LXC50-0450S
LXC50-0450S
    EXCELSYSTECHNOLOGIESLTD
    LED SUPPLY CC AC/DC 55-111V
LXC50-0450S 数据手册
LED Power Supplies 50W LED Power 50W LXC50 series LED Power Supply Constant Current Power Supplies LED POWER next generation power source FEATURES • High Efficiency (up to 88%) • Constant Output Current • Active PFC (Typical 0.87) • IP67 Waterproof • OVP, SCP • -35 to 60°C deg operation • Universal Input 90-264VAC • UL8750 recognised • EN61347-1, -2-13 compliant The LXC50 series of constant current LED power supplies from Excelsys Technologies can deliver up to 50W of output power in an extremely compact package size. The LXC50 series of constant current power supplies provides up to 3000mA of output current and 142V output voltage solutions for specific LED requirements. With industry leading efficiencies, and an extensive protection feature set, the LXC50 series provides high reliability and high performance in a compact package The LXC50 series carries the CE mark for safety and is also RoHS compliant. For more details contact sales@excelsys.com Model Number Output Voltage Output Current Input Voltage OVP Efficiency Latching max 213V 88.0% LXC50-0350S 71-142V 350mA 90-264VAC LXC50-0450S 56-111V 450mA 90-264VAC 167V 88.0% LXC50-0700S 36-72V 700mA 90-264VAC 108V 88.0% LXC50-1050S 24-48V 1050mA 90-264VAC 72V 88.0% LXC50-1100S 23-45.5V 1100mA 90-264VAC 63V 87.0% LXC50-1400S 18-36V 1400mA 90-264VAC 54V 87.0% LXC50-2100S 13-24V 2100mA 90-264VAC 36V 86.0% LXC50-2770S 9-18V 2770mA 90-264VAC 27V 85.0% LXC50-3000S 7-12V 3000mA 90-264VAC 18V 84.0% Nom Max 264 63 0.7 65 0.87 Nom Max ±1 ±3 100 ±5 2.0 10 3 Input Specifications Parameter Input Voltage Range Input Frequency Range Input Current Inrush Current Power Factor Conditions/Description Universal Input Min 90 47 100VAC in, 50W output 230VAC in, 25°C, Cold Start 220VAC, 110VAC 0.84 Conditions/Description Min % of Vout % of Vout 20MHz Bandwidth. See Note 1 50 Units VAC Hz A A Output Specifications Parameter Line Regulation Load Regulation Voltage Range Output Current Range Ripple and Noise Overshoot Turn-on Delay Short Circit Protection Over Voltage Protection Measured at 220VAC and full load Auto Recovery Latching. See individual models OVP levels Units % % % % % pk-pk % s General Specifications Parameter Isolation Voltage Efficiency Safety Agency Approvals No load Power Dissipation MTBF Lifetime Weight Operating Temperature Storage Temperature Relative Humidity Note 1. Note 2. Conditions/Description Input to Output See Note 2 Input to Chassis See individual models UL8750, EN61347-1, -2-13 Measured at 230 Vac Telecordia SR-33, 25°C 25°C Non-condensing (operating) Min 3750 1500 Nom Max Units VAC VAC % 1.0 W Hours Hours g °C °C %RH 88 2,000,000 80,000 460 -35 -40 10 +60 +85 100 1 Output connected in parallel with 0.1uF ceramic capacitor and 10uF electrolytic capacitor. Primary to Secondary Isolation test not to be carried on power supply. Europe/Asia Excelsys Technologies Ltd 27 Eastgate Drive Eastgate Business Park Little Island, Cork, Ireland IRELAND North America t: +353 21 4354716 Excelsys Technologies f: +353 21 4354864 519 Interstate 30, #309 e: sales@excelsys.com Rockwall, TX 75087 USA t: (972) 771 4544 f: (972) 421 1805 e: salesusa@excelsys.com LED Power Supplies 50W EMC LED Power 50W Parameter Emissions Conducted Radiated Harmonic Distortion Flicker and Fluctuation Immunity ESD Radiated RFI Fast Transients - burst Conducted RFI Power Freq Magnetic Field Voltage Dips Standard Level Units EN55015 EN55015 EN61000-3-2 EN61000-3-3 Level B Level B Compliant Compliant EN61000-4-2 EN61000-4-3 EN61000-4-4 EN61000-4-6 EN61000-4-8 EN61000-4-11 Level 4 Level 3 Level 4 Compliant Compliant INPUT / OUTPUT WIRING INPUT CABLE SJTW 18AWG 2C Black (L) and White(N) 340±20mm OUTPUT CABLE SJTW 18AWG 2C Black (-V) and Red (+V) 340±20mm MECHANICAL SPECIFICATIONS 183 ± 0.5 162 ± 0.5 42.5 158 ± 0.5 10 ± 1 50 ± 2 50 ± 2 10 ± 1 34.5 340 ± 20 34.5 340 ± 20 173 ± 0.5 2 x 5.5dia 8 5 8 8 5 2 8 All Tolerances ± 0.2mm unless specified Specifications are subject to change without notice Europe/Asia Excelsys Technologies Ltd 27 Eastgate Drive Eastgate Business Park Little Island, Cork, Ireland IRELAND North America t: +353 21 4354716 Excelsys Technologies f: +353 21 4354864 519 Interstate 30, #309 e: sales@excelsys.com Rockwall, TX 75087 USA t: (972) 771 4544 f: (972) 421 1805 e: salesusa@excelsys.com
LXC50-0450S 价格&库存
很抱歉,暂时无法提供与“LXC50-0450S”相匹配的价格&库存,您可以联系我们找货
