200W TRV-200 Series
Switch Mode LED Drivers
Constant Voltage
Aluminum Housing
Electrical Specifications
Input Voltage Range:
100 - 277 Nom. Vac (90 - 305 V Min/Max)
Frequency:
50/60 Hz Nom. (47-63 Hz Min/Max)
Power Factor:
>0.90 @ full load, 100V through 277V
Inrush Current:
65 Amps max @ 230 Vac, cold start 25ºC
Input Current:
2.3 A max 100Vac, 1.1 A max 220Vac
Maximum Power:
200W
Line Regulation:
± 1%
Load Regulation:
± 2%
THD:
_ 20% @ full load
Leakage Current:
0.75 mA 277 Vac 60Hz
Typical Efficiency
92.5%-93.5% at 220Vac
Turn-on Delay:
0.9S typical 110Vac, 0.5S typical 220Vac
Ripple and Noise:
2% Vo
Protection:
Over-Voltage (latch mode), Over-Temperature (120°C),
Over-Current (hiccup mode), Lightning, and
Short Circuit Protection with Self Recovery
Environmental Specifications
Max Case Temperature:
88.2ºC
Storage Temperature:
-40ºC to +85ºC
Humidity:
5% to 100%
Cooling:
Convection
Sound Rating:
Class A
MTBF:
276,000 Hours @ 110VAC input, 80% load and
25ºC ambient conditions per MIL-HDBK-217F
Lifetime:
92,500 Hours @ 220Vac, 80% load and Tc = 60ºC
Weight:
2.2 lbs. (1.0 kg)
• Total Power: 200 Watts
• Input Voltage: 100-277 Vac Nom.
• UL Dry & Damp Location Rated
• IP67
• Ultra-high Efficiency
• High Power Factor
• UL8750
Constant Voltage - Product Specifications
Model Name
Output Voltage
(Vdc ±5%)
Output Current
Range (A)
Max. Output
Power (W)
Typical
Efficiency
TRV-200S012ST
12
0–15.0
180
91.0%
TRV-200S024ST
24
0–8.33
200
92.0%
TRV-200S036ST
36
0–5.56
200
92.5%
TRV-200S048ST
48
0–4.17
200
92.5%
TRV-200S054ST
54
0–3.70
200
92.5%
E332160
Note:
LED drivers are designed and intended to operate LED loads only.
Non-LED loading may be outside the specified design limits of our
LED drivers, and therefore cannot be covered by any warranty.
If you desire to use our LED drivers to operate non-LED loads
please contact us to discuss compatibility.
Specifications subject to change without notice.
Rev 8-28-15
Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com
TRV-200 Series
SSL Solutions Faster Than The Speed Of Light®
Pg 2 of 2
Dimensions - mm
WHITE (ACN)
BLACK (ACL)
GREEN (GND)
AC INPUT (3*AWG #18)
Tc = 88.2°C max
Derating Curve
Derating Curve
80
80
Load(%)
100
Load(%)
100
60
40
60
40
100Vac
277Vac
DC OUTPUT (2*AWG #18)
RED (V+)
BLACK (V-)
-20
-5
10
25
40
55
120
150
Ambient Temperature(°C)
180
210
240
270
300
330
Input Voltage(V)
Safety and EMC Compliance
UL/CUL
UL8750, Compliance to UL1012, UL935,
CAN/CSA-C22.2 No. 0, CSA-C22.2 No. 107.1-01, CSA-C22.2 No. 250.0
CE
EN 55015
EN 61000-3-2
EN 61000-3-3
EN 61000-4-2
EN 61000-4-3
EN 61000-4-4
EN 61000-4-5
EN 61000-4-6
EN 61000-4-8
EN 61000-4-11
EN 61547
EN 61347-1, EN61347-2-13
Conducted emission Test & Radiated emission Test
Harmonic current emissions
Voltage fluctuations & flicker
Electrostatic Discharge (ESD): 8 kV air discharge, 4 kV contact discharge
Radio-Frequency Electromagnetic Field Susceptibility Test-RS
Electrical Fast Transient / Burst-EFT
Surge Immunity Test: AC Power Line: line to line 2 kV, line to earth 4 kV
Conducted Radio Frequency Disturbances Test-CS
Power Frequency Magnetic Field Test
Voltage Dips
Electromagnetic Immunity Requirements Applies to Lighting Equipment
很抱歉,暂时无法提供与“TRV-200S024ST”相匹配的价格&库存,您可以联系我们找货
