MSM7515
MSM7515
    INVENTUSPOWER
    AC/DC CONVERTER 15V 75W
MSM7515 数据手册
MSM75 series 75 Watt Medical Grade Power Supply 5.75" [146.05mm] 0.02" [0.51mm] PIN 1 3.40" [86.36mm] PIN 1 2.90" [73.66mm] 0.154" [3.96mm] 4 PLCS 1.663" [42.24mm] MAX 0.25" [6.35mm] 0.25" [6.35mm] 5.25" [133.35mm] TOLERANCES: X.XX=0.030 [0.76mm] X.XXX=0.010 [0.25mm] Features Electrical Specifications Wide range AC input Fully regulated output High efficiency Medical grade approval Dimensions meet 1U applications 5 year warranty Input Voltage................................ 90-264 VAC Current................................ 1.5 Amp @ 100 VAC Frequency........................... 47 - 63 Hz Earth leakage current.......... 70 uA, 264 V @ 50 Hz (normal condition) Output Line regulation.................... TYP +/- 1% Load regulation................... TYP +/- 3% Hold up time........................ 15 ms min at full load, 115 VAC Transient response............. 2 ms for 50% to 100% load change Over voltage protection....... Built-in Over current protection....... Built-in Short circuit protection........ Pulsing mode, auto recovery Efficiency............................. 80% min at full load and 115 VAC Ripple/noise (Vp-p)............... 1% (20 MHz bandwidth) EMI/EMC Meets FCC class B, CISPR 11 class B EMC per EN60601-1-2 Complies with EN61000-3-2 class A Safety UR/cUR CE Marked Polarity Input P1 Output P2 UL2601-1 EN60601-1-2:2001 1 2 3 4 5 6 7 8 9 Gnd - Neut. - Line - - - - +V +V +V +V Com Com Com Com Pwr Fail Input and Output Connections Input connector = AMP p/n 643495-2 Input mating connector = AMP p/n 640250-5 or equivalent Input mating connector contacts = AMP p/n 770476-1 or equivalent Output connector = AMP p/n 640445-9 Output mating connector = AMP p/n 640250-9 or equivalent Output mating connector contacts = AMP p/n 770476-1 or equivalent Environmental Operating temperature.......... 0 C to 50 C Storage temperature............. -55 C to 85 C Weight = 0.50 lbs Model No. MSM7512 Voltage Power Current 12V 75W 6.3A MSM7515 15V 75W 5A MSM7524 24V 75W 3.1A MSM7528 28V 75W 2.7A Rev 0705 Elpac Power Supplies 1562 Reynolds Ave. Irvine, CA 92614 USA TEL +1 949-476-6070 www.elpac.com info@elpac.com
MSM7515 价格&库存
很抱歉,暂时无法提供与“MSM7515”相匹配的价格&库存,您可以联系我们找货
