LXV200-048S
LXV200-048S
    EXCELSYSTECHNOLOGIESLTD
    LED SUPPLY CV AC/DC 48V 4.17A
LXV200-048S 数据手册
LED Power Supplies 200W LED Power Supply Constant Voltage Power Supplies LED POWER next generation power source FEATURES • High Efficiency 93% • IP67 Waterproof • Active PFC (Typical 0.97) • OVP, SCP, OTP • -35 to 70°C deg operation • Universal Input 90-264VAC • UL8750 recognised • EN61347-1, -2-13 compliant The LXV200 series of constant voltage LED power supplies from Excelsys Technologies can deliver up to 200W of output power in an extremely compact package size. LED Power 200W LXV200 series The LXV200 series of constant voltage power supplies provides a range of output voltage solutions for specific LED requirements. With industry leading efficiencies, and an extensive protection feature set, the LXV200 series provides high reliability and high performance in a compact package The LXV200 series carries the CE mark for safety and is also RoHS compliant. For more details contact sales@excelsys.com Model Number Output Voltage Output Current Input Voltage OVP Max OCP Hiccup Efficiency LXV200-012S LXV200-024S LXV200-036S LXV200-042S LXV200-048S LXV200-050S LXV200-052S LXV200-054S LXV200-081S LXV200-105S 12V 24V 36V 42V 48V 50V 52V 54V 81V 105V 14.6A 8.33A 5.56A 4.76A 4.17A 4.00A 3.84A 3.70A 2.47A 1.90A 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 18V 36V 54V 63V 72V 75V 78V 81V 122V 158V 120-170% 120-170% 120-170% 120-170% 120-170% 120-170% 120-170% 120-170% 120-170% 120-170% 92.0% 92.0% 92.5% 92.5% 92.5% 92.5% 93.0% 93.0% 93.0% 93.0% Input Specifications Parameter Input Voltage Range Input Frequency Range Input Current Inrush Current Power Factor Conditions/Description Universal Input. see Note 3 Min 90 47 100VAC in, 200W output 230VAC in, 25°C, Cold Start 220VAC, 110VAC 0.97 Conditions/Description Min Nom Max 264/305 63 2.3 65 0.99 Units VAC Hz A A Output Specifications Parameter Line Regulation Load Regulation Voltage Accuracy Ripple and Noise Dynamic Response Overshoot Turn-on Delay Short Circuit Protection Over Voltage Protection OverTemperature Protection Nom % of Vout 20MHz Bandwidth. See Note 1 Output Deviation R/S : 1 A /uS Settling Time Load : 25% ~ 75% full Load Measured at 220VAC and full load Auto Recovery Latching. See individual models OVP levels Internal Component Temperature Max ±1 ±2 ±5 2.0 5 10 10 3 Units % % % % pk-pk % mS % s 110 °C General Specifications Parameter Isolation Voltage Efficiency Safety Agency Approvals No load Power Dissipation MTBF Lifetime Weight Operating Temperature Storage Temperature Relative Humidity Power Derating Note 1. Note 2. Note 3. Conditions/Description Input to Output See Note 2 Input to Chassis See individual models UL8750, EN61347-1, -2-13 pending Measured at 120VAC and 220VAC MIL HDBK-217F, 110VAC input, 80% load, 25°C 220VAC input, 80% load, 45°C Min 3750 1500 Nom Max Units VAC VAC % 2.0 W Hours Hours g °C °C % 93.0 247,000 55,000 1000 -35 -40 Non-condensing (operating) 10 At 100 VAC, derates linearly from 100% at 60°C to 80% at 70 °C +70 +85 100 1 Output connected in parallel with 0.1uF ceramic capacitor and 10uF electrolytic capacitor. Primary to Secondary Isolation test not to be carried on power supply. 90-305VAC input voltage range available. Add Suffix “W” to part number e.g. LXV200-012SW Europe/Asia Excelsys Technologies Ltd 27 Eastgate Drive Eastgate Business Park Little Island, Cork, Ireland IRELAND t: +353 21 4354716 f: +353 21 4354864 e: sales@excelsys.com North America Excelsys Technologies 519 Interstate 30, #309 Rockwall, TX 75087 USA t: (972) 771 4544 f: (972) 421 1805 e: salesusa@excelsys.com LED Power Supplies 200W EMC LED Power 200W Parameter Emissions Conducted Radiated Harmonic Distortion Flicker and Fluctuation Immunity ESD Radiated RFI Fast Transients - burst Input Line Surges Conducted RFI Power Freq Magnetic Field Voltage Dips Standard Level EN55015 EN55015 EN61000-3-2 EN61000-3-3 Level B Level B Compliant Compliant EN61000-4-2 EN61000-4-3 EN61000-4-4 EN61000-4-5 EN61000-4-6 EN61000-4-8 EN61000-4-11 Level 4 Level 3 Level 4 Level 4 Compliant Compliant Compliant Units INPUT / OUTPUT WIRING INPUT CABLE SJTW 18AWG 2C Black (L) and White(N), Green (Earth) 650±20mm OUTPUT CABLE SJTW 18AWG 2C Black (-V) and Red (+V) 220±20mm MECHANICAL SPECIFICATIONS 226 ± 0.5 199 ± 0.5 195 ± 0.5 67.5 67.5 40 15±0.5 50 ± 2 50 ± 2 650 ± 20 15±0.5 40 220 ± 20 50 10.5 34 5 8 5 209 ± 0.5 213 ± 0.5 50 10.5 LXV200-012S model 34 5 8 2 209 ± 0.5 213 ± 0.5 All Tolerances ± 0.2mm unless specified Specifications are subject to change without notice LXV200 Datasheet 27 April 2011 Europe/Asia Excelsys Technologies Ltd 27 Eastgate Drive Eastgate Business Park Little Island, Cork, Ireland IRELAND North America t: +353 21 4354716 Excelsys Technologies f: +353 21 4354864 519 Interstate 30, #309 e: sales@excelsys.com Rockwall, TX 75087 USA t: (972) 771 4544 f: (972) 421 1805 e: salesusa@excelsys.com
LXV200-048S
物料型号:LXV200系列
器件简介:LXV200系列是来自Excelsys Technologies的恒压LED电源,能够提供高达200W的输出功率,具有非常紧凑的封装尺寸。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 高效率:93% - 防水等级:IP67 - 有源PFC(典型值0.97) - 过压保护(OVP)、短路保护(SCP)、过温保护(OTP) - 工作温度范围:-35至70°C - 通用输入电压:90-264VAC - 符合UL8750标准和EN61347-1、-2-13标准
功能详解: - 提供多种输出电压解决方案,以满足特定LED需求。 - 具有行业领先的效率和广泛的保护功能,确保高可靠性和高性能。
应用信息:适用于需要高效率和高可靠性的LED照明应用。
封装信息:文档中提供了详细的机械规格和输入/输出接线信息,包括电缆规格和尺寸。
LXV200-048S 价格&库存
很抱歉,暂时无法提供与“LXV200-048S”相匹配的价格&库存,您可以联系我们找货
