LE300S48VN
LE300S48VN
    SLPOWER
    LED SUPPLY CV AC/DC 48V 6.25A
LE300S48VN 数据手册
300W Single Output LED Grade LE300-VN Family FEATURES AND BENEFITS LED High Efficiency (up to 94%) Waterproof (IP67) Wide Range Universal Input 90-305 VAC Overcurrent, Overvoltage, Overtemperature Protection Active Power Factor Correction (0.99 typical) Meets UL8750 & EN61347 Safety Constant Voltage Output Minimum of 3 Year Warranty, Consult factory for 5 Years Lightning Protection MODEL SELECTION Ripple & Noise** Efficiency* 220Vac 110Vac Regulation Line Load Overvoltage Trip Level Output Current Output Voltage LE300S28VN 0 – 10.71A 28Vdc 91%-92% 93%-94% 2% of Vo pk-pk ±1% ±3% 32V - 36V LE300S48VN 0 – 6.25A 48Vdc 91%-92% 93%-94% 2% of Vo pk-pk ±1% ±3% 52V - 61V Model Number Notes : 1. Efficiency measured at full load, at input voltage noted. 2. Measured at 20MHz bandwidth, with noise probe directly across output terminals, and load terminated with 0.1μF ceramic and 10μF low ESR electrolytic capacitors. OUTPUT INPUT AC Input 90-305Vac, 47-63Hz, 1Ø Output Voltage See models chart on pg 1 Input Current 100Vac: 3..3A, 220Vac: 1.6A Output Power 300W continuous Inrush Current 230Vac, cold start: will not exceed 50A Turn On Time 2.0 seconds, max. Input Fuses XA, 250VAC fuses provided on all models Hold-up Time 20 mSec Earth Leakage Current
LE300S48VN 价格&库存
很抱歉,暂时无法提供与“LE300S48VN”相匹配的价格&库存,您可以联系我们找货
