GLC75-12
GLC75-12
    SLPOWER
    AC/DC CONVERTER 12V 75W
GLC75-12 数据手册
GLC75 Commercial/GLM75 Medical 75 Watt Single Output Global Performance Switchers FEATURES: Cost-effective single-output power source 3.4" x 5.75" x 1.56" (meets 1U applications) Universal input 90-264 Vac 2-year warranty Complies with EN61000-3-2 Class A Also available in multiple output versions Conducted EMI exceeds FCC Class B and CISPR 22 Class B (Commercial models) and CISPR 11 Class B (Medical models) • Commercial & Medical Approved to EN/CSA/IEC/ UL62368-1 • • • • • • • • SPECIFICATIONS: marked to LVD Ac Input 90-264 Vac, 47-63 Hz single phase. Input Current Maximum input current at 120 Vac, 60 Hz with full rated output load not to exceed 2.3 A. Output Power Normal continuous output power is 75 W for unrestricted natural convection cooling; 110 W with 26 cfm airflow. Output Regulation Regulation measured by changing from 5% to 50% load or 50% load to full load in either direction. Overload Protection Factory set to begin power limiting at approximately 120 W (GLC 75-5 is set at approximately 100 W). Fully protected against short circuit and output overload. Short circuit protection is cycling type power limit. Output Noise 0.5% rms, 1% pk-pk, 20 MHz bandwidth, differential mode. Measured with noise probe directly across output terminals of the power supply. Transient Response Main Output: 500 µs typical response time for return to within 0.5% of final value for a 50% load step change, ∆i/ ∆t
GLC75-12 价格&库存
很抱歉,暂时无法提供与“GLC75-12”相匹配的价格&库存,您可以联系我们找货
