TRC-050S110SC
TRC-050S110SC
    THOMASRESEARCHPRODUCTS
    LED SUPPLY CC AC/DC 14-40V 1.1A
TRC-050S110SC 数据手册
Thomas Research Products SSL Solutions Faster Than The Speed Of Light ® 50W TRC-050S110SC Total Power: 50 Watts Input Voltage: 100-277 Vac, 50/60 Hz Outputs: Single from 4-142 Vdc High Efficiency Indoor or Outdoor Applications, IP67 High Power Factor Input/Output Protection & Lightning Protection UL8750 and EN61347 Certified Switch Mode LED Drivers - Constant Current Electrical Specifications Input Voltage Range: 100 - 277 Nom. Vac (90 - 305 V Min/Max) or 108-250 Vdc Frequency: 50/60 Hz Nom. (47-63 Hz Min/Max) Power Factor: >0.90 @ full load, 100V through 277V Inrush Current: 60 A @ 230Vac Input Current: 0.54 A @ 100 Vac, 0.35 A @ 220 Vac Maximum Power: 50W Line Regulation: ± 3% Load Regulation: ± 5% Protection: Over-Voltage, Over-Current, Over-Temperature, Short Circuit Protection with Auto Recovery Environmental Specifications Operating Temperature: -35ºC to +90ºC Maximum Case Temp. 90°C Storage Temperature: -40ºC to +85ºC Humidity: 10% to 100% Cooling: Convection MTBF: 487,000 Hours @ 25ºC, 80% load, 110Vac input Lifetime: 66,000 Hours @ 45ºC, 80% load, 110Vac input Part Number Output Current (mA) Output Voltage Range (Vdc) TRC-050S110SC 1100 14-40 Output Power Max (W) 50W 90% Class 2: AC INPUT (3*AWG18) 172±0.5 168±0.5 42.5 Red (+) Black (-) 50±5 310±20 34.4 300±20 50±5 US/Canada Safety and EMC Compliance 34.5 DC OUTPUT (2*AWG18) 10±2 10±2 Black (ACL) White (ACN) Green (GND) Typical Efficiency CUL CE UL 8750, Compliance to UL1310, Class 2 EN 61347-1, EN61347-2-13 EN 55015 Conducted emission EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations and flicker EN 61000-4-2 Electrostatic discharge EN 61000-4-3 RFE Field Susceptibility test EN 61000-4-4 Electrical Fast Transient EN 61000-4-5 Surge Immunity test: AC Power Line; Line to line 2kV, Line to ground 4kV EN 61000-4-6 Conducted Radio Frequency EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Lifetime / Case Temperature E332160 Note: LED drivers are designed and intended to operate LED loads only. Non-LED loading may be outside the specified design limits of our LED driver, and therefore cannot covered by any warranty. If you desire to use our LED drivers to operate non-LED loads please contact us to discuss compatibility. Lifetime (kHrs) 300 250 200 150 100 50 0 45 55 65 75 Case Hotspot Temperature (°C) Specifications subject to change without notice. Thomas Research Products • 11548 Smith Dr. • Huntley, IL 60142 • T: 847-515-3057 • F: 847-515-3047 • www.trpssl.com 85 5-21-13
TRC-050S110SC 价格&库存
很抱歉,暂时无法提供与“TRC-050S110SC”相匹配的价格&库存,您可以联系我们找货
