AAD130SD-90
AAD130SD-90
    TAMURA
    AC/DC CONVERTER 48V 80W
AAD130SD-90 数据手册
See 3rd page for AAD130SD CODE TABLE AND AVAILABLE OPTIONS. PRODUCT CODE TABLE I. AAD130SD Configured For Single Output Standard Models Tailored Models Custom Models AAD130SD-V W-YYYY AAD130SD- 60ZZZ AAD130SD-61ZZZ Voltage and Current Ratings VW Codes Volts Amps 10 Not Available Not Available 20 3.3 32.0 30 5.0 26.0 40 12.0 12.0 50 15.0 9.5 60 24.0 6.0 70 28.0 5.0 80 36.0 4.0 90 48.0 3.0 Standard Options Y Code Description A Current Sharing B PF Invert C Through Hole Mounting* G = Input and Option Connectors with Gold Pins J = Molex Output Connector with Gold Pins** K = Molex Output Connector with Standard Pins** M = Metric Mounting* O = PF Open Collector *Pemnut chassis mounting is standard **14A MAX current Tailored Units (no safety changes) ------------------------60ZZZ, where ZZZ = Factory Assigned Number. Harnesses Added, Special test data, Etc Custom Units (safety critical changes) ------------------------61ZZZ, where ZZZ = Factory Assigned Number Page 1 of 2 38255 Rev. B PRODUCT CODE TABLE II. AAD130SD Configured For Dual Output Standard Models Tailored Models AAD130SD-V W-YYYY AAD130SD-60ZZZ Voltage and Current Ratings Volts (V1 ) Amps AAD130SD-61ZZZ Standard Options W Channel V Channel V and W Codes Custom Models Volts (V2) Amps 1 Not Available Not Available 2 3.3 16 3.3 16 3 5.0 14 5.0 14 4 12.0 6 12.0 6 5 15.0 5 15.0 5 6 24.0 3 24.0 3 7 28.0 2.5 28.0 2.5 8 36.0 2 36.0 2 9 48.0 1.5 48.0 1.5 Y Code Description A Current Sharing B PF Invert C Through Hole Mounting* G = Input and Option Connectors with Gold Pins J = Molex Output Connector with Gold Pins** K = Molex Output Connector with Standard Pins** M = Metric Mounting* O = PF Open Collector *Pemnut chassis mounting is standard **7A MAX current for V1, V2 outputs Tailored Units (no safety changes) ------------------------60ZZZ, where ZZZ = Factory Assigned Number. Harnesses Added, Special test data, Etc. Custom Units (safety critical changes) ------------------------61ZZZ, where ZZZ = Factory Assigned Number Page 2 of 2 38255 Rev. B
AAD130SD-90 价格&库存
很抱歉,暂时无法提供与“AAD130SD-90”相匹配的价格&库存,您可以联系我们找货
