LE75S70CD
LE75S70CD
    SLPOWER
    LED SUPPL CC AC/DC 54-108V 735MA
LE75S70CD 数据手册
75W Single Output LED Grade LE75-CD Family FEATURES AND BENEFITS LED High Efficiency (up to 91%) Waterproof (IP67) Wide Range Universal Input 90-305 VAC Overcurrent, Overvoltage, Overtemperature Protection � Active Power Factor Correction (0.99 Typical) Meets UL8750 & EN61347 Safety Constant Current Output Compliant to ANSI/IEEE C62.41, Class A Dimming Function Minimum of 3 Year Warranty, Consult Factory for 5 Years Lightning Protection MODEL SELECTION Model Number Output Voltage Output Current Efficiency* 220 Vac 110 Vac Regulation Ripple & Noise** Line Load Overvoltage Trip Level LE75S28CD 2660mA - 2940mA 13V - 27V 85% - 87% 87% - 89% 5% of Vo pk-pk ±1% ±3% 35V - 38V LE75S140CD 1330mA - 1470mA 27V - 54V 86% - 88% 88% - 90% 5% of Vo pk-pk ±1% ±3% 65V - 70V LE75S70CD 665mA - 735mA 54V - 108V 87% - 89% 89% - 91% 5% of Vo pk-pk ±1% ±3% 118V - 130V Notes : 1. Efficiency measured at full load, at input voltage noted. Efficiency will be 2% lower if measured immediately after start-up. 2. Measured at 20MHz bandwidth, with noise probe directly across output terminals, and load terminated with 0.1μF ceramic and 10μF low ESR electrolytic capacitors. 3. LE75S070CD: Non-Class 2 output (USR & CNR) 4. LE75S140CD: Class 2 output (USR), Non-Class 2 output (CNR) 5. LE75S280CD: Class 2 output (USR & CNR) INPUT OUTPUT AC Input 90-305Vac, 47-63Hz, 1ø 120–370Vdc Input Current 100Vac: 0.9A, 220Vac: 0.42A Inrush Current 230Vac, cold start: will not exceed 50A Input Fuses XA, 250VAC fuses provided on all models Earth Leakage Current
LE75S70CD 价格&库存
很抱歉,暂时无法提供与“LE75S70CD”相匹配的价格&库存,您可以联系我们找货
