PENB1035B5600F01
PENB1035B5600F01
    SLPOWER
    POEINJECTOR48VDESKTOP
PENB1035B5600F01 数据手册
PENB1035B Universal 56V, 35W (IEEE802.3at Compliant) PoE Gigabit 3 Year Warranty •10/100/1000 (MbPS) Data Rates •Self-contained Injector •100-240Vac Universal Input •IEEE802.3at Compliant Detection, Disconnect, Overload, and Overvoltage Control Function •Load Diagnostic LEDs •Overload Shutdown and Short Circuit Protection •Regulated Output with Low Ripple •Compliant to UL/IEC/EN60950-1 •LPS (Limited Power Source) Compliant Description The PENB1035 Series of Power-over-Ethernet (PoE) adapters operate from a 90 to 264Vac input range, and provide up to 35W of output power at an output voltage of 56Vdc. These models are capable of operating with Gigabit Data rates, and are available in IEEE802.3at compliant and non-compliant versions. Features include power and diagnostic LEDs, and overvoltage, overload, and short circuit protection. Specifications All specifications are typical at nominal input, full load at 25°C unless otherwise stated AC Input Input Current Short Circuit Protection 100K hours, calculated 10mS min. @ 115Vac, 60Hz 60mS min. @ 230Vac, 50Hz See models’ chart 2.0 sec max. @ 115Vac, 60Hz 2.0 sec max. @ 230Vac, 50Hz 100mS max. @ 115Vac, 60Hz 100mS max. @ 230Vac, 50Hz 10 minutes max @264Vac/60Hz 35W continuous, convection cooled Overvoltage Protection Provided Ripple and Noise See chart Operating Temperature Output Voltage See chart Storage Temperature Total Regulation See chart Relative Humidity Inrush Current Input Protection Dialectric Withstand Earth Leakage Current Output Power 90-264Vac, 47-63 Hz single phase 1.5A @ 90Vac 0.75A @ 180Vac 60A peak, cold start Internal Primary Fuse (3.15A/250V) provided 4242Vdc Primary – Secondary, 2,150Vdc Primary – GND, 500Vdc Secondary - GND
PENB1035B5600F01 价格&库存
很抱歉,暂时无法提供与“PENB1035B5600F01”相匹配的价格&库存,您可以联系我们找货
