MSM6315
MSM6315
    INVENTUSPOWER
    AC/DC CONVERTER 15V 60W
MSM6315 数据手册
MSM63 series 60 Watt Medical Grade Power Supply MM [Inches] Features Electrical Specifications Compact 2 x 4 x 1 inch form factor Wide range AC input, fully regulated output High efficiency Medical grade approvals 5 year warranty Input Voltage................................ 100 - 240 VAC Current................................ Max. 1.2 Amp Frequency........................... 47 - 63 Hz Max. Earth leakage current: Test Voltage Environmental Operating temperature.......... 0 C to 50 C (forced air for full load) Storage temperature............. -20 C to 85 C Weight = 0.27 lbs At least 5 cfm direct forward air flow required to achieve full rating EMI/EMC Meets FCC class B, EN 55011 EMC per EN60601-1-2 Safety UR/cUR CE Marked Polarity Input P1 Output P2 UL2601-1 EN60601-1 Class I 1 2 3 4 5 6 Ntl - Line - - - Com Com - - +V1 +V1 Input and Output Connections Input connector (P1) = V-M Connector Input mating connector = Molex 5195 or 5239 series Output connector (P2) = V-M Connector Output mating connector = Molex 5195 or 5239 series 132 VAC 60 Hz 264 VAC 50 Hz Normal Single-fault 60 uA 100 uA 100 uA 150 uA Output Line regulation.................... TYP +/- 0.5% Load regulation................... TYP +/- 2% Hold up time........................ 11 ms min at full load, 115 VAC Transient response............. 0.5 ms for a 50% load change Over voltage protection....... Built-in Over current protection....... Built-in Short circuit protection........ Built-in Efficiency............................ 80% min at full load and 115 VAC Ripple/noise (Vp-p)............... +/-1% (20 MHz bandwidth) Model No. MSM6312 MSM6315 MSM6324 Voltage Power Current 12V 60W 5.0A 15V 60W 4.0A 24V 60W 2.5A Max output power.........50W with convection cooling; 60W with at least 0.5 CFM forced air cooling Rev 1105 Elpac Power Supplies 1562 Reynolds Ave. Irvine, CA 92614 USA TEL +1 949-476-6070 www.elpac.com info@elpac.com
MSM6315 价格&库存
很抱歉,暂时无法提供与“MSM6315”相匹配的价格&库存,您可以联系我们找货
