LXV150-105S
LXV150-105S
    EXCELSYSTECHNOLOGIESLTD
    LED SUPPLY CV AC/DC 105V 1.42A
LXV150-105S 数据手册
150W LED Power Supplies LED Power Supply Constant Voltage Power Supplies The LXV150 series of constant voltage LED power supplies from Excelsys Technologies can deliver up to 150W of output power in an extremely compact package size. LED POWER next generation power source FEATURES • Constant Voltage Power • Active PFC (0.99 Typical) • High Efficiency 94% • IP67 Waterproof • Active PFC (Typical 0.97) • OVP, SCP, OTP • -35 to 70°C deg operation • Universal Input 90-264VAC • UL8750 recognised • EN61347-1, -2-13 compliant LED Power 150W LXV150 series The LXV150 series of constant voltage power supplies provides a range of output voltage solutions for specific LED requirements. With industry leading efficiencies, and an extensive protection feature set, the LXV150 series provides high reliability and high performance in a compact package The LXV150 series carries the CE mark for safety and is also RoHS compliant. For more details contact sales@excelsys.com Model Number Output Voltage Output Current Input Voltage OVP Max OCP Hiccup Efficiency LXV150-012S LXV150-024S LXV150-036S LXV150-040S LXV150-042S LXV150-048S LXV150-050S LXV150-052S LXV150-054S LXV150-056S LXV150-081S LXV150-105S 12V 24V 36V 40V 42V 48V 50V 52V 54V 56V 81V 105V 12.5A 6.25A 4.17A 3.75A 3.57A 3.13A 3.00A 2.88A 2.78A 2.68A 1.85A 1.42A 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 90-264VAC(3) 16V 34V 48V 53V 55V 61V 63V 66V 69V 75V 100V 135V 110-180% 110-180% 110-180% 110-180% 110-180% 110-180% 110-180% 110-180% 110-180% 110-180% 110-180% 110-180% 92.0% 93.0% 93.0% 93.0% 94.0% 93.0% 93.0% 93.0% 93.0% 93.0% 94.0% 94.0% Nom Max 264/305 63 1.75 65 0.99 Units VAC Hz A A Nom Max ±1 ±2 ±5 2.0 5% Vo 10 mS 10 3 Units % % % % pk-pk 110 °C Input Specifications Parameter Input Voltage Range Input Frequency Range Input Current Inrush Current Power Factor Conditions/Description Universal Input. see Note 3 Min 90 47 100VAC in, 150W output 230VAC in, 25°C, Cold Start 220VAC, 110VAC 0.96 Conditions/Description Min Output Specifications Parameter Line Regulation Load Regulation Voltage Accuracy Ripple and Noise Dynamic Response Overshoot Turn-on Delay Short Circuit Protection Over Voltage Protection OverTemperature Protection % of Vout 20MHz Bandwidth. See Note 1 Output Deviation R/S : 1 A/uS Settling Time Load : 25% ~ 75% full Load Measured at 220VAC and full load Auto Recovery Latching. See individual models OVP levels Internal Component Temperature % s General Specifications Parameter Isolation Voltage Efficiency Safety Agency Approvals No load Power Dissipation MTBF Lifetime Weight Operating Temperature Storage Temperature Relative Humidity Note 1. Note 2. Note 3. Conditions/Description Input to Output See Note 2 Input to Chassis See individual models UL8750, EN61347-1, -2-13 Measured at 120VAC and 220VAC Telecordia SR-33, 25°C 25°C Non-condensing (operating) Min 3750 1500 Nom Max Units VAC VAC % 1.5 W Hours Hours g °C °C %RH 94.0 2,000,000 100,000 1000 -35 -40 10 Output connected in parallel with 0.1uF ceramic capacitor and 10uF electrolytic capacitor. Primary to Secondary Isolation test not to be carried on power supply. 90-305VAC input voltage range available. Add Suffix “W” to part number e.g. LXV150-012SW Europe/Asia North America Excelsys Technologies Ltd t: +353 21 4354716 Excelsys Technologies 27 Eastgate Drive f: +353 21 4354864 Eastgate Business Park e: sales@excelsys.com 519 Interstate 30, #309 Rockwall, TX 75087 Little Island, Cork, Ireland USA IRELAND +70 +85 100 t: (972) 771 4544 f: (972) 421 1805 e: salesusa@excelsys.com 1 LED Power Supplies 150W EMC LED Power 150W Parameter Emissions Conducted Radiated Harmonic Distortion Flicker and Fluctuation Immunity ESD Radiated RFI Fast Transients - burst Input Line Surges Conducted RFI Power Freq Magnetic Field Voltage Dips Standard Level EN55015 EN55015 EN61000-3-2 EN61000-3-3 Level B Level B Compliant Compliant EN61000-4-2 EN61000-4-3 EN61000-4-4 EN61000-4-5 EN61000-4-6 EN61000-4-8 EN61000-4-11 Level 4 Level 3 Level 4 Level 4 Compliant Compliant Compliant Units INPUT / OUTPUT WIRING INPUT CABLE SJTW 18AWG 3C Black (L) and White(N), Green(E) 650±20mm OUTPUT CABLE SJTW 18AWG 2C Black (-V) and Red (+V) 220±20mm MECHANICAL SPECIFICATIONS 226 ± 0.5 199 ± 0.5 195 ± 0.5 67.5 67.5 40 15±0.5 50 ± 2 50 ± 2 650 ± 20 15±0.5 40 220 ± 20 50 10.5 34 5 8 5 209 ± 0.5 213 ± 0.5 50 10.5 LXV150-012S model 34 5 8 2 209 ± 0.5 213 ± 0.5 All Tolerances ± 0.2mm unless specified Specifications subject to change without notice Europe/Asia Excelsys Technologies Ltd 27 Eastgate Drive Eastgate Business Park Little Island, Cork, Ireland IRELAND North America t: +353 21 4354716 Excelsys Technologies f: +353 21 4354864 519 Interstate 30, #309 e: sales@excelsys.com Rockwall, TX 75087 USA t: (972) 771 4544 f: (972) 421 1805 e: salesusa@excelsys.com
LXV150-105S
物料型号:LXV150系列,包括多个型号,如LXV150-012S、LXV150-024S等,每个型号具有不同的输出电压和电流。
器件简介:LXV150系列是一种恒压LED电源供应器,具有高达150W的输出功率,尺寸非常紧凑。该系列电源供应器具有行业领先的效率和全面的保护特性,确保了高可靠性和高性能。
引脚分配:文档中未明确提供引脚分配信息。
参数特性:包括恒定电压输出、主动功率因数校正(典型值0.97-0.99)、高效率(最高94%)、IP67防水等级、过压保护、短路保护、过温保护等。
功能详解:文档提供了详细的输入和输出规格参数,包括输入电压范围、频率范围、输入电流、功率因数、输出规范等。
应用信息:文档中未明确提供应用信息,但考虑到其高效率和紧凑设计,适用于需要高功率LED照明的场合。
封装信息:文档提供了输出电缆和输入/输出接线的规格,包括电缆类型、颜色和长度。
LXV150-105S 价格&库存
很抱歉,暂时无法提供与“LXV150-105S”相匹配的价格&库存,您可以联系我们找货
