LMD800-0120-C2A0-7030000
    WOLFSPEED
    LED DRIVER CC AC/DC 25-52V 2A
LMD800-0120-C2A0-7030000 数据手册
Cree® LMD800 LED Module Driver PRODUCT DESCRIPTION FEATURES TABLE OF CONTENTS Cree® LED modules provide lighting • Input voltage: 120‑277 V Order Code...................................................2 designers and manufacturers with simple, • 0/1-10 V dimming support Characteristics - LMD800 120- to 277‑V easy-to-adopt LED lighting solutions that • Optimized for Cree LMH2 8000‑lm 0/1-10 V Dimming Driver.............................2 reduce luminaire development time and speed time-to-market. The Cree LMD800 ® LED module driver is specifically designed light sources • Enables California Title 24 compliance CLM-DS23 REV 0F LED MODULE DRIVER DATA SHEET Dimming.......................................................2 Mechanical Dimensions..............................2 Wiring Diagrams...........................................4 to work with the Cree LMH2 8000‑lumen Thermal Design............................................5 light source to jump-start the design Emergency Battery Operation.....................5 process for recessed downlights, wall Safety and Regulatory Notes.......................5 sconces or pendant lights in demanding Packaging.....................................................6 end markets such as retail, museums, WWW.CREE.COM/XLAMP hospitality and restaurants. Copyright © 2014-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 LMD800 LED MODULE DRIVER ORDER CODE Nominal Input Voltage (VAC) Frequency (Hz) Typical Output Current (mA) Dimming Order Code 120-277 50/60 2000 0/1-10 V LMD800-0120-C2A0-7030000 CHARACTERISTICS - LMD800 120- TO 277‑V 0/1-10 V DIMMING DRIVER Order Code: LMD800-0120-C2A0-7030000 Characteristics Unit Minimum Input voltage range VAC 108 Input power Output current mA V Driver efficiency (@ 55 °C) - with LMH2 8000‑lm light source % Maximum 105 130 305 W Output voltage Typical 2000 28 54 90 Power factor - with LMH2 8000‑lm light source 0.95 Dimming current @ 120 V mA .05 Dimming current @ 277 V mA .05 LED driver case temperature °C • -40 75 3-D models (.STEP files) for the LMD800 LED module driver are available on the Cree website by selecting the Documentation tab on the LMH2 product page. DIMMING The LMH2 8000‑lm light source can use the LMD800 LED module driver with 0/1-10 V dimming. Driver LMD800-0120-C2A0-7030000 Input Voltage Dimming Lowest Light Level 120-277 V 0/1-10 V 1% MECHANICAL DIMENSIONS Physical Characteristics of the LMD800 Driver Physical Characteristic LMD800 120- to 277-V Driver Weight (g) 440 Maximum height (mm) 47 Maximum length (mm) 160 Maximum width (mm) 63 Copyright © 2014-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 2 LMD800 LED MODULE DRIVER LMD800 120- to 277-V Driver1 160 160 61.6 61.6 23 23 50 50 1 47 47 Tc Tc 6-32 6-32 MOUNTING MOUNTING STUDS STUDS 39 39 88 WIRE LL == 150mm 150mm WIRE TYP. TYP. 1144 ..44 50.8 50.8 63 63 Dimensions for all the diagrams are in mm and are for reference only. For exact dimensions and tolerances, refer to the 3-D models (.STEP files) for the LMD800 driver available by selecting the Documentation tab on the LMH2 product page. Copyright © 2014-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 3 LMD800 LED MODULE DRIVER WIRING DIAGRAMS Electrical Connection LMH2 LED module operation is accomplished by connecting the AC mains to the two (2) lead wires (line and neutral) from the driver and connecting the driver output wires to the input leads on the Cree LMH2 light source, as indicated in the following wiring diagram. The LED module driver lead wires are 150 mm long, 18 AWG with the ends stripped 10 mm. LMD800 120- to 277‑V Driver Wiring Strain Relief LMD800 LED module drivers must not be suspended directly by the leads. Though the wiring from the LMD800 LED module driver is internally strain relieved, additional strain relief methods must be employed if the luminaire is to be suspended solely by the wiring, as in a pendant luminaire. Copyright © 2014-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 4 LMD800 LED MODULE DRIVER THERMAL DESIGN Expected LMD800 Lifetime versus Temperature at Tc Point Tc (°C) @ 25 °C Room Ambient Expected Operation Life (Hours) LMD800 120- to 277-V 0/1-10 V Dimming Driver 50,000 75 EMERGENCY BATTERY OPERATION The LMD800 LED module driver is a constant‑current supply. Interrupting the driver current with a battery supply is an acceptable method of emergency or power outage operation. An acceptable installation should also include a switching mechanism that prevents the battery power from entering the driver through the DC output leads. Confirming backup power supply compatibility is the responsibility of the luminaire manufacturer or installer. Please refer to the backup power supply manufacturer’s instructions for installation and further product information. SAFETY AND REGULATORY NOTES The following table shows the safety and regulatory certifications for the LMD800 LED module driver. LMD800 120- to 277‑VAC Driver Standard File Number UL/cUL recognized (UL8750) LVLE for US and Canada UL – Damp rated E333437 Air handling (plenum) Safety 5VA flame rating EN 61347-1 EN 61347-2-13 CE SELV equivalent IP-20 EN 55015 IEC 61000-3-2 Electromagnetic compatibility IEC 61000-3-3 IEC 61547 FCC 47 CFR Part 15 Class B/ ICES 03 Regulatory Environmental E1/2014/60038 E1/2014/60036C E1/2014/60037 IEEE C.62.41-1991 Class A (surge) NEMA 410 RoHS Copyright © 2014-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 5 LMD800 LED MODULE DRIVER Safety Certification Together, the LMH2 light source combined with the LMD800 LED module driver is “suitable for damp locations; covered ceilings.” Final luminaire designs should go through safety certification as required, which is the responsibility of the luminaire manufacturer. PACKAGING LMD800 120- to 277–V LED module drivers are packaged in boxes of 5, which are then combined in cartons of 5 boxes, or 25 LMD800 120- to 277–V drivers. Box and carton sizes are as follows. Box of 5 LMD800 120- to 277‑V LED module drivers: 490 x 235 x 90 mm Carton of 5 LMD800 120- to 270‑V driver boxes: 510 x 510 x 255 mm Copyright © 2014-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 6 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Cree, Inc.: LMD800-0120-C2A0-7030000
LMD800-0120-C2A0-7030000 价格&库存
很抱歉,暂时无法提供与“LMD800-0120-C2A0-7030000”相匹配的价格&库存,您可以联系我们找货
