LE150S140CD
LE150S140CD
    SLPOWER
    LED SUPP CC AC/DC 53-107V 1.47A
LE150S140CD 数据手册
150W Single Output LED Driver Series LE150-CD Family FEATURES AND BENEFITS LED High Efficiency (up to 93%) Dimming Function Wide Range Universal Input 90-305 VAC Meets UL8750 & EN61347 Safety Active Power Factor Correction (0.99 typical) Lightning Protection Constant Current Output Waterproof (IP67) Overcurrent, Overvoltage, Overtemperature Protection Minimum of 3 Year Warranty, Consult factory for 5 Years MODEL SELECTION Model Number Output Current Output Voltage LE150S140CD 1330mA - 1470mA 53V - 107V 89% - 90% 91% - 92% LE150S70CD 665mA - 735mA 107V - 214V 90% - 91% 92% - 93% Ripple & Noise** Regulation Line Load Overvoltage Trip Level 3.2V pk - pk max. ±1% ±3% 128V - 161V 6.5V pk - pk max. ±1% ±3% 257V - 321V Efficiency* 110Vac 220Vac Notes: 1. Efficiency measured at full load, at input voltage noted. 2. Measured at 20MHz bandwidth, with noise probe directly across output terminals, and load terminated with 0.1μF ceramic and 10μF low ESR electrolytic capacitors. INPUT OUTPUT AC Input 90-305Vac, 47-63Hz, 1Ø Input Current 100Vac: 1.8A, 220Vac: 0.9A Inrush Current 230Vac, cold start: will not exceed 65A Input Fuses XA, 250VAC fuses provided on all models Earth Leakage Current
LE150S140CD 价格&库存
很抱歉,暂时无法提供与“LE150S140CD”相匹配的价格&库存,您可以联系我们找货
