TRC-040S070DS
TRC-040S070DS
    THOMASRESEARCHPRODUCTS
    LED SUPPLY CC AC/DC 18-54V 700MA
TRC-040S070DS 数据手册
TRC-040DS Series–Fixed Output and Dimmable 40W Switch Mode LED Drivers Constant Current, Long Life Electrical Specifications Input Voltage Range: 100 - 277 Nom. Vac (90 - 305 V Min/Max) Frequency: 50/60 Hz Nom. (47-63 Hz Min/Max) Power Factor: >0.90 @ full load 100-220V, >0.80 @ full load 277V Inrush Current: 60.0 Amps max @ 230Vac Input AC Current: 0.48 A max 100Vac, 0.23 A max 220Vac Line Regulation: ± 2% Vac Load Regulation: ± 5% Typical Efficiency 85-88% typical @ maximum load Protection: Over-Voltage, Output Over-Current, Output Short Circuit Protection with Auto Recovery Environmental Specifications Minimum Starting Temp: -35ºC Maximum Case Temp. 87.5°C for 350 & 450 mA, 83°C for all others Storage Temperature: -40ºC to +85ºC Humidity: 10% to 100% Cooling: Convection Sound Rating: Class A MTBF: 487,000 Hours @ 25ºC, 80% load, 110Vac input on 3330 mA output model (MIL-HDBK-217F) Lifetime: 77,000 Hours @ 25ºC, 80% load, 110Vac input on 3330 mA output model Weight: 0.79 lbs (360 g) • Total Power: 40 Watts • Input Voltage: 100-277 Vac Nom. • UL Dry & Damp Location Rated • IP66 • High Efficiency • High Power Factor Constant Current Versions - Product Specifications Model Number Output Current (mA ±5%) Output Voltage Range (Vdc) Max. Output Power (W) Typical Efficiency TRC-040S035PS 350 38-114 40 88% TRC-040S045PS 450 30-89 38 88% TRC-040S070PS 700 18-54 37.8 87% TRC-040S105PS 1050 12-36 38 87% TRC-040S128PS 1280 10-29 36 87% TRC-040S140PS 1400 10-25 38 87% TRC-040S166PS 1660 8-23 38 86% TRC-040S222PS 2220 6-16 36 85% TRC-040S333PS 3330 4-11 35 84% Dimmable Versions - Product Specifications Output Current (mA ±5%) Output Voltage Range (Vdc) TRC-040S035DS 350 38-114 40 88% TRC-040S045DS 450 30-89 38 88% Model Number Sign Components Manual Max. Output Power (W) Typical Efficiency TRC-040S070DS 700 18-54 37.8 87% TRC-040S105DS 1050 12-36 38 87% TRC-040S128DS 1280 10-29 36 87% TRC-040S140DS 1400 10-25 38 87% TRC-040S166DS 1660 8-23 38 86% TRC-040S222DS 2220 6-16 36 85% TRC-040S333DS 3330 4-11 35 84% US/Canada US Only Class 2: E332160 Note: LED drivers are designed and intended to operate LED loads only. Non-LED loading may be outside the specified design limits of our LED drivers, and therefore cannot be covered by any warranty. If you desire to use our LED drivers to operate non-LED loads please contact us to discuss compatibility. Specifications subject to change without notice. Rev 8-31-15 Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com TRC-040 Series SSL Solutions Faster Than The Speed Of Light® Pg 2 of 4 10.63±0.79 [270±20] 0.39±0.08 [10.0±2] 2.76 [70.0] [ 1.18 30.0] 0.2 [5.0] 0.14 [3.6] INPUT White (N) Black (L) 3.74 [95.0] OUTPUT Red (+) Black (-) 0.39 [10.0] 7.87±0.79 [200±20] 1.18 [30.0] WIRE SPECS: AC Input: #18AWG DC Output: #18AWG Dimming Control: #26AWG 0.39 [10.0] Power Factor / Load 1.00 1.26 [32.0] Typical Efficiency / Load THD / Load 25% 100% 0.95 120Vac 277Vac 20% 0.90 0.85 15% 0.75 THD PF 0.80 120Vac 277Vac 0.70 0.65 10% 0.60 5% 60% 70% 80% Load 90% 100% 0% 50% Conducted emission EN 61000-3-2 Harmonic current emissions EN 61000-3-3 Voltage fluctuations and flicker EN 61000-4-2 Electrostatic discharge EN 61000-4-3 RFE Field Susceptibility test EN 61000-4-4 Electrical Fast Transient EN 61000-4-6 Conducted Radio Frequency EN 61000-4-8 Power Frequency Magnetic Field Test EN 61000-4-11 Voltage Dips EN 61547 Electromagnetic Immunity 70% 80% 90% Load 70% 60% 100% 70% 100 100 80 80 60 40 20 0 -20 80% 90% Normalized Output Voltage 100% Derating Curve Load (%) EN 55015 60% Derating Curve Load (%) UL 8750 EN 61347-1, EN61347-2-13 85% 75% Safety and EMC Compliance CUL CE 90% 80% 0.55 0.50 50% 120Vac 277Vac 95% Efficiency 0.39±0.04 [10.0±1] Dimming Yellow (10V out) Purple (0-10V in) Green (GND) 60 40 20 -5 10 25 40 55 Ambient Temperature (°C) 70 0 90 120 150 180 210 240 Input Voltage (V) 270 Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com 300 330 TRC-040 Series SSL Solutions Faster Than The Speed Of Light® Pg 3 of 4 Dimming Control Details Parameters 10V output voltage 10V output source current Absolute maximum voltage on the 0-10V input pin Source current on 0-10V input pin Minimum Typical Maximum 9.8 V -10 mA -2 V 0 mA 10 V — — — 10.2 V 2 mA 15 V 1 mA 10V Output (Yellow) TRC-040SxxxDS 1-10V Input (Purple) 20K GND (Green) Option 2 - DC Input Output Current / Potentiometer 100% Normalized Output Current Option 1 - Potentiometer Control Normalized Output Current The dimmer control is operated from either a potentiometer or from an input signal of 1 – 10 Vdc. Recommended implementations are provided below. 80% 60% 40% 20% 0% 0 1 2 3 4 5 6 Vdim (V) 7 8 9 10 Output Current / Dimming Voltage 100% 1-10V Input (Purple) TRC-040SxxxDS 1-10Vdc V GND (Green) 80% 60% 40% 20% 0% 0 1 2 3 4 5 6 Vdim (V) 7 8 9 10 Notes: 1. For the driver to operate properly, the load voltage must be maintained above the minimum voltage threshold (approx. 33% of the max. output voltage for any given model). 2. If the dimming voltage is varied from 10V down to 0V, the output current can be varied from 100% Io down to 20-30% Io. 3. Do not connect the GND of dimming to V(-) or earth ground; otherwise the LED driver will not work properly. 4. If dimming is not required, connect yellow and purple leads together to get full current output (100%). 5. It is permissible to parallel driver outputs to achieve higher output currents. However, when doing so, it is not permissible to connect dimming control leads in parallel. 6. It is permissible to connect dimming control leads of multiple drivers in parallel to allow them to operate from a single 0-10V control. However, when doing so, it is not permissible to interconnect output leads (red and black) across drivers. Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 • T 847-515-3057 • F 847-515-3047 • www.trpssl.com
TRC-040S070DS 价格&库存
很抱歉,暂时无法提供与“TRC-040S070DS”相匹配的价格&库存,您可以联系我们找货
