TWC-050S070SS
TWC-050S070SS
    THOMASRESEARCHPRODUCTS
    LEDDRIVERCCAC/DC36-72V700MA
TWC-050S070SS 数据手册
50W TRC-050 Dimmable Series Switch Mode LED Drivers - Constant Current Electrical Specifications Input Voltage Range: 100 - 277 Nom. Vac (90 - 305 V Min/Max) Frequency: 50/60 Hz Nom. (47-63 Hz Min/Max) Power Factor: >0.90 @ full load, 100V through 277V Inrush Current: 60 A @ 230Vac Input Current: 0.70 A @ 100 Vac, 0.35 A @ 220 Vac Maximum Power: 50W Line Regulation: ± 2% Load Regulation: ± 5% Typical Efficiency 83-89% typical @ maximum load Protection: Over-Voltage, Output Over-Current, Over-Temperature, Output Short Circuit Protection with Auto Recovery Environmental Specifications Minimum Starting Temp: -35ºC Maximum Case Temp. 90°C Storage Temperature: -40ºC to +85ºC Humidity: 10% to 100% Cooling: Convection Sound Rating: Class A MTBF: 487,000 Hours @ 25ºC, 80% load, 110VAC input on 4200 mA output model Lifetime: 66,000 Hours @ 45ºC, 80% load, 110VAC input on 4200 mA output model • Total Power: 50 Watts • Input Voltage: 100-277 Vac Nom. • UL Dry & Damp Location Rated • IP67 • High Efficiency, High Power Factor • Input/Output Protection & Lightning Protection • UL8750 and EN61347 Certified Output Current (mA) Output Voltage Range (Vdc) TRC-050S035DT 350 47-142 50 91% TRC-050S045DT 450 36-110 50 91% Model Number Max. Output Power (W) Typical Efficiency TRC-050S070DT 700 24-72 50 91% TRC-050S110DT 1100 16-48 50 90% TRC-050S140DT 1400 12-36 50 90% TRC-050S175DT 1750 9-29 50 90% TRC-050S210DT 2100 8-24 50 87% TRC-050S280DT 2800 6-18 50 89% TRC-050S333DT 3330 5-15 50 88% TRC-050S420DT 4200 4-12 50 87% US/Canada US Only Class 2: E332160 Note: LED drivers are designed and intended to operate LED loads only. Non-LED loading may be outside the specified design limits of our LED drivers, and therefore cannot be covered by any warranty. If you desire to use our LED drivers to operate non-LED loads please contact us to discuss compatibility. Specifications subject to change without notice. Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com Rev 9-1-15 TRC-050 Dimming Series SSL Solutions Faster Than The Speed Of Light® Pg 2 of 3 AC INPUT (2*AWG18) Dimming Control (3*AWG22) White (ACN) Black (ACL) Green (GND) Yellow (10V) / Purple (1-10V) / Green (Gnd) DC OUTPUT (2*AWG18) Red (+) Black (-) Power Factor / Load 1.00 THD / Load 25% 0.95 120Vac 277Vac 20% 0.90 0.85 15% 0.75 THD PF 0.80 120Vac 277Vac 0.70 0.65 10% 0.60 5% 0.55 0.50 50% 60% 70% 80% Load 90% 100% EN 55015 Conducted emission EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations and flicker EN 61000-4-2 Electrostatic discharge EN 61000-4-3 RFE Field Susceptibility test EN 61000-4-4 Electrical Fast Transient EN 61000-4-5 Surge Immunity test EN 61000-4-6 Conducted Radio Frequency EN 61000-4-8 Power Frequency Magnetic Field Test 70% 80% Load 90% 100% 100% 120Vac 277Vac 95% Efficiency UL 8750, Compliance to UL1310, Class 2 EN 61347-1, EN61347-2-13 60% Typical Efficiency / Load Safety and EMC Compliance CUL CE 0% 50% 90% 85% 80% 75% 70% 60% 70% 80% 90% Normalized Output Voltage 100% EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com TRC-050 Dimming Series SSL Solutions Faster Than The Speed Of Light® Pg 3 of 3 Dimming Control Details Parameters 10V output voltage 10V output source current Absolute maximum voltage on the 0-10V input pin Source current on 0-10V input pin Minimum Typical Maximum 9.8 V -10 mA -2 V 0 mA 10 V — — — 10.2 V 2 mA 15 V 1 mA The dimmer control is operated from either a potentiometer or from an input signal of 1 – 10 Vdc. Recommended implementations are provided below. 10V Output (Yellow) TRC-050xxxxDT Rin 1-10V Input (Purple) GND (Green) 20K Normalized Output Current Option 1 - Potentiometer Control Output Current / Potentiometer 100% 80% 60% 40% 20% 0% 0 1 2 3 1-10V Input (Purple) TRC-050xxxxDT Normalized Output Current Option 2 - DC Input 4 5 6 Vdim (V) 7 8 9 10 Output Current / Dimming Voltage 100% 1-10Vdc V GND (Green) 80% 60% 40% 20% 0% 0 1 2 3 4 5 6 Vdim (V) 7 8 9 10 Notes: 1. For the driver to operate properly, the load voltage must be maintained above the minimum voltage threshold (approx. 33% of the max. output voltage for any given model). 2. If the dimming voltage is varied from 10V down to 0V, the output current can be varied from 100%Io down to 10-20%Io. 3. Do not connect the GND of dimming to the output; otherwise the LED driver can not work normally. Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com
TWC-050S070SS 价格&库存
很抱歉,暂时无法提供与“TWC-050S070SS”相匹配的价格&库存,您可以联系我们找货
