
provisions of the Low Voltage Directive 73/23/EEC.
All GSM7 models are certified to be in compliance with
the applicable requirements of UL2601-1 (Patient Care
Equipment), CSA 22.2 No. 234 (with additional tests to
C22.2 No 601.1 per T.I.L. CA-08), EN 60601-1. Classification
(in accordance with sub-clause 5 of EN60601-1):
(5.1) Protection against electric shock = class II
(5.2) Degree of protection against electric shock = signal
output or intermediate
(5.3) Protection against harmful ingress of water =
ordinary (no protection)
(5.5) Not suitable for use in the presence of flammable
anesthetic mixture
(5.6) Mode of operation = continuous
Earth Leakage Current
Leakage current measured in ground wire connection to
output common.
Model
Leakage Current* Leakage Current**
Test Voltage
32 µA
50 µA
132 Vac/60 Hz
UL2601-1
GSM7
55 µA
85 µA
264 Vac/50 Hz
IEC601-1
* Normal condition **Single fault condition
14
Test Method
GSM7
Condor D.C. Power Supplies, Inc., 2311 Statham Parkway, Oxnard, CA 93033
800-235-5929 • 805-486-4565 • FAX 805-487-8911 • www.condorpower.com
GSM7 Medical 7 Watt Single Output
Output
Current
Load Regulation
Initial Setpoint
Tolerance
OVP Setpoint
Ripple and Noise
GSM7-5
5.1 V
1.4 A
0.75%
2.5%
6.2 ± 0.6 V
1%
GSM7-12
12 V
0.6 A
0.75%
2.5%
14 ± 1.1 V
1%
GSM7-15
15 V
0.5 A
0.75%
2.5%
18.5 ± 1.5 V
1%
GSM7-24
24 V
0.3 A
0.75%
2.5%
28 ± 2.5 V
1%
GSM7-28
28 V
0.3 A
0.75%
2.5%
34 ± 2.8 V
1%
Model
GSM7 MECHANICAL SPECIFICATIONS
AC NEUTRAL
Environmental
Specification
Operating
Non-operating
Temperature (A)
0 to 50ºC
-40 to +85ºC
0 to 95% RH
0 to 95% RH
20 gpk
40 gpk
Humidity (A)
Shock (B)
Altitude
Vibration (C)
-500 to 10,000 ft
-500 to 40,000 ft
1.5 grms, 0.003 g2/Hz
5 grms, 0.026 g2/Hz
A. Units should be allowed to warm up/operate under non-condensing conditions
before application of power.
B. Random vibration—10 to 2000Hz, 6dB/octave roll-off from 350 to 2000Hz, 3
orthogonal axes. Tested for 10 min./axis operating and 1 hr./axis non-operating.
C. Shock testing—half-sinusoidal, 10 ± 3 ms duration, ± direction, 3 orthogonal
axes, total 6 shocks.
15
很抱歉,暂时无法提供与“GSM7-15”相匹配的价格&库存,您可以联系我们找货
