GEM600-24G
GEM600-24G
    SLPOWER
    AC/DC CONVERTER 24V 600W
GEM600-24G 数据手册
GEM600 600W Single Output Economy/Technology Switchers Commercial and Medical 2 Year Warranty •600W Single Output AC-DC Power Supply •Universal Input 90-264 VAC •Standard: Active PFC, OVP, Power Fail and Inhibit (low) •Modified and Customized Designs also available •Complies with EMI/RFI Standards •Approved to EN/IEC/UL/CSA 60950-1 for ITE •Approved to EN/IEC/UL60601-1 for Medical • Compliant (LVD, RoHS) Specifications All Specifications are typical at nominal input, full load at 25°C unless otherwise stated. AC Input 90-264VAC, 47-63 Hz single phase. Input Current 120VAC: 9A, 230VAC: 4.5A. Inrush Current Limited by internal thermistor. The inrush at 240VAC, averaged over the first AC half-cycle under cold start conditions will not exceed 40A. Input Fuse F1, F2: 12A, 250VAC fuses provided on all models. Power Factor 0.99 typical, 0.96 minimum. Earth Leakage Current 120VAC: 75µA max. NC, 120µA max. SFC. 264VAC: 160µA max. NC, 300µA max. SFC. Output Power 600W continuous. Peak Output Power 650W for 1 minute, 10% duty cycle. Output Voltage See chart. Voltage Adjustability Adjustable potentiometer, capable of ±5% change from nominal. Minimum Load Not required. Total Regulation See chart. Transient Response 500µs max., 50% load step, ∆i/∆t < 0.2A/µs. Enclosure Dimensions See outline drawing Turn On Time Less than 2 seconds under all rated load conditions. Hold-up Time ≥20 ms from loss of AC input at 600W load, 120VAC input. Over/Undershoot 3.5% max. at turn-on, 1% max. at turn-off. Output Overload & Short Circuit Protection Foldback, then cycle-by-cycle current limiting, automatic recovery. Overvoltage Protection Latching type, recycle AC input to reset. See chart for trip levels. Ripple and Noise 1% pk-pk max., 20MHz BW, differential mode. Measured with noise probe directly across output terminals. ITE Safety Standards CSA/EN/IEC/UL 60950-1 Medical Safety Standards EN/IEC/UL 60601-1 Efficiency >80% typical at full rated load Switching Frequency 140KHz main inverter and 70kHz PFC (synchronized). MTBF 208K hours per Telcordia. Overtemperature Protection Automatic. Weight 3.75 lbs. (1.70kg) Signals AC Power Fail: TTL “0” 10ms before the output drops to
GEM600-24G 价格&库存
很抱歉,暂时无法提供与“GEM600-24G”相匹配的价格&库存,您可以联系我们找货
