TTC-150S280DT
TTC-150S280DT
    THOMASRESEARCHPRODUCTS
    LEDDRIVERCCAC/DC27-54V2.8A
TTC-150S280DT 数据手册
150W TTC-150 Series Total Power: 150 Watts Input Voltage: 347-480 Vac Single Output: 12-54 Vdc Indoor or Outdoor Applications, IP67 Ultra High Efficiency High Power Factor UL8750 Switch Mode LED Drivers Constant Current and Dimming Aluminum Housing Electrical Specifications Input Voltage Range: 347 - 480 Nom. Vac (312 - 528 V Min/Max) Frequency: 50/60 Hz Nom. (47-63 Hz Min/Max) Power Factor: >0.90 @ full load, 347V through 480V Input Current: 0.7 A @ 347Vac full load, 0.42 A @ 480Vac full load Inrush Current: 15 A @ 480Vac Maximum Power: 150W Line Regulation: ± 1% Load Regulation: ± 3% THD: < _ 20% @ 75-100% load Leakage Current: 1 mA max @ 480Vac Typical Efficiency 91-94% @ full load Turn-on Delay: 1S Protection: Over-Voltage, Over-Temperature (105°C), and Short Circuit Protection with Auto Recovery Environmental Specifications Operating Temperature: -40ºC to +70ºC Ambient Storage Temperature: -40ºC to +85ºC Humidity: 10% to 100% Cooling: Convection MTBF: 250,000 Hours @ 480Vac, 80% load, 25ºC, per MILHDBK-217F Lifetime: 87,600 Hours @ 480Vac, 80% load and Tc = 60ºC Weight: 2.87 lbs. (1.3 kg) Constant Current Versions - Product Specifications Model Number Output Current Output Voltage Max Output Typical (mA ±5%) Range (Vdc) Power (W) Efficiency TTC-150S058ST 580 129-258 150 91% TTC-150S070ST 700 107-214 150 91% TTC-150S105ST 1050 71-142 150 90% TTC-150S140ST 1400 53-107 150 90% TTC-150S210ST 2100 35-71 150 90% TTC-150S280ST 2800 27-54 150 90% TTC-150S350ST 3500 21-43 150 89% TTC-150S420ST 4200 18-36 150 89% Dimming Versions - Product Specifications Model Number Output Current Output Voltage Max Output Typical (mA ±5%) Range (Vdc) Power (W) Efficiency TTC-150S058DT 580 129-258 150 91% TTC-150S070DT 700 107-214 150 91% TTC-150S105DT 1050 71-142 150 90% TTC-150S140DT 1400 53-107 150 90% TTC-150S210DT 2100 35-71 150 90% TTC-150S280DT 2800 27-54 150 90% TTC-150S350DT 3500 21-43 150 89% TTC-150S420DT 4200 18-36 150 89% E332160 Specifications subject to change without notice. Thomas Research Products • 11548 Smith Dr. • Huntley, IL 60142 • T: 847-515-3057 • F: 847-515-3047 • www.trpssl.com 1-09-13 TTC-150W Pg 2 of 3 Dimming Control On secondary side Minimum Typical Maximum 10.8V 0 mA 0V 0µA 12V — — — 13.2V 20mA 15V 200µA 12V output voltage 12V output source current Absolute maximum voltage on the 1-10v input pin Source current on 1-10V input pin Output Current / Dimming Voltage Normalized Output Current Parameters 100% V+ (Red) Vac V- (Blue) L Vaux (Yellow) TTC-150 N Dim+ (Purple) G 80% 60% 40% 20% 0% 0 1 0-10V Dimmer Dim- (Gray) 2 3 4 5 6 7 Dimming Voltage (V) 8 Notes: 1. Io is actual output current and Ir is rated current without dimming control. 2. For the driver to operate properly, the load voltage must be maintained above the minimum voltage threshold (approx. 50% of the max. output voltage for any given model). 3. If the output voltage is maintained above 50% of the maximum output voltage, the dimming control may be operated over the entire 1-10V range with output current varying from 10% to 100% of Ir. 4. The dimming signal may be less than 1V; however, no further dimming will occur between 0V and 1V. 5. Do not connect the GRAY of dimming to the output; otherwise, the LED driver can not work normally. Derating Curve 140 100 Lifetime (kHrs) 120 Load (%) 80 100 60 40 120Vac 277Vac 20 0 -20 Lifetime / Case Temperature -10 0 10 20 30 40 50 Ambient Temperature (°C) 60 (580 mA model) 60 40 20 0 30 70 Power Factor / Output Voltage 1.00 80 40 50 60 70 Case Temperature (°C) 80 90 Efficiency / Load (580 mA model) 95% 0.95 90% 0.85 85% PF PF 0.90 0.80 80% 0.75 0.70 347Vac 480Vac 0.65 0.60 50% 60% 70% 80% 90% Normalized Output Current 347Vac 480Vac 75% 100% 70% 50% 60% 70% 80% 90% Normalized Output Current 100% Thomas Research Products • 11548 Smith Dr. • Huntley, IL 60142 • T: 847-515-3057 • F: 847-515-3047 • www.trpssl.com 9 10 TTC-150W Pg 3 of 3 Dimensions - mm TTC-150 Dimming AC IN (UL STW 18#/3C) DC OUT (UL SJTW 18#/2C) Black (ACL) White (ACN) Green (GND) Red (V+) Blue (V-) Black/White Purple Gray DIMMING WIRE (UL 2464 3*22AWG) TTC-150 AC IN (3*AWG #18) DC OUT (2*AWG #18) Black (ACL) White (ACN) Green (GND) Red (V+) Blue (V-) Safety Category Standard UL8750, Compliance to UL1012, UL/CUL CAN/CSA-C22.2 No. 223-M91, CSA-C22.2 No. 107.1-01 EMI Standards Notes FCC Part 15 ANSI C63.4:2009 Class B Note: Disconnect power to LED driver for at least 30 seconds before connecting or disconnecting Driver output and LED Engine. This prevents potential arcing transients that can damage the Engine and Driver. See Hot Plugging in our Driver Application Guide for more information. Thomas Research Products • 11548 Smith Dr. • Huntley, IL 60142 • T: 847-515-3057 • F: 847-515-3047 • www.trpssl.com
TTC-150S280DT 价格&库存
很抱歉,暂时无法提供与“TTC-150S280DT”相匹配的价格&库存,您可以联系我们找货
