TRV-150S024ST
TRV-150S024ST
    THOMASRESEARCHPRODUCTS
    LEDDRIVERCVAC/DC24V6.25A
TRV-150S024ST 数据手册
150W TRV-150 Series Switch Mode LED Drivers Constant Voltage Aluminum Housing Electrical Specifications Input Voltage Range: 100 - 277 Nom. Vac (90 - 305 V Min/Max) Frequency: 50/60 Hz Nom. (47-63 Hz Min/Max) Power Factor: 0.90 @ 75-100% load, 100-277V THD: < _ 20% @ 75-100% load, 100-277V Inrush Current: 65 Amps maximum @ 230 Vac, cold start 25ºC Input Current: 1.75 A max 100Vac, 0.8 A max 220Vac Maximum Power: 150W Line Regulation: ± 1% Load Regulation: ± 2% Leakage Current: 1 mA 277 Vac 60Hz Typical Efficiency 92.5%-93.5% at 220Vac Turn-on Delay: 0.9S typical 110Vac, 0.5S typical 220Vac Ripple and Noise: 2% Vo Protection: Over-Voltage (latch mode), Over-Temperature (110°C), Over-Current (hiccup mode), Lightning, and Short Circuit Protection with Self Recovery • Total Power: 150 Watts • Input Voltage: 100-277 Vac Nom. • UL Dry & Damp Location Rated • IP67 • Ultra-high Efficiency • High Power Factor • UL8750 Environmental Specifications Minimum Starting Temp: -35ºC Maximum Case Temp. 90°C Storage Temperature: -40ºC to +85ºC Humidity: 5% to 100% Cooling: Convection Sound Rating: Class A MTBF: 260,000 Hours @ 110Vac input, 80% load and 25ºC ambient conditions per MIL-HDBK-217F Lifetime: 77,200 Hours @ 220Vac, 80% load and Tc=60ºC Weight: 2.2 lbs. (1.0 kg) New Surge Protection and HI-POT Testing Model Number Metal Lock Sheet Nut HI-POT Test Output Voltage Output Current (Vdc ±5%) Range (mA) Max. Output Power (W) Typical Efficiency TRV-150S012ST 12 0-12.5 150 92% TRV-150S020ST 20 0-7.50 150 92% TRV-150S024ST 24 0-6.25 150 93% TRV-150S036ST 36 0-4.17 150 93% TRV-150S048ST 48 0-3.13 150 93% TRV-150S054ST 54 0-2.78 150 93% Safety and EMC Compliance Normal Application The new design of this LED driver provides 1.4KV surge protection. To properly HI-POT test this unit, the surge protection must be disconnected. The screw, nut, and metal lock sheet on the input side of the driver provide for this. To test, first remove the nut and lock sheet as shown. After testing, secure the nut and lock sheet to provide line-to-earth protection. UL/CUL UL8750, Compliance to UL1012, UL935, CAN/CSA-C22.2 No. 0, CSA-C22.2 No. 107.1-01, CSA-C22.2 No. 250.0 CE EN 61347-1, EN61347-2-13 EN 55015 Conducted emission Test & Radiated emission Test EN 61000-3-2 Harmonic current emissions This HI-POT test feature is available on product manufactured after August 15, 2015. EN 61000-3-3 Voltage fluctuations & flicker EN 61000-4-2 Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge EN 61000-4-3 Radio-Frequency Electromagnetic Field Susceptibility Test-RS EN 61000-4-4 Electrical Fast Transient / Burst-EFT EN 61000-4-5 Surge Immunity Test: AC Power Line: line to line 4 kV, line to earth 6 kV EN 61000-4-6 Conducted Radio Frequency Disturbances Test-CS EN 61000-4-8 Power Frequency Magnetic Field Test E332160 Note: LED drivers are designed and intended to operate LED loads only. Non-LED loading may be outside the specified design limits of our LED drivers, and therefore cannot be covered by any warranty. If you desire to use our LED drivers to operate non-LED loads please contact us to discuss compatibility. Specifications subject to change without notice. EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity Requirements Applies to Lighting Equipment Rev 8-28-15 Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com TRV-150 Series SSL Solutions Faster Than The Speed Of Light® Pg 2 of 2 226 199 195 650±20 Ø 7.3±0.2 50±3 220±20 125 15±2 Tc = 90°C max 20.6 Ø 7.8±0.2 50±3 67.5 OUTPUT Red (+) Black (-) 25 39.5 5 39.5 15±2 INPUT Black (L) White (N) Green (GND) 5 50 34 8 WIRE SPECS: AC Input: UL SJTW #18AWG DC Output: UL SJTW #18AWG TRV-150S012ST: Note, Two DC output cables are connected in parallel internally, because one AWG #18 wire can only carry 10A. In application, connect the two red wires together and two black wires together, or ensure that each cable carries same current. 226 199 195 650±20 20 Ø 7.3±0.2 50±3 220±20 125 15±2 Tc = 90°C max 20.6 Ø 7.8±0.2 50±3 OUTPUT Red (+) Black (-) 25 39.5 5 39.5 15±2 INPUT Black (L) White (N) Green (GND) 67.5 209 213 5 50 34 8 209 213 Lifetime / Case Temperature Derating Curve 105 90 100 100 80 80 Load (%) Lifetime (kHrs) 120 Derating Curve Load (%) 135 75 60 60 60 40 40 45 30 20 20 15 0 30 40 50 60 70 Case Temperature (°C) 80 90 0 -35 -20 -5 10 25 40 55 Ambient Temperature (°C) 70 0 90 120 150 180 210 240 Input Voltage (V) 270 Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com 300 330
TRV-150S024ST 价格&库存
很抱歉,暂时无法提供与“TRV-150S024ST”相匹配的价格&库存,您可以联系我们找货
