TCDC-7001
TCDC-7001
    TAMURA
    模块
    DC/DC CONVERT 24V 1A
TCDC-7001 数据手册
Model TCDC-7001 Industrial DC:DC Converter for Photovoltaic Applications ・ 24 Watt DC Power Supply ・ Wide DC Input Range ・ Isolation Control ・  Rated Input Voltage Input Voltage Range 200 - 600 VDC 190 - 1000 VDC Volts Output Rated Load Current Input Power Max Ripple and Noise Standby Power In Rush Current 24 VDC +/- 2% 1.0 Amps 30 watts DC < 120 mVp-p 20 mS at 400V Input end 1A Output Load 35 MM DIN Rail Mounting Hold Up Time Glass Filled Plastic case is durable with UL 94 V - 0 Flame Rating Internal Input Fuse ESD Immunity Humidity storage 95% from +25 to 50 C - 40 to 75 C Storage Temperature Operating Temperature - 20 to 50 C -per UL 1741 Internal Ambient Expectations MTBF ( Calc ) Life Time Not Replaceable 8kV air and 4kV contact per IEC61000 - 4 -2 Input Surge Immunity per IEC61000-4-5 Single Pulse, 1.2/50uS (class 3). 2KV Features: Power On LED indicator light Fault protected and auto reset: Input under-voltage, output over-load, or thermal shut down results in hiccup mode (Auto Restart). O input power cycled. > 200,000 hours at 40 C > 50,000 hours at 50 C ambient TAMURA CORPORATION OF AMERICA 1040 SOUTH ANDREASEN DRIVE, STE.100 ESCONDIDO, CA 92029 PHONE: (951)699-1270 FAX: (951)676-9482 (800)472-6624 www.tamuracorp.com Speci cations Subject to Change without Notice © Oct. . 2012 Tamura Corporation of America. All rights Reserved. 1   Model TCDC-7001 Industrial DC:DC Converter for Photovoltaic Applications Dimensions in Inches Applications Smart Combiner Box assemblies Remote Sensors and Security Power Source Radio and Wireless Data Links Power Current Sensors Modules Security Lighting Battery Charging (coming soon) - UL 1741 - CSA No.107.1 - UL 1012 Output isolated from Input. Dielectric Strength 4250 Vdc 60 sec. from Input Terminals to Output Terminals and terminals to plastic case For use in Controlled Environment, see Installation Guide Warnings and Restrictions. Item 41501 Rev C TAMURA  CORPORATION  OF  AMERICA 1040  SOUTH  ANDREASEN  DRIVE,  STE.100  ESCONDIDO,  CA  92029   PHONE:  (951)699-­1270        FAX:  (951)676-­9482 (800)472-6624 www.tamuracorp.com Specifications  Subject  to  Change  without  Notice         © Oct.  .  2012  Tamura  Corporation  of  America.  All  rights  Reserved.         2
TCDC-7001 价格&库存
很抱歉,暂时无法提供与“TCDC-7001”相匹配的价格&库存,您可以联系我们找货
