TSC-075S315DT
TSC-075S315DT
    THOMASRESEARCHPRODUCTS
    LEDDRIVERCCAC/DC12-24V3.15A
TSC-075S315DT 数据手册
TSC-75W Series Dimmable LED Drivers Constant Current Aluminum Housing Electrical Specifications Input Voltage Range: 277 - 480 Nom. Vac (249 - 528 V Min/Max) Frequency: 50/60 Hz Nom. (47-63 Hz Min/Max) Power Factor: >0.90 @ full load, 277V through 480V Inrush Current: 135.0 Amps max @ 480 Vac, cold start 25ºC Input AC Current: 0.34 A max 277VAC, 0.21 A max 480Vac Maximum Power: 75W Line Regulation: ± 1% Load Regulation: ± 3% THD: < _ 20% @ full load Leakage Current: 0.7 mA 480 Vac 50Hz Typical Efficiency 85-87% at 480Vac Turn-on Delay: 1 S typical Output Current Ripple: 20% Output Protection: Over-Voltage, Over-Temperature, and Short Circuit Protection Environmental Specifications Minimum Starting Temp: -40ºC Maximum Case Temp. 90°C Storage Temperature: -40ºC to +85ºC Humidity: 5% to 100% Cooling: Convection Sound Rating: Class A MTBF: 380,000 Hours (700 mA model) at 480Vac input, 80% load and 25ºC ambient conditions per MIL-HDBK-217F Lifetime: 50,000 Hours @ Case Temperature = 60ºC Weight: 2.2 lbs. (1.0 kg) • Total Power: 75 Watts • Input Voltage: 277-480 Vac Nom. • UL Dry, Damp & Wet Location Rated • IP67 • High Power Factor • UL Type HL Rated * UL8750 Constant Current - Product Specifications Model Number Output Current Output Voltage (mA ±5%) Range (Vdc) Max. Output Power (W) Typical Efficiency TSC-075S035ST 350 107-214 75 87% TSC-075S070ST 700 53-107 75 86% TSC-075S105ST 1050 36-72 75 87% TSC-075S140ST 1400 26-53 75 87% TSC-075S210ST 2100 18-36 75 86% TSC-075S315ST 3150 12-24 75 85% Dimming Versions - Product Specifications Model Number E332160 Output Current Output Voltage (mA ±5%) Range (Vdc) Max. Output Power (W) Typical Efficiency TSC-075S035DT 350 107-214 75 87% TSC-075S070DT 700 53-107 75 86% TSC-075S105DT 1050 36-72 75 87% TSC-075S140DT 1400 26-53 75 87% TSC-075S210DT 2100 18-36 75 86% TSC-075S315DT 3150 12-24 75 85% US/Canada US Only The output current is adjustable at factory from 50% to 100%. Class 2: Note: LED drivers are designed and intended to operate LED loads only. Non-LED loading may be outside the specified design limits of our LED drivers, and therefore cannot be covered by any warranty. If you desire to use our LED drivers to operate non-LED loads please contact us to discuss compatibility. Specifications subject to change without notice. Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com Rev 6-6-16 TSC 75W Series SSL Solutions Faster Than The Speed Of Light® Pg 2 of 3 Dimensions - mm 50±5 15±2 220±20 70 Black (ACL) White (ACN) Green (GND) Red (V+) Blue (V-) 88.9 AC INPUT (3*AWG18) 38.1 15 DC OUPUT (2*AWG18) Tc = 90°C max 230±20 115 12 650±20 30±2 40±2 50±2 5±1 15±2 50±5 86 222 188 184 Dimming Control (3*AWG22) Purple (Dim+) Gray (Dim-) Black/White (VC) 45 202 45 4.4 Ø9.5 Derating Curve 100 120 Lifetime (kHrs) 105 Load (%) 80 60 40 20 0 Lifetime / Case Temperature 135 90 75 60 45 30 15 -10 0 10 20 30 40 50 Ambient Temperature (°C) 60 70 0 30 35 40 45 50 55 60 65 70 75 80 85 90 Case Temperature (°C) Efficiency / Load Power Factor / Output Voltage 1.00 0.95 90% Efficiency 0.90 0.85 PF 350mA Model 95% 0.80 0.75 277 Vac 480 Vac 0.70 0.65 0.60 50% 60% 70% 80% 90% Normalized Output Voltage 85% 80% 277 Vac 480 Vac 75% 100% 70% 50% 60% 70% 80% Load 90% 100% Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com TSC 75W Series SSL Solutions Faster Than The Speed Of Light® Pg 3 of 3 Dimming Control Parameters 12V output voltage Vc source current Absolute maximum voltage on the 0~10V input pin Source current on 0~10V input pin Minimum Typical Maximum 10.8 V 10 mA -2 V 150 µA 12 V 15 mA — 200 µA 13.2 V 20 mA 15 V 250 µA The dimmer control is operated from an input signal of 1 – 10 Vdc. V+ (Red) Vac L V- (Blue) N Vc (Black/White) TSC-75xxxDT G Output Current/Dimming Voltage 100% Dim+ (Purple) Dim- & Vc Return (Gray) Normalized Output Current Implementation with 0-10V Dimming 0-10V Dimmer 80% 60% 40% 20% 0% 0 1 2 3 4 5 6 7 Dimming Voltage (V) 8 9 10 Notes: 1. The dimmer can also be replaced by an active 0-10V voltage source signal or passive components like resistors and zener. 2. The dimming signal is allowed to be less than 1V, when it is between 0 and 1V, the output level is 10%. 3. Do NOT connect the Gray Wire (Vdim-) to Blue Wire (V-) together. 4. The dimming section is not isolated from the output. 5. Vc is an auxillary 12V/15mA output. 6. If 0-10V dimming is not used, Dim+ can be either capped-off or connected to Vc. Safety Certification Standard UL/CUL CE UL8750, UL1310, UL1012, CAN/CSA-C22.2 No. 223-M91, CSA-C22.2 No. 107.1-01 EN 61347-1, EN61347-2-13 EMC Standard Notes EN 55015 EN 61000-3-2 EN 61000-3-3 EN 61000-4-2 EN 61000-4-3 EN 61000-4-4 EN 61000-4-5 EN 61000-4-6 EN 61000-4-8 EN 61000-4-11 EN 61547 Conducted emission Test & Radiated emission Test with 6 dB margin Harmonic current emissions: Class C Voltage fluctuations & flicker Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge Level 3, Criteria A Radio-Frequency Electromagnetic Field Susceptibility Test-RS Level 3, Criteria A Electrical Fast Transient / Burst-EFT Level 3, Criteria A Surge Immunity Test: AC Power Line: line to line 4kV, line to earth 6 kV Conducted Radio Frequency Disturbances Test-CS Level 3, Criteria A Power Frequency Magnetic Field Test 3A/m , Criteria A Voltage Dips Criteria B Electromagnetic Immunity Requirements Applies To Lighting Equipment Note: Disconnect power to LED driver for at least 30 seconds before connecting or disconnecting Driver output and LED Engine. This prevents potential arcing transients that can damage the Engine and Driver. See Hot Plugging in our Driver Application Guide for more information. Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com
TSC-075S315DT 价格&库存
很抱歉,暂时无法提供与“TSC-075S315DT”相匹配的价格&库存,您可以联系我们找货
