GNT428ABTG
GNT428ABTG
    SLPOWER
    AC/DC CONVERTER 28V 400W
GNT428ABTG 数据手册
GNT400 Front End Series 400W AC/DC Universal Input Medical & ITE Power Supply 2 Year Warranty •Medical & and ITE (EN60950) Certifications •Compact 4” x 7” x 1.5” U Channel (1U compatible) •9.5 W/in³ •100-240 VAC Input with Active PFC •12 to 48 V DC Output at 400W (300W convection rating) •5 Vdc, 100 mA Standby Output •12 Vdc Fan Output •Approved to UL, CSA, and EN/IEC Standards •Less than 100µA leakage •Compliance to EN55011/22 Conducted Noise, Class B •RoHS Compliant – Category 6 Specifications All Specifications are typical at nominal input, full load at 25°C unless otherwise stated. AC Input 100-240VAC, 50/60 Hz, 1∅. 90-270VAC, 45-65 Hz max 120VAC: 4.2A. 230VAC: 2.1A Input Current Inrush Current Input Fuses Power Factor Earth Leakage Current Output Power Peak Output Power Output Voltage Voltage Adjustability Minimum Load Total Regulation Transient Response Remote Sense Active Circuit, 37A max. peak F1 and F2, 6.3A/250V for line and neutral 0.99 typical, 0.96 minimum 100µA at 120VAC, 60 Hz Normal 400µA at 264VAC, 50 Hz, SFC 400W continuous with 200lfm airflow See chart for convection ratings 450W for 1 minute, 10% duty cycle See chart ±5% minimum Not required See chart 500µs to 1%, 50% load step, ∆i/∆t < 0.2A/µs Maximum voltage deviation is 3.5% Compensates for up to 500mV voltage drop Turn On Time 500 ms max Hold-up Time 20 ms at 400W Over/Undershoot Overload Protection Overvoltage Protection Ripple and Noise ITE Safety Standards Medical Safety Standards 3.5% max Cycling type, 470W typical See chart 1% pk-pk max., 20MHz BW 0.1µF and 10 µF caps on probe EN/CSA/IEC/UL62368-1 EN/IEC/UL 60601-1, CSA22.2 No. 601-1 Keeping the following components below Thermal Considerations these temp. indicates sufficient cooling: T5: 90°C max., T1: 100°C max Output: 170kHz ±8kHz, PFC: 140kHz ±8kHz Switching Frequency MTBF Overtemperature Protection Efficiency Temperature Coefficient 300K hours per Telcordia Automatic 91% typical at 230VAC 88% typical at 120VAC 0.03% per °C typical on all units Model Number Key GNT 4 XX X X X G RoHS Com pliant Cover Options: Blank = Standard Mini Cover, "E" = Cover w ith fan on the end, "T" = Cover w ith fan on top Output Connections: "B" = Busbars, "T" = Phoenix P/N 1731721 Input Connections: "A" = EBY P/N 5002-03-N-12, "B" = Phoenix P/N 1732034, "C" = AMP P/N 540445-5 (pins 2 & 4 Output Voltage: (See m odels chart below ) Output Pow er (Watts): "4" = 400W Product Fam ily ______________________________________________________________________________________________________________________________ SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com 1 of 4 GNT400 Front End Series 400W AC/DC Universal Input Medical & ITE Power Supply Model Number Volts (V) ┌───── Output Current ─────┐ Convection Fan Cooled 2 Year Warranty Ripple & Noise Total Regulation OVP Threshold GNT412ABG 12V 25.0A 33.3A 120mV ±2% 14.0 ± 1V GNT415ABG 15V 20.0A 26.7A 150mV ±2% 17.6 ± 1V GNT418ABG 18V 16.7A 22.2A 180mV ±2% 20.8 ± 1V GNT424ABG 24V 12.5A 16.7A 240mV ±2% 26.5 ± 1V GNT428ABG 28V 10.7A 14.3A 280mV ±2% 32.0 ± 1V GNT436ABG 36V 8.3A 11.1A 360mV ±2% 39.0 ± 1V GNT448ABG Notes: 48V 6.3A 8.4A 480mV ±2% 55.0 ± 2V 1. 2. 3. When the input voltage is 95% of nominal Always ON, up to 100mA 12Vdc @ 250mA (turns off during inhibit) GNT400 Output Power vs. Line Voltage & Temperature ______________________________________________________________________________________________________________________________ SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com 2 of 4 GNT400 Front End Series 400W AC/DC Universal Input Medical & ITE Power Supply 2 Year Warranty Mounting Options ______________________________________________________________________________________________________________________________ SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com 3 of 4 GNT400 Front End Series 400W AC/DC Universal Input Medical & ITE Power Supply 2 Year Warranty Mounting Options (continued) Data Sheet © 2010 SL Power Electronics Corp. The information and specifications contained herein are believed to be correct at the time of publication. SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice. Rev. 8-27-2010 ______________________________________________________________________________________________________________________________ SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 858.712.2040 • Email: info@slpower.com • www.slpower.com 4 of 4
GNT428ABTG 价格&库存
很抱歉,暂时无法提供与“GNT428ABTG”相匹配的价格&库存,您可以联系我们找货
