3238
3238
    ADAFRUIT
    WASHER SHOULDER #10 FIBRE
3238 数据手册
802.3af PoE Output Data & Power Splitter - 12V 1A PRODUCT ID: 3238 Description Power over Ethernet (PoE) splitters can make your project wiring a breeze - and best of all they work to connect any 802.3af-capable router to any Ethernet device, even if it doesn't natively support PoE! The splitter takes a unified PoE signal (data and power) from one cable, and then separates the data (Ethernet) and power (+12VDC regulated) into two different lines for non-PoE devices. This is an economical, practical, high-performance, and reliable 12V PoE Output Splitter based on IEEE 802.3af standard. It can divide power and data signals from a network cable, and can be used with any PoE power supply equipment (PoE injector) that is compatible with IEEE 802.3af, and supply power and data for non-PoE network equipment. Features: IEEE 802.3af compliant Supports 10/100M data transmission 44V-57V power voltage input makes it very convenient to use direct current DC48V power from generator room or PoE power supply equipment, standard or non-standard PoE injector, PoE switch, etc. Supplies 1 Amp regulated DC12V power on a 2.1mm DC barrel jack - suitable for small projects. For use only with true 802.3af routers! If you don't have a PoE injector / hub / router, check out our passive PoE cable kit Technical Details Product Dimensions: 300.0mm x 35.0mm x 28.0mm / 11.8" x 1.4" x 1.1" Product Weight: 62.5g / 2.2oz Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3238”相匹配的价格&库存,您可以联系我们找货
