3239
3239
    ADAFRUIT
    BOX ALUM BLUE 2.25"L X 1.38"W
3239 数据手册
802.3af PoE Output Data & Power Splitter - 5/9/12V PRODUCT ID: 3239 Description Power over Ethernet (PoE) splitters can make your project wiring a breeze - and best of all they work to connect any 802.3af-capable router to any Ethernet device, even if it doesn't natively support PoE! The splitter takes a unified PoE signal (data and power) from one cable, and then separates the data (Ethernet) and power (+12VDC regulated) into two different lines for non-PoE devices. 7KLVLVDQHFRQRPLFDO¬SUDFWLFDOKLJKSHUIRUPDQFH¬DQG¬UHOLDEOHM Multi-Voltage (5V, 9V or 12V) PoE Output SplitterEDVHGRQ,(((DI¬VWDQGDUG¬,WFDQGLYLGHSRZHUDQGGDWDVLJQDOVIURPD QHWZRUNFDEOHDQGFDQEHXVHGZLWKDQ\3R(SRZHUVXSSO\HTXLSPHQW 3R(LQMHFWRU WKDW¬LV compatible with IEEE 802.3af, and supply power and data for non-PoE network equipment. Features: IEEE 802.3af compliant Supports 10/100M data transmission 99SRZHUYROWDJHLQSXWPDNHVLWYHU\FRQYHQLHQW¬WRXVHGLUHFWFXUUHQW'&9SRZHUIURP JHQHUDWRUURRP¬RU3R(SRZHUVXSSO\HTXLSPHQWVWDQGDUGRUQRQVWDQGDUG3R(LQMHFWRU3R( switch, etc. Supplies 1 Amp regulated DC power on a DC barrel jack - suitable for small projects. DIP switch for 5V, 9V, and 12V adjustable output power Comes with a variety of DC plugs with positive-tip output: 5.5mm/2.5mm, 5.5mm/2.1mm, 4.8mm/1.8mm, 3.4mm/1.3mm For use only with true 802.3af routers! If you don't have a PoE injector / hub / router, check out our passive PoE cable kit Technical Details Power OUT cable length: 280mm / 11" Data OUT cable length: 263mm / 10.5" Product Dimensions: 80.0mm x 55.0mm x 30.0mm / 3.1" x 2.2" x 1.2" Product Weight: 66.7g / 2.4oz Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3239”相匹配的价格&库存,您可以联系我们找货
  • 1+223.587811+28.04915
库存:1
