PENB1020A4800F01
PENB1020A4800F01
    SLPOWER
    POEINJECTOR48VDESKTOP
PENB1020A4800F01 数据手册
PENB1020A Universal 19.2W Gigabit PoE Adapter 3 Year Warranty •10/100/1000 (MbPS) Data Rates •Self-contained Injector •100-240Vac Universal Input •Green DC Power LED •Overload and Short Circuit Protection •Regulated Output with Low Ripple •Compliant to UL/IEC/EN60950-1 •LPS (Limited Power Source) Compliant •RoHS Compliant Description The PENB1020A Series of Power-over-Ethernet (PoE) adapters operate from a 90 to 264Vac input range, and provide up to 19.2W of output power at an output voltage of 48Vdc. These models are capable of operating with Gigabit Data rates, and include features include diagnostic LED, and overvoltage, overload, and short circuit protection. This non-compliant adapter does not require a “handshake” signal to enable the output voltage. Specifications All specifications are typical at nominal input, full load at 25°C unless otherwise stated AC Input 100-240Vac +/- 10%, 47-63 Hz single phase Input Current MTBF >60,000 hours, calculated (7 years) 0.5A @ 90Vac 0.25A @ 180Vac 60A peak, cold start Hold-Up Time Internal Primary Current Fuse provided, 250Vac/3.15A Dialectric Withstand 4242Vdc Primary – Secondary, 2,150Vdc Primary–GND, 500Vdc Secondary - GND Earth Leakage Current
PENB1020A4800F01 价格&库存
很抱歉,暂时无法提供与“PENB1020A4800F01”相匹配的价格&库存,您可以联系我们找货
