LE150S24VN
LE150S24VN
    SLPOWER
    LED SUPPLY CV AC/DC 24V 6.25A
LE150S24VN 数据手册
150W Single Output LED Grade LE150-VN Family FEATURES AND BENEFITS LED High Efficiency (up to 93%) Waterproof (IP67) Wide Range Universal Input 90-305 VAC Lightning Protection Active Power Factor Correction (0.99 typical) Minimum of 3 Year Warranty, Consult factory for 5 Years Constant Voltage Output SELV Overcurrent, Overvoltage, Overtemperature Protection Meets UL8750, UL935 & EN61347 Safety MODEL SELECTION Ripple & Noise** Efficiency* 110Vac 220Vac Efficiency* Line Load Overvoltage Trip Level Model Number Output Current Output Voltage LE150S24VN 0 - 6.25A 24Vdc 89% - 90% 92% - 93% 2% of Vo pk-pk ±1% ±2% 110% - 130% of Vo LE150S48VN 0 - 3.13A 48Vdc 89% - 90% 92% - 93% 2% of Vo pk-pk ±1% ±2% 110% - 130% of Vo Notes: 1. Efficiency measured at full load, at input voltage noted. 2. Measured at 20MHz bandwidth, with noise probe directly across output terminals, and load terminated with 0.1μF ceramic and 10μF low ESR electrolytic capacitors. INPUT OUTPUT AC Input 90-305Vac, 47-63Hz, 1Ø Hold-up Time 20 mSec Input Current 100Vac: 1.75A, 220Vac: 0.8A Turn On Time 1.5 seconds, max. Inrush Current 230Vac, cold start: will not exceed 65A Dimming Function Input Fuses XA, 250VAC fuses provided on all models 1-10Vdc source or External Resistor can be used for dimming control. See below Earth Leakage Current Output Power 150W continuous
LE150S24VN 价格&库存
很抱歉,暂时无法提供与“LE150S24VN”相匹配的价格&库存,您可以联系我们找货
