LDB60-012SW
LDB60-012SW
    EXCELSYSTECHNOLOGIESLTD
    LED SUPPLY CC/CV AC/DC 6-12V 5A
LDB60-012SW 数据手册
LED Power Supplies 60W LED Power Supply Constant Voltage /Current The LDB series of Xled constant voltage/current LED power supplies can deliver up to 60W output power in an extremely compact package size. LDB Series FEATURES • Universal Input: 90-305VAC • Constant Voltage/Current • High Efficiency 88% • Class II • IP67 rated • Class 2 device (UL1310) • Power Factor: Typical 0.95 • OCP, OVP, SCP, OTP • -30 to 50°C deg operation LED Power 60W LDB060 The LDB060 can deliver a constant voltage single 12V output in a compact package. At only 28.5mm high, the LDB100 offers the lowest profile LED driver solution. Furthermore, the LDB060 can operate as a constant current driver delivering the maximum output current range over the defined voltage range. Model Number Output Voltage Output Current (max) Efficiency 6V-12V 5.0A 88.0% LDB060-012SW Input Specifications Parameter Input Voltage Range Input Frequency Range Input Current Inrush Current Power Factor Conditions/Description Universal Input Min 90 47 240VAC, 60W 240VAC in, 25°C, Cold Start 240VAC, 100VAC Nom Max 305 63 0.3 40 Units VAC Hz A A 0.95 Output Specifications Parameter Line Regulation Load Regulation Voltage Accuracy Voltage Range Current Regulation Ripple and Noise Turn-on Delay Hold Up Time Over Current Protection Overload Protection Short Circuit Protection Over Voltage Protection Over Temp Protection Conditions/Description Min Nom % of Vout See individual models Vout 6.0V to 12.0V 20MHz Bandwidth. See Note 1 Measured at 200VAC and full load Max ±0.5 ±1.5 ±2.0 ±3.0 2.0 0.5 10 60 % % pk-pk s ms % W 16 100 V °C 20 5A max on 12V version See Note 2 Auto Recovery Auto Recovery Auto Recovery 85 92 Conditions/Description Input to Output Input to Chassis Min 3750 3750 Nom Units % % % General Specifications Parameter Isolation Voltage Efficiency Safety Agency Approvals No load Power Dissipation MTBF Lifetime Weight Operating Temperature Storage Temperature Relative Humidity Altitude Vibration Shock Dimensions Note 1. Note 2. Note 3. Max Units VAC VAC % 1.5 W Hours Hours Kg °C °C %RH m Grms Grms 88 UL8750, UL1310, CSA C22.2 No.223, Designed to meet EN61347-2-13, EN61347-1 Measured at 100VAC and 240VAC Telecordia SR-33, Full Load, 25°C T case = 60°C Maximum T case = 80°C Non-condensing (operating) Operating, Non Operating 10,000m 5-500Hz, random vibration Half-Sine, 11ms duration L x H x W: 231.0 x 28.4 x 40.0mm 1,000,000 100,000 0.66 -30 -40 5 +50 +85 95 2000 1.0 10 Output connected in parallel with 0.1uF ceramic capacitor and 10uF electrolytic capacitor. LBB060-012SW can delivers a maximum of 56W output power guaranteed at nominal output voltage. Output power will not exceed 60W under normal operating conditions. Maximum allowable case temperature is 80°C Pre Release Dec 2011 Europe/Asia Excelsys Technologies Ltd 27 Eastgate Drive Eastgate Business Park Little Island, Cork, Ireland IRELAND North America t: +353 21 4354716 Excelsys Technologies f: +353 21 4354864 519 Interstate 30, #309 e: sales@excelsys.com Rockwall, TX 75087 USA t: (972) 771 4544 f: (972) 421 1805 e: salesusa@excelsys.com 1 LED Power Supplies 60W EMC LED Power 60W Parameter Emissions Conducted Radiated Harmonic Distortion Flicker and Fluctuation Immunity ESD Radiated RFI Fast Transients - burst Input Line Surges Conducted RFI Power Freq Magnetic Field Voltage Dips Standard Level EN55015, EN55022 Class B EN55015, EN55022 Class B EN61000-3-2, Class C EN61000-3-3 Compliant Compliant Compliant Compliant EN61000-4-2 EN61000-4-3 EN61000-4-4 EN61000-4-5 EN61000-4-6 EN61000-4-8 EN61000-4-11 Level 4 Level 3 Level 4 Level 4 Compliant Compliant Compliant Units INPUT / OUTPUT WIRING INPUT CABLE Black (L) and White(N) 300±20mm 18AWG OUTPUT CABLE Red (+V) and Black (-V) 300±20mm 18AWG 231 218 4.2 205 21.8 40 7.4 12.5 28.4 11.2 6 4.2 2 Pre Release Dec 2011 Europe/Asia Excelsys Technologies Ltd 27 Eastgate Drive Eastgate Business Park Little Island, Cork, Ireland IRELAND North America t: +353 21 4354716 Excelsys Technologies f: +353 21 4354864 519 Interstate 30, #309 e: sales@excelsys.com Rockwall, TX 75087 USA t: (972) 771 4544 f: (972) 421 1805 e: salesusa@excelsys.com
LDB60-012SW 价格&库存
很抱歉,暂时无法提供与“LDB60-012SW”相匹配的价格&库存,您可以联系我们找货
