PENB1020B4800F01
PENB1020B4800F01
    SLPOWER
    AC/DCDESKTOPADAPTER
PENB1020B4800F01 数据手册
PENB1020B Universal 15.4W Gigabit PoE Adapter 3 Year Warranty •10/100/1000 (MbPS) Data Rates •Self-contained Injector •100-240Vac Universal Input •IEEE802.3af Compliant Detection, Disconnect, Overload Control Function •Load Diagnostic LED •Overload Shutdown and Short Circuit Protection •Regulated Output with Low Ripple •Compliant to UL/IEC/EN60950-1 •LPS (Limited Power Source) Compliant Description The PENB1020B Series of Power-over-Ethernet (PoE) adapters operate from a 90 to 264Vac input range, and provide up to 15.4W of output power at an output voltage of 48Vdc. These models are capable of operating with Gigabit Data rates, and are IEEE802.3af compliant. Features include diagnostic LED, and overvoltage, overload, and short circuit protection. Specifications All specifications are typical at nominal input, full load at 25°C unless otherwise stated AC Input 100-240Vac +/- 10%, 47-63 Hz single phase Input Current 0.5A @ 90Vac 0.25A @ 180Vac 60A peak, cold start Input Inrush Current Input Protection Internal Primary Current Fuse provided, 250Vac/3.15A Dialectric Withstand 4242Vdc Primary – Secondary, 2,150Vdc Primary–GND, 500Vdc Secondary - GND Earth Leakage Current 60,000 hours, calculated (7 years) Hold-Up Time 16mS min. @ 110Vac, 60Hz Efficiency 65% minimum Output Inrush Current (Iinrush) 450mA max. Output current in startup mode. (IEEE 802.3af 33.3.8.5) Overload Current Detection (Icut) 400mA max. (IEEE 802.3af 33.3.8.6) Short Circuit Protection (Ilim) 400 to 450mA max. Output current - at short circuit limit. (IEEE 802.3af 33.3.8.8) Overload time limit (Tovld) 50 to 75ms (IEEE 802.3af 33.3.8.7) Short circuit time limit (Tlim) 50 to 75ms (IEEE 802.3af 33.3.8.9) Operating Temperature 0° to +40°C Storage Temperature -30° to +85°C Relative Humidity 5% to 95%, non-condensing Altitude 0 to 10,000 ft Safety Standards UL/IEC/EN60950-1, CE, CB The voltage potential shall be measured between any conductor of one power pair and any conductor of the other power pair Models Model Number Output Voltage Output Current¹ Ripple & Noise² Max. Power Regulation IEEE802.3af Line Load³ Compliant? PENB1020B4800F01 48Vdc 0.35A 15.4W ±1% ±4% Yes IEC60320, C14 PENB1020B4800N01 48Vdc 0.35A See table above 15.4W ±1% ±4% Yes IEC60320, C8 Note: 1. 2. 3. AC Input Receptacle (Iport): Maximum output current in normal powering mode at PSE min output voltage. (IEEE 802.3af 33.3.8.4) Measured at 20MHz bandwidth, with noise probe as close to output RJ-45 connector as possible, and load terminated with 0.1μF ceramic and 10μF low ESR electrolytic capacitors. per (IEEE 802.3af 33.2.8.2) ______________________________________________________________________________________________________________________________ SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 805.832.6131 • Email: info@slpower.com • www.slpower.com 1 of 2 PENB1020B Universal 15.4W (IEEE802.3af Compliant) PoE Gigabit 3 Year Warranty EMI/EMC Compliance Conducted Emissions EN55022: 2006+ A1:2007 (Class B) Radiated Emissions EN55022: 2006+ A1:2007 (Class B) Static Discharge Immunity EN55024/IEC61000-4-2, 6kV/8kV, Criteria A Radiated RF Immunity EN55024/IEC 61000-4-3, 3V/m, Criteria A EFT/Burst Immunity EN55024/IEC 61000-4-4, 2kV, 5kHz, Criteria A Line Surge Immunity EN55024/IEC 61000-4-5, 1kV/2kV, Criteria A Conducted RF Immunity EN55024/IEC 61000-4-6, 3V (AM 80%, 1kHz), Criteria A Power Frequency Magnetic Field Immunity Line Harmonic Emissions EN55024/IEC 61000-4-8, 3A/m, Criteria A EN55024/IEC 61000-4-11, 100%, 10mS; 60%, 100mS; 30%, 500mS Criteria A. 100$, 5000mS, Criteria B EN61000-3-2: 2006 Flicker Test EN61000-3-3: 2008 Voltage Dip Immunity Outline Drawing IEC320 C14 input receptacle shown. Other options available. Consult factory for details and availability. PSA pinout Alternative B (IEEE 802.3af 33.2.2): J1 Pins 1 2 3 4 5 6 7 8 Da ta Pa ir 1 Da ta Pa ir 1 Da ta Pa ir 2 +VDC +VDC Da ta Pa ir 2 -VDC -VDC J2 Pins 1 2 3 4 5 6 7 8 Data Pa i r 1 Data Pa i r 1 Data Pa i r 2 No Connecti on No Connecti on Data Pa i r 2 No Connecti on No Connecti on Data Sheet © 2014 SL Power Electronics Corp. The information and specifications contained herein are believed to be correct at the time of publication. Rev. 12/1/2014 However, SL Power accepts no responsibility for consequences arising from reproduction errors or inaccuracies. Specifications are subject to change without notice. ______________________________________________________________________________________________________________________________ SL Power Electronics Corp • 6050 King Drive Ventura, CA 93003 • Phone 805.486.4565 • Fax 805.832.6131 • Email: info@slpower.com • www.slpower.com 2 of 2
PENB1020B4800F01
物料型号:PENB1020B 器件简介:PENB1020B系列PoE适配器支持90至264Vac输入范围,提供48Vdc输出电压,最大输出功率为15.4W。
兼容IEEE802.3af标准,支持千兆数据传输速率,具备诊断LED、过压、过载和短路保护功能。
引脚分配:遵循IEEE 802.3af标准,数据对1和2分别连接至J1和J2的1、2、3、6引脚,而直流正负电压(+VDC和-VDC)则不连接。
参数特性:输入电压范围100-240Vac,频率47-63Hz,MTBF超过60,000小时,效率不低于65%,输出功率15.4W,典型输出电压为+48Vdc,负载瞬态响应时间为0.5毫秒。
功能详解:具备诊断LED显示状态,过载和短路保护,符合UL/IEC/EN60950-1安全标准,LPS(有限功率源)兼容。
应用信息:适用于需要通过以太网线供电的应用,如网络摄像头、无线接入点等。
封装信息:尺寸为宽1.9英寸x长4.44英寸x高1.3英寸,重量120克,材质为94V-0黑色聚碳酸酯。
以上信息摘自PDF文档,提供了PENB1020B系列PoE适配器的详细规格和功能描述。
PENB1020B4800F01 价格&库存
很抱歉,暂时无法提供与“PENB1020B4800F01”相匹配的价格&库存,您可以联系我们找货
