TRC-200S105ST
TRC-200S105ST
    THOMASRESEARCHPRODUCTS
    LEDDRVRCCAC/DC114-190V1.05A
TRC-200S105ST 数据手册
200W TRC-200 Series Switch Mode LED Drivers Constant Current Aluminum Housing Electrical Specifications Input Voltage Range: 100 - 277 Nom. Vac (90 - 305 V Min/Max) Frequency: 50/60 Hz Nom. (47-63 Hz Min/Max) Power Factor: >0.90 @ full load, 100V through 277V Inrush Current: 65 Amps maximum @ 230 Vac, cold start 25ºC Input Current: 2.4 A max 100Vac, 1.2 A max 220Vac Maximum Power: 200W Line Regulation: ± 1% Load Regulation: ± 3% Leakage Current: 1 mA 277 Vac 60Hz Typical Efficiency 89-91% at 277Vac Turn-on Delay: 0.5S typical 110Vac, 0.3S typical 220Vac Ripple and Noise: 3% Vo Protection: Over-Voltage, Over-Temperature (110°C), Lightning, and Short Circuit Protection with Self Recovery Environmental Specifications Minimum Starting Temp: -35ºC Storage Temperature: -40ºC to +85ºC Humidity: 5% to 100% Cooling: Convection Sound Rating: Class A MTBF: 330,000 Hours (450 mA model) @ 110Vac input, 80% load and 25ºC ambient conditions per MIL-HDBK-217F Lifetime: 60,000 Hours @ 220Vac, 80% load and 45ºC ambient Weight: 3.31 lbs. (1.5 kg) • Total Power: 120 Watts • Input Voltage: 100-277 Vac Nom. • UL Dry & Damp Location Rated • IP67 • High Efficiency • High Power Factor with Active Correction • Output and Lightning Protection Standard Versions - Product Specifications Model Number Safety and EMC Compliance UL/CUL UL8750, Compliance to UL1012, CAN/CSA-C22.2 No. 0, CSA-C22.2 No. 107.1-01, CSA-C22.2 No. 250.0 CE EN 61347-1, EN61347-2-13 EN 55015 Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations & flicker EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies to Lighting Equipment Output Current Output Voltage (mA)* Range (Vdc) Max. Output Power (W) Typical Efficiency 93% TRC-200S045ST 450 267-445 200 TRC-200S070ST 700 171-285 200 93% TRC-200S105ST 1050 114-190 200 92% TRC-200S140ST 1400 85-142 200 92% TRC-200S175ST 1750 68-114 200 92% TRC-200S210ST 2100 57-95 200 91% TRC-200S245ST 2450 48-81 200 91% TRC-200S280ST 2800 42-71 200 91% TRC-200S315ST 3150 38-63 200 91% TRC-200S350ST 3500 34-57 200 90% TRC-200S420ST 4200 28-47 200 90% TRC-200S490ST 4900 24-40 200 90% TRC-200S560ST 5600 21-35 200 89% TRC-200S630ST 6300 19-32 200 89% 8330 14-24 Vc 200 88% TRC-200S833ST * The output current is adjustable at factory from 50% to 100%. E332160 Note: LED drivers are designed and intended to operate LED loads only. Non-LED loading may be outside the specified design limits of our LED drivers, and therefore cannot be covered by any warranty. If you desire to use our LED drivers to operate non-LED loads please contact us to discuss compatibility. Specifications subject to change without notice. Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com Rev 9-1-15 TRC-200 Series SSL Solutions Faster Than The Speed Of Light® Pg 2 of 2 INPUT Black (L) White (N) Green (GND) OUTPUT Red (V+) Blue (V-) Tc WIRE SPECS: AC Input: #18AWG DC Output: #18AWG Lifetime / Case Temperature (450mA) 300 250 Lifetime (kHrs) Lifetime (kHrs) 300 200 150 100 50 0 Lifetime / Case Temperature (8330mA) 250 200 150 100 50 35 45 55 65 75 85 Case Hotspot Temperature (°C) 0 95 Derating Curve 40 50 60 70 80 90 Case Hotspot Temperature (°C) Derating Curve 100 80 80 -20 -5 10 25 40 55 Ambient Temperature (°C) 10% 40 100Vac 100Vac (350mA, 450mA) 277Vac 20 120Vac 220Vac 277Vac THD Load (%) 40 THD / Output Voltage 15% 60 60 100 20% Load (%) 100 0 -35 30 5% 20 70 0 90 120 150 180 210 240 Input Voltage (V) 270 300 330 0% 50% 60% 70% 80% 90% Normalized Output Voltage Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com 100%
TRC-200S105ST 价格&库存
很抱歉,暂时无法提供与“TRC-200S105ST”相匹配的价格&库存,您可以联系我们找货
